B&K 1760 Tripple PS has one bad side
  • Ltank
    • Jun 2013
    • 776
    Does anone have a Schematic? Tried to charge a battery and it screwed up one bank or side. The readout shows zero voltage and the constant current
    Par led stays lite up. The other adjustable and 5vdc are good.
    Schematic is greatly appreciated
  • Ltank
    • Jun 2013
    • 776
    Re: B&K 1760 Tripple PS has one bad side
    Opened unit and started checking simple things first. Found a shorted 1N5002 Diode.
    The bottom half is all rivited together. Not made to be serviuced. I was able to just reach it from the side. Put a 1n5008 and it works fine. Reassembled. Thanks Guys
      Service manual.
      • flibidy
        Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
        by flibidy
        I have here a Magnum IA.100 which belongs to my parents.
        The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
        Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
        What Ive done........
        01-01-2025, 01:26 PM
      • bouny56
        Lenovo E15 Nm-c421 usb-c work only in one side
        by bouny56
        ​Hello
        Laptop E15 I5 10gen
        Mb nm-c421
        I have a problem with the usb-c power dc.
        The motherboard start only in one side of the usb-c
        Replace the usb-c port 2 times same problem
        With the usb-c meter, one side 20v ok, other side the usb-c meter don't come on
        Try to test the pin with the Mechanic Tail insertion tester and every pin are ok ?
        Can the pd controler be the fault ? Or something else maybe ?
        Thx
        02-11-2025, 03:15 AM
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
      • Stephen
        A2442 MacBook Pro 14" Two Left SIDE USB C ports charge but no data
        by Stephen
        Right SIDE usb.c port charges and transfers data without issue, two left side uSB c ports charge but do not receive or see data. Was liquid damaged, and repaired significantly and thought we were in the clear but appears this is the last issue that is rearing its head. I am trying to locate the RETIMER chip that communicates the DATA TX/RX but I cannot seem to find it on the schematic or maybe I am just so tired my eyes wore out lol. Any help would be great.
        05-29-2025, 10:35 AM
      • dicky96
        Xilence XP600 600w ATX PSU - No PWM Controller on primary side - how does it work?
        by dicky96
        Hi guys
        I have a faulty Xilence ATX PSU here
        The fault basically is I have two short circuit power transistors on the primary side of the large SMPS transformer - they are 2SC3320.
        There is another smaller transistor on the primary side C3866 which tests ok
        The PSU has three transformers - it looks like the 2SC3320's drive the big one and the C3866 drives one of the small ones. There is a separate PFC PCB with it's own controller and MoSFETS
        There is also a short on the 3.3V output and a near short on 5V - I suspect this probably blew...
        05-11-2021, 07:55 AM
