Info. about PSU protections
This topic has been answered.
  • Danielsan315
    • Mar 2025
    • 5
    • Argentina
    Hi everyone, hope all of You are having a good day. I have a Question from protections in some of this PSU brands and models: Dell Optiplex series 745 to 380 to 390 to 7040 - HP EliteDesk series - And some new Lenovo minitower series. I don't know how to find info. about their protections [ OVP (Over voltage protection) - OCP (Over Current Portection) - OPP (Over power protection) - SCP (Short Circuit Protection) - short - OTP (Over temperature Protection)], some Internet's friend told me that Delta company buids to this brands, but not lists that information if that the client request that protections or not. In consecuence he told me that I must dissasembly the PSU and search for an specific chip to know what type of protection it has, if it has. If that the case: Can You tell me about what chip fo find? Thanks in advance and sorry for my bad English.
  • Answer selected by Danielsan315 at 03-03-2025, 04:03 PM.
    momaka
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Just about every (not completely trash) power supply has working SCP and OVP/UVP.
    Anything based on forward converter topology (many of those Dell and HP OEM PSUs) will have OPP on the primary.
    OCP may or may not be present, and maybe only on the 12V rail... but for the most part, these are relatively modern PSUs and DO have OCP usually.
    OTP is the only one that is not always included in the design. For that one, you do really need to open the PSU, look at the ICs inside, and also see how the thermistor for the temperature pickup is wired - it could only be used for speed control of the fan, or it could also be used for OTP + fan control.
    As far as manufacturers behind these OEM PSUs: Delta is not the sole manufacturer. Other ones are likely to be LiteON, HiPro/Chicony, AcBel, and maybe even Bestec and FSP.
    • CapLeaker
      Leaking Member
      • 8177
      Are you talking about the supervisor IC? something like a Weltrend 7525? A supervisor IC is to find on the secondary. It’s connected back to the primary via an optocoupler to the PWM. This way if something is off, the supervisor IC can shut the PSU down. If you look at one of my old threads about a PowerMan IP power supply, you can see how that thing works and how to override the supervisor IC and force the PSU to stay on. All you need to find is the FPOB (fault protection pin) and see if the state is high (5V) or low (0V). If the state of the pin is high the supervisor had shut the PWM down.
      • Danielsan315
        • Mar 2025
        • 5
        • Argentina
        Hi Cap! Thanks for reply back! Do You refer to this post??: https://www.badcaps.net/forum/troubl...-it-works-fine. I was searching in Your profile, and suscribed of course . So, if that IC is the cause about the protections I've mentioned before, then I have to dissasembly that PSUs and search for them. You gave me a lot of work! Thanks! . As I can see there aren't many info. about this topic arround the Internet. So if I find any useful I'll do a post.
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          • CapLeaker
            Leaking Member
            • 8177
            No… actually it is this one:
            https://www.badcaps.net/forum/troubl...300bn7-2-blown
            Most of the time you won’t find a perfect schematic. You just have to understand how the PSU and the power protection works. They are not all created equal.
            • Danielsan315
              • Mar 2025
              • 5
              • Argentina
              Hi Momaka!! Thanks a lot! That info really helped Me! It's possible that those PSU have OTP because I found temperature sensors inside. So probably to auto modify the fan speed. Thanks about the rest of the info. It's extremely useful for my purpose. Have a nice day!
              • Danielsan315
                • Mar 2025
                • 5
                • Argentina
                Hi Cap! Saved Your post! Thanks! I'll check later. Yeah, I know just because I worked in a informatic hardware house here, a briefly time and repaired almost 5 PSU without an schematic, was hard and I needed help, just because You need to test the components to fin which is broken. The info. in Internet is poor. There are only You and Your experience. Now I have some PSU's incomplete and broken, and I have the project in the future to reconstruct them.
                • Supradin
                  TEAC AG 980 going protection mode
                  by Supradin
                  Hi everyone. I'm new on this things, this is my first amplifier after I start offering repair service almost for free, just for learning purpouse
                  So I have a amp that is going to protection mode. I saw that if I remove the ribbon cable which sends from main board B+,B- and signal for amplifiers card, is not going to protection mode.
                  So, from that ribbon cable y disconnect everything but b+ b-, and amp goes again to protection mode. So my guess was something is wrong in the amp board.
                  I disconnect all transistors and amp is ok.
                  After, I connect the...
                  Electronics forum for electronics experts to repair defective appliance.
                  05-01-2024, 08:34 AM
                • waspie
                  Aiwa GX-770 Amplifier Protection Circuit
                  by waspie
                  I am by no means an expert on this type of troubleshooting but I can follow direction real well.
                  I'm no stranger to using a meter and soldering iron so I'm looking for some help in fixing an old amplifier/system I got. This is part of a system "V-1200" by Aiwa where there are several components. My first problem seems to be the amplifier.
                  It seems to be in protection. When first turned on I hear the inital relay coming on but never the second relay which is connected to the protection IC. I don't see any obvious bad components on the board. If I ground the...
                  11-29-2022, 09:58 AM
                • cook
                  Good brands of run capacitor for house heat hump
                  by cook
                  Are there good brands for 'run capacitors' or 'start capacitors' that are used on electric motors or heat pump compressors? ... r are the good capacitor brands for electronics (power supplies, laptops, motherboards, etc.) also the good brands for run capacitors?
                  Yeah I know this might be a novice question, but I just wanted to be sure. I did do a search on the forum but did not see this question asked before.
                  09-13-2024, 12:53 PM
                • acedogblast
                  [Marantz SR5012] Center channel keeps going into ASO/Overcurrent protection.
                  by acedogblast
                  First off I would like to thank this community as it has provided me with great information that has helped me greatly on my repair for this Marantz SR5012 AV receiver. I am creating this new thread as the other 2 that I have created here has had their original question/problem solved and I plan that this is the final thread on my repair. Please note that this is my first time repairing audio amplifiers so I may not be aware of common issues and things to know.
                  Lets start at what I have done so far. Random speaker popping on all channels is fixed by replacing the 2 large filter...
                  03-01-2023, 08:24 PM
                  Protection Pin Shutdown in PWM Controllers & LCD inverters
                  How to remove the protection of the inverter - several ways to protect shutdown in popular PWM controllers, LCD inverters.
                  When repair and diagnosis, it is often necessary to check the individual
                  inverter circuits - power converter lamps illuminate the LCD panel.
                  Carry out the necessary measurements is sometimes not possible, the
                  generation of breaks for various reasons, for example because of the
                  imbalance in the loads.
                  Together, artists and researches different options for the repair of
                  conferences were blocking inverter protection in order...
                  11-06-2024, 04:18 AM
