I opened a Dell Server PSU, what do you think? also arent ltec a bad brand of caps especially for a server...
Dell Server PSU Teardown
Tags: None
Re: Dell Server PSU Teardown
Normally, Ltec aren't great, but 1) i've rarely (if ever) seen any of them outside of Delta power supplies, and 2) somehow, Delta manage to pull off some sort of mojo-voodoo by which they make Ltec's last for quite a while
And Newton Power Systems are either a subsidiary, or just a brand, of Delta, so...Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans -
Yup. LTECs fail everywhere else, but not in Delta PSUs.I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
I've had Ltecs fail after about a year or so in a Delta power supply from a Lexmark C543dn color laser printer. Most of the caps (Ltec and CapXon) were fine, but two Ltecs under one of the heatsinks on the secondary side were bulged.Comment
They were making reference to well ventilated and cooled Delta PSUs. Printer PSUs don't count where the capacitors were touching the finless heatsinks. Neither do LCD monitors; LTEC capacitors will be bloated in those PSUs as well. They run as hot as hell.(note that I am defending DELTA, not LTEC
I'm quite sure Delta did their homework regarding those supplies, but i'm willing to bet money the system designers (ie. people/teams who designed the cases / devices those supplies were used in where Ltecs fail) either didn't give two flying f*beep*s, or had no clue about, cooling requirements and such...Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - ShenanigansComment
Ltecs are garbage. take one out and measure it and its probably way off. I would yank them allComment
Also the Delta GPS-x00AB platform is quite troubled with bloated caps.Less jewellery, more gold into electrotech industry!Half of the computer problems is caused by bad contacts
Exclusive caps, meters and more!Hardware Insights - power supply reviews and more!Comment
Yah. I never really blame the caps itself for failing if the PCB around it is heat darkened. You can cook Rubycons in such conditions.I love putting bad caps and flat batteries in fire and watching them explode!!
I'm not saying you are wrong but keep in mind as the cap fails the switching transistors need to work _much_ harder to keep a stable voltage output.
Thus heating up waay more than normal..."The one who says it cannot be done should never interrupt the one who is doing it."Comment
This. It was probably pretty hot already and when the caps failed, the silicon burned itself. I got another one (most likely bad signal board), it is not so black but still it was heating as well.
Anyway Delta fucked up heavily. With Chemi-cons KY it would work twice as long at least, but I guess Acer didn't want that lolLess jewellery, more gold into electrotech industry!Half of the computer problems is caused by bad contacts
Delta have sometimes been prone to error like any other company. Poor designs in LCD PSUs and using CapXon in GPS-series PSUs aren't their only erroneous decisions. Sometimes they underspec the primary rectification diode in the two transistor +5VSB circuit (using a single standard recovery rectifier diode I think, something like IN400x) and it gets so hot (without airflow that is) as to even kill the "critical" Japanese capacitor in their older PSUs (DPS-300KB-1x, DPS-85NB, and some other PSUs come to mind) since they had a habit of placing the capacitor right next to that diode. IIRC everell had to repair the snubber circuit in another Delta PSU because it too was underspec'd and failed. And the GPS-300AB-100V series of PSUs always has the +5VSB output diode running way too hot and cooking the output capacitor present (usually a CapXon GL since it was right next to it), probably because they only used a 3A diode or something without a heatsink (the same way Bestec PSUs run too hot in terms of +5VSB output rectifiers). This is a stark contrast to other Delta PSUs that use a single, low VF 10A/40V TO-220 rectifier on a finless heatsink for +5VSB rectification...
HOWEVER, with regard to their well ventilated PSUs with ample airflow, generally speaking, capacitor failures are rare in their PSUs unless we're talking CapXon. This is especially true if you compare the amount of LTEC failures in Delta PSUs, overall, compared to the amount of Teapo failures in Hipro PSUs and LTEC/OST failures in Lite-on PSUs (on the output - there is no comparison - Teapo capacitors, G-Luxon capacitors, etc, fail all the time in Hipro units....). While Hipro PSUs are designed very well for the most part, the thermal design on the secondary side is not ideal and so the capacitors run hotter and suffer a shorter life. That being said, Hipro PSUs are very solid with a recap...Last edited by Wester547; 12-14-2014, 12:50 PM.Comment
Yup. I have a GPS-300AB in my stash, and the 5vsb diode discolours the PCB. My solution was to take a 12A fast recovery rectifier from the 12V rail of a gutless wonder, screw it to the secondary heatsink, and connect it with wires to where the original diode went. That way, it won't cook the cap.I love putting bad caps and flat batteries in fire and watching them explode!!
ASRock B550 PG Velocita
Ryzen 9 "Vermeer" 5900X
Arc A770 16 GB
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
"did I see a chair fly? I think I did! Time for popcorn!" -ratdude747Comment
Do you mean CapXon KM? Definitely replace those.
They are probably all fine. As I said, they fail everywhere -except- on most Delta PSUs, where they usually hold up just as well as Japanese caps. Delta really do seem to have a way with LTEC.Last edited by c_hegge; 12-14-2014, 05:12 PM.I love putting bad caps and flat batteries in fire and watching them explode!!
by omegaHello all,
as a beginner electronics hobbyist, after a few years I would like to place another post on this Forum section, given that I did not succeed in finding any useful advice among the other posts.
Over the last years, I have been using a PowerEdge Dell Server with two redundant PSUs, namely the 750W F750E-S0 ones (aka 06W2PW). Unfortunately, last summer one of them failed (perhaps owing to an overheating), and the server had for working to take into account the other one only. Of course I opened and tried to troubleshoot the failed PSU, but each cap I tested seemed to...1 Photo -
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
This specification for the MSI Delta DELTA 15 A5EFK-008 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the DELTA 15 A5EFK-008 boardview and DELTA 15 A5EFK-008 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-07-2024, 03:40 AM
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
Channel: BIOS Requests ONLY!
by master3112I would like to share my experience about charging issues with Dell power supplies with the tech community. I am working on a Dell Inspiron 5590, Mainboard 18778-1 with charging problems. The device can be switched on and works so far, only the message appears at startup:
The power supply unit is not recognized in the Bios and the charging process is set to "idle". I use original Dell battery, type...-
Channel: Schematic Requests ONLY!
- Loading...
