Dell Server PSU Teardown
  • blasterboomer
    • Dec 2013
    • 135
    • United Kingdom
    I opened a Dell Server PSU, what do you think? also arent ltec a bad brand of caps especially for a server...
  • Khron
    • Sep 2006
    • 1350
    • Finland
    Re: Dell Server PSU Teardown
    Normally, Ltec aren't great, but 1) i've rarely (if ever) seen any of them outside of Delta power supplies, and 2) somehow, Delta manage to pull off some sort of mojo-voodoo by which they make Ltec's last for quite a while
    And Newton Power Systems are either a subsidiary, or just a brand, of Delta, so...
    Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
    • c_hegge
      • Sep 2009
      • 5219
      Yup. LTECs fail everywhere else, but not in Delta PSUs.
      • cheapie
        null
        • Jul 2010
        • 849
        I've had Ltecs fail after about a year or so in a Delta power supply from a Lexmark C543dn color laser printer. Most of the caps (Ltec and CapXon) were fine, but two Ltecs under one of the heatsinks on the secondary side were bulged.
        • Wester547
          • Nov 2011
          • 1268
          • USA.
          They were making reference to well ventilated and cooled Delta PSUs. Printer PSUs don't count where the capacitors were touching the finless heatsinks. Neither do LCD monitors; LTEC capacitors will be bloated in those PSUs as well. They run as hot as hell. (note that I am defending DELTA, not LTEC )
          • Khron
            • Sep 2006
            • 1350
            • Finland
            I'm quite sure Delta did their homework regarding those supplies, but i'm willing to bet money the system designers (ie. people/teams who designed the cases / devices those supplies were used in where Ltecs fail) either didn't give two flying f*beep*s, or had no clue about, cooling requirements and such...
            • CapSwapper
              • Feb 2014
              • 69
              Ltecs are garbage. take one out and measure it and its probably way off. I would yank them all
              • Behemot
                • 4845
                • CZ
                It's Delta stupidity to use them in such conditions so the blame goes back to Delta. One of the worst Deltas I've ever seen:
                Also the Delta GPS-x00AB platform is quite troubled with bloated caps.
                  • 31026
                  the heatsink is too damned small and the component is probably underated.
                  i wont blame the caps when the board is that burned - it's even burned where the heatsink is soldered down at the left!!!!
                  • c_hegge
                    • Sep 2009
                    • 5219
                    Yah. I never really blame the caps itself for failing if the PCB around it is heat darkened. You can cook Rubycons in such conditions.
                    • Per Hansson
                      • Jul 2005
                      • 5895
                      • Sweden
                      I'm not saying you are wrong but keep in mind as the cap fails the switching transistors need to work _much_ harder to keep a stable voltage output.
                      Thus heating up waay more than normal...
                      • Behemot
                        • 4845
                        • CZ
                        This. It was probably pretty hot already and when the caps failed, the silicon burned itself. I got another one (most likely bad signal board), it is not so black but still it was heating as well.
                        Anyway Delta fucked up heavily. With Chemi-cons KY it would work twice as long at least, but I guess Acer didn't want that lol
                          • 31026
                          i also just realised that the caps would be above the heatsink when it's assembled, so getting cooked by convection too!!!
                          • Wester547
                            • Nov 2011
                            • 1268
                            • USA.
                            Look at that, the small Teapos (visibly) outlasted the LTECs.
                            Delta have sometimes been prone to error like any other company. Poor designs in LCD PSUs and using CapXon in GPS-series PSUs aren't their only erroneous decisions. Sometimes they underspec the primary rectification diode in the two transistor +5VSB circuit (using a single standard recovery rectifier diode I think, something like IN400x) and it gets so hot (without airflow that is) as to even kill the "critical" Japanese capacitor in their older PSUs (DPS-300KB-1x, DPS-85NB, and some other PSUs come to mind) since they had a habit of placing the capacitor right next to that diode. IIRC everell had to repair the snubber circuit in another Delta PSU because it too was underspec'd and failed. And the GPS-300AB-100V series of PSUs always has the +5VSB output diode running way too hot and cooking the output capacitor present (usually a CapXon GL since it was right next to it), probably because they only used a 3A diode or something without a heatsink (the same way Bestec PSUs run too hot in terms of +5VSB output rectifiers). This is a stark contrast to other Delta PSUs that use a single, low VF 10A/40V TO-220 rectifier on a finless heatsink for +5VSB rectification...
                            HOWEVER, with regard to their well ventilated PSUs with ample airflow, generally speaking, capacitor failures are rare in their PSUs unless we're talking CapXon. This is especially true if you compare the amount of LTEC failures in Delta PSUs, overall, compared to the amount of Teapo failures in Hipro PSUs and LTEC/OST failures in Lite-on PSUs (on the output - there is no comparison - Teapo capacitors, G-Luxon capacitors, etc, fail all the time in Hipro units....). While Hipro PSUs are designed very well for the most part, the thermal design on the secondary side is not ideal and so the capacitors run hotter and suffer a shorter life. That being said, Hipro PSUs are very solid with a recap...
                            • c_hegge
                              • Sep 2009
                              • 5219
                              Yup. I have a GPS-300AB in my stash, and the 5vsb diode discolours the PCB. My solution was to take a 12A fast recovery rectifier from the 12V rail of a gutless wonder, screw it to the secondary heatsink, and connect it with wires to where the original diode went. That way, it won't cook the cap.
                              • RJARRRPCGP
                                • Jul 2004
                                • 6304
                                Not as likely as "KM"s. Replace all "KM"s on sight!!
                                Looks like LCD monitor makers like using KM caps.
                                ASRock B550 PG Velocita
                                Ryzen 9 "Vermeer" 5900X
                                Arc A770 16 GB
                                eVGA Supernova G3 750W
                                Alienware AW3423DWF OLED
                                • c_hegge
                                  • Sep 2009
                                  • 5219
                                  Do you mean CapXon KM? Definitely replace those.
                                  They are probably all fine. As I said, they fail everywhere -except- on most Delta PSUs, where they usually hold up just as well as Japanese caps. Delta really do seem to have a way with LTEC.
                                  • omega
                                    Troubleshooting of redundant F750E-S0 Dell PowerEdge Server
                                    by omega
                                    Hello all,
                                    as a beginner electronics hobbyist, after a few years I would like to place another post on this Forum section, given that I did not succeed in finding any useful advice among the other posts.
                                    Over the last years, I have been using a PowerEdge Dell Server with two redundant PSUs, namely the 750W F750E-S0 ones (aka 06W2PW). Unfortunately, last summer one of them failed (perhaps owing to an overheating), and the server had for working to take into account the other one only. Of course I opened and tried to troubleshoot the failed PSU, but each cap I tested seemed to...
                                    02-09-2024, 03:34 PM
                                  • Bowline
                                    by Bowline
                                    06-11-2025, 10:13 AM
                                    MSI Delta DELTA 15 A5EFK-008 Notebook 15 Specification for Upgrade or Repair
                                    This specification for the MSI Delta DELTA 15 A5EFK-008 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the DELTA 15 A5EFK-008 boardview and DELTA 15 A5EFK-008 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                    09-07-2024, 03:40 AM
                                  • Dynamite76
                                    Dell D635EF DELTA DPS-635AB PSU with blown TNY280PN
                                    by Dynamite76
                                    Recently I got a DELL PSU from a presision T3600. It is a 635W PSU which went out with a bang and some black smoke. The model of the PSU is a D635EF made by DELTA.
                                    The cause of the bang was a blown. TNY280PN Chip. How ever as a result or as a causo also two SMD resistors are smoked. I have been able to replace the TNY280 Chip but I do not know the values of the resistors. The resistors are within the Drain line of the TNY. I can not find the schematic of this PSU. THe resistor are Open Loop and on the voltage accross them is about 330V. (EU)
                                    Any suggestions for...
                                    07-27-2023, 01:52 PM
                                  • hazem3636
                                    need Bios Bin file Dell server 220
                                    by hazem3636
                                    hi everyone
                                    i need dump file for dell server r220
                                    i have download Flash BIOS executable file but i dont know how to conver it to Bin file
                                    i have check on youtube there is some programs are doing this method of creating Bin file from ExE file .
                                    if anyone has this method please need his supporting .
                                    all the best
                                    EXE file is attched and Original Bin file from the Bios Chip is attached also
                                    and dell website "https://www.dell.com/support/home/en-us/drivers/driversdetails?driverid=mrxv...
                                    11-05-2022, 06:20 AM
