PC PSU damaged by lightning strike
  • TELVM
    • Oct 2012
    • 547
    • Spain
    A friend got his PC zapped by a nearby lightning strike. Says Mobo, CPU and GPU are dead, he has tested them with another PSU and they don't work .
    About the injured PSU, he says it just trips the house's residual-current circuit breaker whenever he switches it on.
    He knows I like tinkering PSUs and has asked me if I could resuscitate his PSU. I've told him that after a strike that has screwed the whole PC, chances are his PSU is FUBAR .
    What do you guys think? What have been your experiences dealing with lightning-damaged PSUs?
  • Compgeke
    • Feb 2014
    • 524
    Re: PC PSU damaged by lightning strike
    After a lightning strike I wouldn't even bother trying to fix it. I wouldn't be surprised if it ate some traces off the board and\or killed nearly everything in its path.
    It would be fun to open just to assess the damage but I've seen a few lightning damaged things before and I wouldn't consider it worth the effort.
    • everell
      • Jan 2009
      • 1514
      On the other hand......if you fix it you will learn something.
      Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
      • c_hegge
        • Sep 2009
        • 5219
        I want to see some pictures of the carnage
        Here, lightning strikes almost always come through the phone line, which kills the ADSL Modem/router and/or Ethernet controller on the motherboard.
          • 31055
          seconded - foto's, lots of them!
          • TELVM
            • Oct 2012
            • 547
            • Spain
            I've told him not to junk the wreck, so next time I see him (he lives quite aways) I'll snatch the body for forensics .
            • CapSwapper
              • Feb 2014
              • 69
              no surge protector on wall outlet? It would have took the brunt of the hit.
              • Khron
                • Sep 2006
                • 1350
                • Finland
                Trips the RCD, you say? Some Y-caps failed short, perhaps?
                Unless some sort of arcing "welded" the line or neutral to the case (which sounds a bit less likely)...
                Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
                • Behemot
                  • 4845
                  • CZ
                  Yeah may be something directly on filtration, MOV, X/Y caps etc.
                  • ben7
                    Capaholic
                    • Jan 2011
                    • 4059
                    Yeah that's what I think. You know, Y-caps aren't completely fail-safe
                    Or perhaps it has fake Y-caps
                    Muh-soggy-knee
                    • Khron
                      • Sep 2006
                      • 1350
                      • Finland
                      Correct me if i'm wrong, but i recall reading somewhere that X-caps were designed to fail open, and Y-caps to fail short. Or was it the other way around?
                      • ben7
                        Capaholic
                        • Jan 2011
                        • 4059
                        Neither of them are meant to fail short. If they do, they could pose a fire and/or shock hazard!
                        Muh-soggy-knee
                        • Behemot
                          • 4845
                          • CZ
                          It was that usually ordinary ceramic caps go short. Metalized foil usually loose capacity and should not get shorted even if not safety (the foil vaporizes when there are mini-shorts internally untill most of the area disappears and it ceases to exist as a capacitor).
                          Safety caps should open in each case.
                          • senz_90
                            • Aug 2013
                            • 328
                            • Indonesia
                            Third request! Pict of burnt PSUs if your friend give it next time
                            "There is no shortcut to be successful. No pain, no gain."
                            Best Regards
                            Rudi
                            Thank You
                            • pfl
                              ElectroVoice ETX-18SP (powered Subwoofer) damaged after lightning strike
                              by pfl
                              Hello Everyone.
                              This powerful amplified subwoofer doesn't make any sound after lightning striked near the house were it was plugged in.
                              It consists in :
                              • a power board were the full H bridge class D amplifier and main power rails are located
                              • a preamp board (ref. F.01U.299.771) receiving 2 symetrical inputs(IN1, IN2), a digital chain (A-D converter -> Digital Signal Processor -> D-A converter) and a micro controler in charge (at least) of the human interface (lcd display and 1 rotating button)
                              Power rails are ok.
                              human interface is working fine
                              Input levels are...
                              01-23-2024, 10:21 AM
                            • Bardou Kari
                              HP EliteBook 840 G6 – no power after lightning strike
                              by Bardou Kari
                              I’m trying to fix an HP EliteBook 840 G6 that stopped working after a lightning storm.
                              – Charger is OK and 19V is present at the motherboard.
                              – No charging LED, no fan, no reaction.
                              – I don’t see any 3.3V or 5V near the coils.
                              – Battery is unplugged.
                              – I’m new to board repair but can use a multimeter.
                              I added a clear photo of the board.
                              Any idea where to start or what to check next?
                              Thanks a lot for your help!...
                              07-01-2025, 10:45 AM
                            • karthur
                              Samsung UN60EH6000 wont come on after lightning strike.
                              by karthur
                              We had a lightning strike a few days ago really close to my house. My Samsung UN60EH6000 was on when it hit. Afterwards, the TV would not come back on.
                              I had repaired this TV a few years back by replacing the T-Con board. (The post I had on this is repair is here.)
                              When I turn on the TV, I don't get any start-up melody. The screen just dimly flickers around the edges.
                              Here is what I have checked.
                              On the power supply board, 14pin connector:
                              1 :12.7 Vdc
                              3 :12.7
                              5 :12.7
                              7 :12.7
                              9 :0
                              11 :5.
                              13 :5....
                              11-01-2023, 06:18 PM
                            • pbig
                              advices for repairing Sony Bravia 32EX600 after lightning strike
                              by pbig
                              hi everyone,
                              my parents in law have seen their Bravia Sony LED 32EX600 TV set stop after a lightning strike. After being plugged to mains, it shows nothing no power LED on bottom left shines.
                              On the power PCB (GE3b, attached pic), I chacked the fuses and the only roasted one is R6536 : 0.47 ohms, 1/2W. After replacing it, I made some voltage measurement with ref to the chassis :
                              - the 450V/150uF capacitor voltage when plugged is normal at 394V
                              - from connector CN6150 (15 poles)
                              STBY normal 3.3V -> I shunted it to 3 (POWER ON) and 11 (BL ON) and unplugged...
                              06-28-2023, 02:43 AM
                            • ktmmotocross
                              DELL 5537 LA-9982P - not work after lightning strike
                              by ktmmotocross
                              Hello.
                              Have this DELL 5537 LA-9982P that not work after lightning strike to house.
                              i replaced PQ701 but now have only 5.5V after it. ACDRV have voltage only for a moment when attach charger. BQ24717 have ACDET 2.58V, VIN 19V. Dont have this charger ic , can be replaced by other like 737?
                              How to check if PSID is ok?
                              MOD Edit: Schematic & boardview moved to new thread - https://www.badcaps.net/forum/showthread.php?t=122414
                              12-25-2022, 03:39 AM
