Reducing ripple voltage
  • new2019
    • Aug 2014
    • 49
    • Srilanka
    Hey guys , I read some reviews about my Silverstone ST1500W and it seems to have ripple voltage. Some say its bad for mobo and other components .
    Is there a way to reduce it to minimum by replacing parts on psu ?
    Any advice ?
    Re: Reducing ripple voltage
    How high are the ripple voltages? Are they higher than the spec? Power supply will always has ripple voltges because the capacitors will always be charged and discharged.
    • new2019
      • Aug 2014
      • 49
      • Srilanka
      I'm not sure if they are in spec , but in specs it says 120mV and 50mV .
      If I recap with very good ones will it reduce the ripple voltage ?
      one more thing: will it be a problem if I replace a irfb3206 mosfet with irfb3207 mosfet ?
      the irfb3206 is for 120A and irfb3207 is for 130A , can it increase the output of my powersupply ? or can it damage my psu ?
      • mariushm
        • May 2011
        • 3799
        Recapping doesn't guarantee lower ripple. Ripple is a combination of capacitors, pi filter on output, how fast the psu reacts to changes in output current and other factors.
        Changing mosfets doesn't change the power supply performance, won't make power supply more capable.
        That Amps rating of mosfets is somewhat meaningless for power supplies, doesn't mean the power supply will be capable of more amps if you replace the mosfet.
        • new2019
          • Aug 2014
          • 49
          • Srilanka
          Thanks mate for clearing that out . I thought if I replace the mosfet it would do better .
          What is really responsible to give higher out put ?
          • LLLlllou
            • May 2011
            • 201
            Whatever the weakest link is, usually the input switcher(s) or the transformers.
              It sound to me that you do not have the equipment to make the proper measurement.
              Wrong value, type of capacitor can cause power supply to become stable. Same for other active components. You have to be able to measure the DUT before and after modification to see what it becomes.
              You should do more study and look into the matter more.
              BTW, for example that the transformer is rated at 10VA, you're not going any more VA than the transformer can handle, and if you drive the transformer too hard, the core will saturated, the inductance will drops and you will see magic smoke.
              http://e2e.ti.com/support/power_mana...ge-ripple.aspx
              https://cdn.badcaps-static.com/pdfs/...c2d95d3787.pdf
              http://www.hardwaresecrets.com/article/181
              https://cdn.badcaps-static.com/pdfs/...18fa07ffd4.pdf
              • new2019
                • Aug 2014
                • 49
                • Srilanka
                Yea , I dont have the correct tools so I have ordered them now.
                Oh il refrain from doing that lol I dont want to overstress my psu.
                Thanks for those links .
                ALso you guys are real helpful , thanks for that .
                I'l give my maximum effort to fix this .
                  ISL6556ACB ISL6556ACBZ ISL6556ACR ISL6556ACRZ PWM Controller Datasheet
                  Optimized Multi-Phase PWM Controller
                  with 6-Bit DAC for VR10.X Application
                  The ISL6556A controls microprocessor core voltage
                  regulation by driving up to 4 synchronous-rectified buck
                  channels in parallel. Multi-phase buck converter architecture
                  uses interleaved timing to multiply channel ripple frequency
                  and reduce input and output ripple currents. Lower ripple
                  results in fewer components, lower component cost, reduced
                  power dissipation, and smaller implementation...
                  11-05-2024, 03:10 PM
                • Fernon@Repair
                  Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
                  by Fernon@Repair
                  i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
                  VCCIO voltage ok
                  VCCSA Voltage OK
                  VCCPLL Voltage OK
                  Ram Voltage ok
                  RamVTT OK
                  VPP 2.5 OK
                  But No Core Voltage
                  and i want to this vrm ic datasheet or pinout (ISL69269)
                  anyone have this ic pinout voltages?...
                  06-25-2025, 07:19 AM
                  Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
                  by sam_sam_sam
                  I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
                  The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
                  Now...
                  06-09-2024, 10:57 AM
                • electron_jj
                  Panasonic TH-L42D25A checking the PSU output voltage
                  by electron_jj
                  Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
                  I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
                  08-29-2021, 08:13 AM
                • ruletero
                  Acer a515-43 low battery charge voltage
                  by ruletero
                  Hi
                  Acer A515-43
                  LA-H801P
                  Fail: Does not charge battery, has low voltaje on connector.
                  Laptop didn't want to turn on, only charge led blinked.
                  I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                  I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                  Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                  10-24-2022, 02:31 PM
