Bestec ATX-300-12Z 24>20pin - Pink wire
  • socketa
    Asbelowsoabove
    • Jun 2014
    • 662
    • samsara
    Decided to buy a half decent (well, at least, not bottom of the barrell) PSU.
    It's going onto a motherboard with only a 20-pin power socket.
    This bestec has a 24-pin plug that can not be seperated into a 20+4 pin.
    The plug wont fit into the socket because there are components in the way.
    I had unclipped (with the eye of a needle) and removed all of the pins from another 20+4 pin plug, and was going to transfer the bestec wires over into this empty plug, untill i noticed a pink wire doubled up with a red wire, on pin 23.
    I read, in another thread, that this is a sensor wire.
    If i replaced the wires to exaclty the same positions, then this pink wire (which would now be in the 4-pin plug) would wind up not being used.
    Is that OK?
    Or would it be preferable to swap this terminal (with the pink and red wire) with one of the other 5V terminals on the new 20-pin plug, so that the 5V rail is still regulated?
    If so, which one, and why?
    Or is this PSU only compatible with motherboards that have 24-pin sockets?
  • c_hegge
    • Sep 2009
    • 5219
    Re: Bestec ATX-300-12Z 24>20pin - Pink wire
    It would work fine. 24 pin is just 20 pin with another 4 pins added to the side. That extra wire is indeed just a sensor. many PSUs have that so that the secondary controller IC can see what the voltage is doing at the motherboard end.
    I would pop the cover on that PSU and check the capacitors in it, though. Bestecs do sometimes get bad caps (particularly on the 5vsb rail).
    • socketa
      Asbelowsoabove
      • Jun 2014
      • 662
      • samsara
      So wouldn't the PSU work better if the red/pink terminal was swapped with a red wire on the replacement 20-pin connector?
      Because, if the pink wire is not connected, then there is no information going to the sensor circuit/IC - so it can't adjust voltage requirements for the 5V rail.
      Wouldn't the PSU work better (or more efficiently) if it was getting some info back on the sensor wire?
      i.e., if this sensor wire was actually being utilized
      What does the 5V wire on the 4-pin connector supply voltage to?
      Is it sensible to swap the red/pink (both wires are crimped together on the same terminal) with a red one on the 20-pin connector,
      since, after moving the terminals from one connector to the other, it would otherwise wind up not being used?
      If so, which one should i swap it with? - i.e., i don't know what each 5v pin does on the motherboard connector,
      There would be 4 positions to choose from.
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        its +5 remote sense.
        just include it in your 20 pin mod and eliminate one of the others.
        oh and recap!
        • socketa
          Asbelowsoabove
          • Jun 2014
          • 662
          • samsara
          The caps look OK - although there is a component-type odor coming from it.
          Will test voltages after i get this plug sorted - want to make sure that the PSU working, before buying caps for it.
          Was just wondering why the sensor wire was on that particular pin - was it completely arbitrary?, or was there some reason for it?
          i.e., would have that being the pin that demanded the most power, like the CPU or one of the chipset processors?
          Just checked continuity of all the 5v positions on a 24-pin motherboard, and they all appear to be connected together.
          If they are all connected on a 5v rail on the motherboard, then what is the point of having 4 (in the case of 20-pin connector) or 5 (in the case of 24-pin connector) 5v wires coming from the PSU, instead of just one 5v wire?
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            It's the pin where you are likely to have the highest current draw, all pretty academic though.
            Just checked continuity of all the 5V positions on a 24-pin motherboard, and they all appear to be connected together.
            Yup, that's how they are made
            Because the pins in the ATX connector can only handle so much current, same goes for the wires.
            The reason the extra 4 pins where added was because otherwise you would get problems with burning or charring of the ATX connector, because too much current was going through the pins...
            • socketa
              Asbelowsoabove
              • Jun 2014
              • 662
              • samsara
              Thanks,
              The voltage drop/current rating of the wire did cross my mind.
              One more point to clear up:
              If all the 5v wires are all the same, and also connected together on the same rail on the motherboard, how can one wire have a greater current draw than the others.
              • chozo4
                Nothing Special
                • 134
                Thanks,
                That's actually the reason for the extra wires. Essentially all it's doing is dividing the current between the wires to keep within ATX wire gauge specifications and avoid heat buildup while reducing wire resistance. In turn it also reduces the effect of a voltage crop over the wires itself, again, due to less resistance as well. In this case one wire cannot draw more than the others unless the lengths or wire conditions (poorer solder joint, looser crimp on the connecting pin, etc) are slightly different but it's negligible at best due to less than an ohm resistance difference.
                Though, as an alternative one can do the math and simply decrease most of the common connected wires to a thicker gauge and remove the extra's altogether. The only issue then is the amount of current the connector pins can handle. As an alternative in THAT case would be to combine them into a single thick wire and at the plug end divide it into the smaller wires between the pins thus reducing overall wire clutter. All you lose then is wire flexibility overall however.
                Even crap caps can be useful... such as blank rounds for prop gunfights.
                • socketa
                  Asbelowsoabove
                  • Jun 2014
                  • 662
                  • samsara
                  Yep, i get that thanks
                  But what i dont get is this:
                  If there is multiple pins for red wires, and they are all connected together on the motherboard, then how can one have a higher current draw than any of the others?
                  The selection of which red wire to connect the sensor wire to would have to be completey abitrary, wouldn't it?
                    Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) Notebook 1 Specification for Upgrade or Repair
                    This specification for the Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) boardview and Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) schematic. Our users...
                    09-06-2024, 09:30 PM
                  • jimjoe123
                    LCD TV Green/Pink screen problem
                    by jimjoe123
                    I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
                    Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
                    Then each time...
                    02-23-2020, 01:29 AM
                  • wnlewis
                    New wire for my RDE3340 Whirlpool electric range
                    by wnlewis
                    OK. I got the rocker switch figured out thanks to the good advice on this forum.
                    Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
                    This is a Whirlpool RDE3340 electric range.
                    The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
                    Where may I find parts...
                    01-08-2025, 11:21 PM
                  • mikey5791
                    Tiny Tech ATX480W output power ticking
                    by mikey5791
                    Hi to all forum members,
                    ​​​​​​This psu (Tiny Tech model ATX 480W) had been installed in a very old Windows XP PC but recently i pulled it out as the pc cannot start. To test it, i jumped the green wire and black wire on the 24 pin connector. The psu fan jerk a bit but not spinning. I used my dmm to check dc voltage on output connector wire, the 5v red wire keeps ticking a bit at around dc1v....then drops and ticking again around 1v. It is the same situation with the 12v yellow wire.
                    Fyi, i desoldered the secondary side electrolytic cap those over 1000uf...
                    02-20-2025, 01:11 AM
                  • emeskay
                    Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
                    by emeskay
                    We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
                    08-06-2024, 07:13 AM
