A vintage 1980's PC power supply has started making a hissing and whining/squealing noise and the PC is now giving random errors like memory and video etc. Ive tried the PSU with just the Motherboard plugged in and its quiet but soon as I increase the load adding controller interface cards and drives etc, the noise starts. I think there is something about to fail but cannot see anything like a bulging cap or anything. Does anyone know whats the most likely suspect component? Here is a link to a video i took.
Old PC PSU making noise etc
Tags: None
When you do the re-cap, be aware that using the latest and greatest low impedance electrolytics could cause stability problems. I would suggest Nichicon PJ or PS series if either is available, and as second choices, PM or PW series.PeteS in CA
****************************Comment
I took all the electrolytic caps out of my PSU today and what a hard job it wad getting the 2 big 200v ones out as they were glued in good and proper. Well just out of interest i tried each one on my component tester and this are the results.. not sure what is a bad ESR etc so do any look like they are bad?
PSU Caps tested
16v 3300 x2 off (C27+29)
(1) Measures: 307.4 uf
Vloss: 1.8
ESR: 0.06 ohm
(2) Measures: 3020uf
Vloss:1.6
ESR: 0.08 ohm
16v 47uf (C35)
Measures: 46.87
Voss: 2.1
ESR: 1.0ohm
200wv 680uf x2off
(1) measures: 602.5uf
Vloss: 0.6
ESR: 0.8
(2) Measures: 606.2UF
Vloss: 0.9
ESR: 0.8
16v 330uf x3 off (C21 + C24 + 30)
(1) Measures 281.9uf
Vloss: 2.1
ESR: 0.20ohm
(2) Measures: 792.6uf
Vloss: 1.9
ESR: 0.23ohms
(3) measured 282.6uf
Vloss: 1.9
ESR: 0.22ohm
16v 1000uf (C31)
Measures: 850.8uf
Vloss:1.9
ESR: .12 ohms
Thanks, unfortunately that was a typo it should have read 292uf. I only copied and pasted so dont know how that happened.
is there any others not showing particularly good so i can know there was a problem with a cap or two and should i still replace them all.Comment
having difficulty finding capacitors of the series like you recommenced,. The two Big 200v 680uf nichicon caps in this PSU are marked PS(M) which google states "PS(M) is a series of polarized aluminum electrolytic capacitors with a P for polarized, S for a series designation, and (M) for a tolerance rating of ±20%., These are general-purpose capacitors designed for a wide range of applications" is this correct because I too think they should be long life type. if I can find some. Id there a special marking or prefix number that identifies this series of caps.Comment
by tony359Hi all,
2. Even with the fan running outside of the case, there is still some noise which is clearly going back to the processor via power line....2 Photos -
by MegaZACSurprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
There's some logic behind it. As soon as I select an input I get only left...-
04-23-2025, 10:09 PM -
by dicky96Hi guys
I have a DynAudio DBM50 here - it makes a loud hissing noise.
It sounds just like an FM radio with no antenna (or tuned off-station). The volume of the hissing fades up and down, sometimes drops to almost nothing then comes back loud. It occasionally makes a loud bump noise too.
It does this even with nothing connected to the audio input XLR
Any suggestions?...-
by courtcircuitHello
I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
Removed each of tyhe boards
02-08-2025, 08:22 AM -
by badcappoHello there, got a Thinkpad E15 on the bench, almost no vital signs. Only things: Power button white LED flashes several times when USB-PD gets connected (number of flashes varies from three up to twelve times, sometimes no reaction at all). Battery charge indicator LED stays orange. Most interesting is hissing / whining sound from Battery Charge Controller IC BQ25710 on the keyboard side of the main pcb. Board fuses tested and intact, no shorts found so far. BQ25710 is also the only thing on the board to become warm in thermal image (below 70 °C). Thanks for any hint.
- Loading...
