bad caps on Antec Truepower 380s?
  • erdos
    • Jul 2012
    • 15
    i have a home built pc with Antec Sonata mid tower case that just died, it comes with a Antec Truepower 380w Power supply.
    when i turned on the PC power, immediately there was a loud noise coming from PC, like a fan hitting something hard, also the pc gave off a burning smell. afterwards pc went dead.
    i took out the Power supply and opened it up for a look. there are brown stuff everywhere, like something exploded inside. the two big capacitors also leaked at the bottom.
    can this unit still be fixed?
  • Sparkey55
    • Jan 2010
    • 1523
    Re: bad caps on Antec Truepower 380s?
    That yellow stuff is glue used to hold down the caps prior to solder bath.
    • mariushm
      • May 2011
      • 3799
      The yellow glue can become conductive, especially when it turns brownish. The glue may have shorted something.
      Clean it up and see what blew up and replace that and it should work.
        • 31246
        you need to clean all that brown glue off,
        and take some focussed foto's of all of the board - preferably including the underside.
        while your at it, use your finger to see if the fan blades still turn smoothly.
        • c_hegge
          • Sep 2009
          • 5219
          Yup, that's all glue. check the caps on the other side of the PSU, though. Those will almost definitely be bad if it's a few years old.
          • Stefan Payne
            • 1267
            There were 380W CWT Earthwatts??
            • c_hegge
              • Sep 2009
              • 5219
              No. This one is a Truepower, not an Earthwatts.
              • Pentium4
                CapXon Be Gone
                • Sep 2011
                • 3741
                Check ALL caps, even the small 1uF 50V caps I've seen fail. And check the snubber resistor on the primary behind the input caps, those run hot
                  by momaka
                  03-12-2025, 03:42 PM
                • eryjus
                  by eryjus
                  05-10-2023, 11:21 AM
                • ajdrenter
                  Picking caps for Antec SU-380
                  by ajdrenter
                  In my search for a proper 5v heavy ATX power supply, I selected an old Antec SU-380 that I've had in storage for a long time. Opening the power supply reveals a couple bulged capacitors. I removed all the caps and made a map for myself. I found the datasheet for the PCE TUR series in this thread:
                  https://www.badcaps.net/forum/showthread.php?t=14159
                  It says these are general purpose, so I assume I can replace them with any general purpose capacitors, but I don't really know anything about power supply circuits or reading capacitor datasheets. Despite this, I've been shopping for replacements:...
                  05-13-2023, 10:40 AM
                • Paxman_Swede
                  by Paxman_Swede
                  Hello!
                  01-14-2025, 09:51 AM
                • captain150
                  by captain150
                  03-16-2025, 07:34 PM
