I am trying to determine what this inductor is. It was already removed from the board when it was brought in for repair, my guess to prevent the AC part of the circuit from operating, The main cap is also blown. The DC part of the board is still functioning. There is a second identical inductor on the board in mint condition. Not sure why this one failed but would like to replace it but not sure where to find.
Norcold DE-0061 AC/DC power supply inductor?
I am trying to determine what this inductor is. It was already removed from the board when it was brought in for repair, my guess to prevent the AC part of the circuit from operating, The main cap is also blown. The DC part of the board is still functioning. There is a second identical inductor on the board in mint condition. Not sure why this one failed but would like to replace it but not sure where to find.Tags: None -
Will re-post pics, not sure where they went. Went to Wurth website but I don't have any specs for this other than it's on the AC side of the board (120v) so not sure about a replacement. Not sure if those ID numbers help. Rep in the Wurth chat couldn't help.Last edited by repair-it; 07-23-2025, 09:57 AM.Comment
Assuming...7 Photos -
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by SoulzinkHi everyone,
I am trying to fix a samsung washinmachine power supply main board.
I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
The power supply board reference is the following: DC41-00189a
I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel... -
by NicktronicHey everyone,
This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
Anybody... - Loading...
