DSP-167DP LOW VCC at IC901
  • TJM2005
    • Aug 2013
    • 25
    I am trying to repair a power supply for a Vizio M492i-B2.
    Before I started:
    Fusible Resistor R915 was open.
    ZD909 was shorted.
    D950B was shorted.
    I have replaced the above parts along with a new IC901 / LD7913J
    I now have:
    165V on the main cap
    IC901 Drain pins: 165V
    IC901 VCC: 1.1V
    IC901 COMP: 1.1V
    IC901 BNO: 0.3V
    I pulled the Q800 Mosfet and it checked good.
    I also tested the two smaller caps C907 and C904B, they both tested close to the rated value.
    Does anyone know of anything that could be causing this, or where I could check next?
    Thanks for your time.
  • R_J
    • 9600
    Are you sure ZD909 was shorted, or did it check shorted in circuit? ZD909 is across source resistors R907A & R907B which are low values, likely under 1Ω
    IC901 has an internal startup cell that creates a startup vcc voltage of around 12vdc to charge c904B so you should replace C904B and C907 as well.
    • CapLeaker
      Leaking Member
      • 8339
      165VDC on the main cap? When that thing is turned on you should have closer to 390VDC there. So… either it isn’t turned on or your APFC isn’t working. Plus IC901 is in UVLO with VCC at 1.1V.
      • R_J
        • 9600
        it won't turn ON when ic901 is the standby ic which ALSO provides VCC for the PFC drive ic, NO standby = NO pfc vcc, no optocoupler voltages etc.
        • TJM2005
          • Aug 2013
          • 25
          Yes, ZD909 tested shorted even when removed from the circuit.
          I put an order in for the C904B and C907 and should have them in a day or so.
          I missed that the IC generates its own VCC voltage, is this only during startup then the VCC power comes from the secondary side of the transformer ones it starts switching? Will it power up even if the optocoupler on the COMP pin is bad?
          I will plan to replace the caps then retest the VCC, I also ordered another LD7913J as the first one came from e-bay, and I am not sure of an easy way to test that is fully operational.
          I am on 120V 60Hz, shouldn't this be about the correct voltage?
          Vpeak ≈ 120V × 1.414 ≈ 169.7V
          • R_J
            • 9600
            Did you check the source resistors R907 A & R907B? make sure they did not open. when the internal mosfet in the ic shorted it may have damaged the source resistors, if it did the ic will likely not start. The ZD909 zener is more for spike suppression than regulation.
            When power is applied ic901 will have 165vdc on its drain and it will internally supply a small current to the vcc pin, this will charge C904B, once charged to about 12~16v the ic starts to switch, then the transformer will suppliy the vcc voltage via R908A~C and D902B to about 25vdc.
            Once the standby circuit is working, it will also supply the VCC voltage (via D902 and C907) to the pfc and main driver ic's, only when the power supply is switched ON will the pfc start to work and then you will have about 385vdc on the main capacitor.
            • CapLeaker
              Leaking Member
              • 8339
              Cuz there is a an active Power Factor Correction circuit that boosts the voltage to around 390 VDC. If that isn’t there, the TV is never going to work.
              Thats why I said, either the PSU is off, or there is something wrong with the PFC circuit. VCC at 1.1Vdc it is in undervoltage lock out.
              • R_J
                • 9600
                The power supply is OFF because it has no standby voltage
                • CapLeaker
                  Leaking Member
                  • 8339
                  Op didn’t specify…
                  • R_J
                    • 9600
                    Op didn’t specify…
                    I will wait for op to reply.
                    • TJM2005
                      • Aug 2013
                      • 25
                      Thanks for the info and explanations. I am working long hours the next couple of days, but I will try to test the source resistors when I have a minute. The caps should also be here sometime tomorrow.
                      There is no secondary voltage anywhere on the CN101 connector. I assume this is to be expected if IC901 isn't yet providing the switching needed to drive the transformer? I can also try to throw a scope on the VCC pin and see what it is doing as power is applied.
                      Appreciate the help so far.
                      • CapLeaker
                        Leaking Member
                        • 8339
                        There must be 5Vsb on that connector. IF there is none, you have to fix that first… otherwise there will be an absolute no go. How this works is VSB is always on on the PSU and gets sent to the main board. The main board will return the PSon and BLon, DIMM etc commands to the PSU. Without VSB on CN101, there is nothing going to happen… ever.
                        Fix VSB first then try the psu again by either putting everything together or forcing the PSU on by itself.
                        • TJM2005
                          • Aug 2013
                          • 25
                          I had time today to do some more testing.
                          I went ahead and threw new caps in for C904B and C907, each of the removed caps tested about 2uf lower than rated and was about 0.15Ω greater ESR than the new replacements.
                          • Source resistors R907A and R907B
                            • R097A = 5.1 Ω
                            • R907B = Open
                          I found this in another post:
                          4.7Ω in parallel with 3.9Ω would be 2.13Ω.
                          Can you confirm these are the correct values?
                          Being they are in parallel, is there any reason it would matter which one has what value?
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 5059
                            • New Zealand
                            What are the value markings on the resistors?
                            -David VanHorn
                            • R_J
                              • 9600
                              R907A = 4R70 4.7Ω
                              R907B = 3R92 3.9Ω
                              in parallel = 2.13Ω
                              I believe they are metal film 1 watt 1% resistors
                              • TJM2005
                                • Aug 2013
                                • 25
                                  • R907A = 5.1 Ω = Looks like 5R70?
                                  • R907B = 4.2Ω = 3R92
                                    • Looking at the picture I noticed one of the solder pads came off and I was able to take a reading.
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 5059
                                  • New Zealand
                                  The values look correct to me given the photos you've posted.
                                  And R_J says they are that too.
                                  ​Yes since they are in parallel it shouldn't matter which one goes in which position, as long as the values are correct.
                                  Although there's no logical reason to swap them, either.
                                  (That said if this were some weird super high frequency RF black magic situation, which way around they went might actually matter)
                                  -David VanHorn
                                  • TJM2005
                                    • Aug 2013
                                    • 25
                                    I ordered some SMD replacements, should have them in a couple of days.
                                    From what I could tell they are the 1206 package size.
ID:	3748605Click image for larger version
                                    • TJM2005
                                      • Aug 2013
                                      • 25
                                      Update:
                                      I got the two source resistors replaced, as well as the two small caps.
                                      • R907A
                                      • R907B
                                      • C904B
                                      • C907
                                      I am still only seeing 1.6V on the VCC pin
                                      Orange is VCC
                                      Blue Is BNO
                                      • Agent24
                                        I see dead caps
                                        • Oct 2007
                                        • 5059
                                        • New Zealand
                                        Did you check D902 and/or D902B yet?
                                        -David VanHorn
                                        • reessi
                                          Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                                          by reessi
                                          Hello:
                                          I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                                          I started on the ACER:
                                          Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                                          All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                                          I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                                          10-29-2024, 11:31 AM
                                        • Yanleb
                                          Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
                                          by Yanleb
                                          Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
                                          I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
                                          D608, good
                                          D618 RF101L4S, good (See warning 1 below)
                                          D619 RF101L4S, good (See warning 1 below)
                                          D865 RF101L4S, shorted (See warning 1 below)
                                          IC464 Inverter HA MC74HC1G14, shorted...
                                          03-09-2020, 12:00 AM
                                        • modtool
                                          HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
                                          by modtool
                                          Hi to all,
                                          the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
                                          I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
                                          I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
                                          04-01-2025, 08:22 AM
                                        • BalkanBoy
                                          Dead Razer Blade 14 2022, shorted CPU?
                                          by BalkanBoy
                                          today I got Razer Blade 14, Ryzen 9 6900HX and RTX 3070Ti.
                                          Laptop was completely dead. I found shorted CPU VRM mosfet, shorted 19V mosfet and blown battery fuse.
                                          I replaced it all, but still on CPU coil where mosfet was shorted I got very low resistance, near 0 ohms. On other CPU coils I got around 3 ohms.
                                          Laptop now raises voltage on whole board, but still nothing comes on the screen. CPU gets 0.7V on all coils except the shorted one. CPU gets only slightly hot, below 40 C.
                                          I removed coil and injected 0.7V, it draw around...
                                          09-27-2024, 12:44 PM
                                        • barry101
                                          Apple 820-3662 VCore shorted to ground.
                                          by barry101
                                          Hi, Would appreciate some help.
                                          I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
                                          Get charger light but no fan spin or chime. No liquid damage.
                                          Found PPBUS and VCORE both shorted to ground. Other rails were ok.
                                          Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
                                          With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
                                          Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
                                          06-24-2025, 07:34 AM
