B&K 1760 Tripple PS has one bad side
  • flibidy
    Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
    by flibidy
    I have here a Magnum IA.100 which belongs to my parents.
    The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
    Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
    What Ive done........
    01-01-2025, 01:26 PM
  • bouny56
    Lenovo E15 Nm-c421 usb-c work only in one side
    by bouny56
    ​Hello
    Laptop E15 I5 10gen
    Mb nm-c421
    I have a problem with the usb-c power dc.
    The motherboard start only in one side of the usb-c
    Replace the usb-c port 2 times same problem
    With the usb-c meter, one side 20v ok, other side the usb-c meter don't come on
    Try to test the pin with the Mechanic Tail insertion tester and every pin are ok ?
    Can the pd controler be the fault ? Or something else maybe ?
    Thx
    02-11-2025, 03:15 AM
  • howardc64
    by howardc64
    07-24-2025, 05:17 PM
  • Stephen
    A2442 MacBook Pro 14" Two Left SIDE USB C ports charge but no data
    by Stephen
    Right SIDE usb.c port charges and transfers data without issue, two left side uSB c ports charge but do not receive or see data. Was liquid damaged, and repaired significantly and thought we were in the clear but appears this is the last issue that is rearing its head. I am trying to locate the RETIMER chip that communicates the DATA TX/RX but I cannot seem to find it on the schematic or maybe I am just so tired my eyes wore out lol. Any help would be great.
    05-29-2025, 10:35 AM
  • JarzabekPZ
    DELL Latitude 5520 - charging only on one side of usb-c
    by JarzabekPZ
    DELL Latitude 5520
    MB: South Peak 15 MB (DDR4)
    Charging only on one side of usb-c on both ports. I have replaced one of the ports but still the same. Checked for short, nothing is getting hot under thermovision. Usb meter is not coming on one side, on the other is coming on and showing 20V.
    Any sugesstions where to look for fault?
    04-04-2025, 07:15 AM
