Old PC PSU making noise etc
  • roadrash
    • Oct 2015
    • 499
    • U.K.
    A vintage 1980's PC power supply has started making a hissing and whining/squealing noise and the PC is now giving random errors like memory and video etc. Ive tried the PSU with just the Motherboard plugged in and its quiet but soon as I increase the load adding controller interface cards and drives etc, the noise starts. I think there is something about to fail but cannot see anything like a bulging cap or anything. Does anyone know whats the most likely suspect component? Here is a link to a video i took.
    • 31316
    re-cap it
    • roadrash
      • Oct 2015
      • 499
      • U.K.
      Thanks STJ, i was going to do that but just wondered if there was anything else that could make that noise. Will i need to replace those 2 large cans as well.
        • 31316
        coil noise is often caused by the psu running at the wrong frequency or being overloaded.
        small caps can effect the pwm circuit.
        *and warn people that your video is 150M in size
        • roadrash
          • Oct 2015
          • 499
          • U.K.
          Thanks Stj, thats what i thought i had heard before that a whining noise was a coil or something. Thats interesting i signifies there is somethings not right. Ok will get all those caps changed. Thanks you thats a great help .
          • PeteS in CA
            • Aug 2005
            • 3586
            • USA, Unsure of Planet
            When you do the re-cap, be aware that using the latest and greatest low impedance electrolytics could cause stability problems. I would suggest Nichicon PJ or PS series if either is available, and as second choices, PM or PW series.
            PeteS in CA
            • roadrash
              • Oct 2015
              • 499
              • U.K.
              I took all the electrolytic caps out of my PSU today and what a hard job it wad getting the 2 big 200v ones out as they were glued in good and proper. Well just out of interest i tried each one on my component tester and this are the results.. not sure what is a bad ESR etc so do any look like they are bad?
              PSU Caps tested
              16v 3300 x2 off (C27+29)
              (1) Measures: 307.4 uf
              Vloss: 1.8
              ESR: 0.06 ohm
              (2) Measures: 3020uf
              Vloss:1.6
              ESR: 0.08 ohm
              16v 47uf (C35)
              Measures: 46.87
              Voss: 2.1
              ESR: 1.0ohm
              200wv 680uf x2off
              (1) measures: 602.5uf
              Vloss: 0.6
              ESR: 0.8
              (2) Measures: 606.2UF
              Vloss: 0.9
              ESR: 0.8
              16v 330uf x3 off (C21 + C24 + 30)
              (1) Measures 281.9uf
              Vloss: 2.1
              ESR: 0.20ohm
              (2) Measures: 792.6uf
              Vloss: 1.9
              ESR: 0.23ohms
              (3) measured 282.6uf
              Vloss: 1.9
              ESR: 0.22ohm
              16v 1000uf (C31)
              Measures: 850.8uf
              Vloss:1.9
              ESR: .12 ohms
                • 31316
                the 330uf cap that read as 782 is leaky as fuck.
                i'm surprised the tester didnt catch that.
                • roadrash
                  • Oct 2015
                  • 499
                  • U.K.
                  Thanks, unfortunately that was a typo it should have read 292uf. I only copied and pasted so dont know how that happened.
                  is there any others not showing particularly good so i can know there was a problem with a cap or two and should i still replace them all.
                  • roadrash
                    • Oct 2015
                    • 499
                    • U.K.
                    having difficulty finding capacitors of the series like you recommenced,. The two Big 200v 680uf nichicon caps in this PSU are marked PS(M) which google states "PS(M) is a series of polarized aluminum electrolytic capacitors with a P for polarized, S for a series designation, and (M) for a tolerance rating of ±20%., These are general-purpose capacitors designed for a wide range of applications" is this correct because I too think they should be long life type. if I can find some. Id there a special marking or prefix number that identifies this series of caps.
                    • roadrash
                      • Oct 2015
                      • 499
                      • U.K.
                      I can see now Nichicon Caps beginning UP? denotes P series thanks and EL? is snap in type. Still hard to find a Nichicon Cap like you recommend. Does it matter that I use a snap in mounting type or how critical is the size? If for say I can find a P series cap but its a leaded type and a bit smaller than the original size would this matter? Also what is an acceptable impedance range?
                        master hoarder
                        • May 2008
                        • 12176
                        • Bulgaria
                        You can leave the big 200V caps alone, as in, not buy new ones. The old ones measure fine and won't give you issues. On non-APFC PSUs, those large HV caps almost never fail. So save yourself the money and hassle with trying to replace those. From your list of the caps that you posted above, the one 3300 uF (C27) cap that measures 307.4 uF is definitely bad... unless that was a typo as well?? Is that all of the caps in the PSU? I suspect there should be lots more small ones... and usually these are the ones to fail "silently" (ironic, given the PSU's symptoms, isn't it ) without bulging or leaking. So it might be worthwhile to check all of the small caps, especially ones near heatsinks or other large/hot power components. While at it, check the solder joints in the PSU too. Also, how are the motherboard caps? Any suspicious brands to beware of on there? Just asking, because I don't like to jump to the conclusion that the PSU is causing the issues here... at least not without confirming that the issues do go away with another PSU.
                          • 31316
                          is this psu AT or XT?
                          • roadrash
                            • Oct 2015
                            • 499
                            • U.K.
                            Thank you very much for taking the time to help with that info. Ok I will put the 3 big caps back in. There are no other smaller caps except tantalum type ones. I read on my history notes when i first got this and turned it on it blew up a tantalum cap which after it was replaced the computer worked. These new faults that have started are frustrating because there are no visible signs of any bad caps. The main computer PCB just has little bead type caps. Here is a photo of the computers PCB. I have has this working ok when i first started using it and then it started giving memory and graphics errors and at the same time I heard the PSU making the whining noise so just put it all down to a PSU problem making the computer unstable.
                            • roadrash
                              • Oct 2015
                              • 499
                              • U.K.
                              Its a AT PSU
                                • 31316
                                i just use panasonic FR in those
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 5111
                                  • New Zealand
                                  If you already had one blown tantalum, you may have others not far behind. A partially shorted one could cause overloading. Might pay to replace the lot when they're that old.
                                  -David VanHorn
                                  • tony359
                                    by tony359
                                    11-28-2023, 05:18 AM
                                  • MegaZAC
                                    Onkyo TX-SR805 noise in one channel
                                    by MegaZAC
                                    Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                                    Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                                    There's some logic behind it. As soon as I select an input I get only left...
                                    04-23-2025, 10:09 PM
                                  • dicky96
                                    DynAudio DBM50 Monitor Speaker - loud hissing noise
                                    by dicky96
                                    Hi guys
                                    I have a DynAudio DBM50 here - it makes a loud hissing noise.
                                    It sounds just like an FM radio with no antenna (or tuned off-station). The volume of the hissing fades up and down, sometimes drops to almost nothing then comes back loud. It occasionally makes a loud bump noise too.
                                    It does this even with nothing connected to the audio input XLR
                                    Any suggestions?...
                                    11-09-2020, 08:45 AM
                                  • courtcircuit
                                    Philips HTS8000 home cinema noise problem
                                    by courtcircuit
                                    Hello
                                    I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
                                    Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
                                    Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
                                    I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
                                    Removed each of tyhe boards
                                    02-08-2025, 08:22 AM
                                  • badcappo
                                    Dead Thinkpad E15, hissing noise from BQ25710
                                    by badcappo
                                    Hello there, got a Thinkpad E15 on the bench, almost no vital signs. Only things: Power button white LED flashes several times when USB-PD gets connected (number of flashes varies from three up to twelve times, sometimes no reaction at all). Battery charge indicator LED stays orange. Most interesting is hissing / whining sound from Battery Charge Controller IC BQ25710 on the keyboard side of the main pcb. Board fuses tested and intact, no shorts found so far. BQ25710 is also the only thing on the board to become warm in thermal image (below 70 °C). Thanks for any hint.
                                    03-09-2025, 08:23 AM
