How do you use this SCR for a stud welder
    • Jul 2011
    • 6024
    This may be the right place to this post question if this is the case please for give me
    http://www.digikey.com/product-detai...147-ND/1998988
    Part number is a T700123504BY
    Re: How do you use this SCR for a stud welder
    Are you repairing a welder or you are trying to build a welder?
      • Jul 2011
      • 6024
      Trying to build one
      I have one but it has to much power to is for use on a battery tap welding
      It has one the part is SKT491/04D which was cross over to a SKT493/18E
      you have to buy 6 of them @$600.00
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8670
        I was thinking about building one, and the trouble I had was ... getting the capacitors. The SCR was intended for cap discharge welders.
        I ended up backtracking and thinking about another way of doing this and was wondering what I can do with 100+ amps... Not quite as much as a capacitive discharge welder but still significant...
          • 30937
          what are you trying to weld ?
            • 30937
            http://ultrakeet.com.au/write-ups/cdWelder
            dont kill yourself!!!
            • ben7
              Capaholic
              • Jan 2011
              • 4059
              You could possibly get the caps from an old UPS system, or the like. People on fleabay sell large caps for reasonable prices (of course, they are usually used)
              Muh-soggy-knee
                Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
                by sam_sam_sam
                I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
                I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
                I tested the battery cells there are installed right now and they are testing good with no issues that I...
                02-04-2025, 08:08 PM
              • spleenharvester
                Reverse engineering of DoCreate DHJ567 handheld spot welder
                by spleenharvester
                Hello everyone
                I attach a schematic and teardown photos for the DoCreate DHJ567 handheld spot welder. I bought this welder for temporary use while my supercapacitor welder was waiting for replacement parts. It cost only £24, though there is a screenless version available for £17.
                Performance: The absolute maximum it can handle appears to be 0.15mm of pure nickel. Reliability was not great - welds were very inconsistent, ranging from weak attachment to burning through the strip. However, I was able to build a 5S2P pack without losing any cells. It's a bit difficult getting...
                05-08-2025, 02:52 PM
              • Dobrowol
                Dell Latitude 3520 help with bios build/repair
                by Dobrowol
                Hello. Ive got problem with Dell Latitude 3520. After power on, no display and fan goes crazy. Standard job, I exported a clean bios from update via pfs extract.
                Steps i done and results:
                I exported a clean bios from update file via pfs extract.
                1. Build clean bios with clean ME, PMC, PCH in flash image tool.
                Result: Dead
                2. Build clean bios with no changes in ME, new PMC, PCH
                Result: Dead
                3. Build old bios with clean ME, new PMC, PCH
                Result: The same
                09-22-2023, 02:43 AM
                ACER Revo M2-601 Revo Build i3-6100U Specification for Upgrade or Repair
                This specification for the ACER Revo M2-601 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Revo M2-601 boardview and Revo M2-601 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ACER Revo...
                09-12-2024, 03:28 PM
