Protection Pin Shutdown in PWM Controllers & LCD inverters
    • 115471
    How to remove the protection of the inverter - several ways to protect shutdown in popular PWM controllers, LCD inverters.
    When repair and diagnosis, it is often necessary to check the individual
    inverter circuits - power converter lamps illuminate the LCD panel.
    Carry out the necessary measurements is sometimes not possible, the
    generation of breaks for various reasons, for example because of the
    imbalance in the loads.
    Together, artists and researches different options for the repair of
    conferences were blocking inverter protection in order to obtain
    diagnostic capabilities
    AT1741 , BA9741 , BD9211F , BD9215AFV , BD9222FV , BD9240 ,
    BD9261FP , BD9270F , BD9275F , BD9276EFV , BD9766VF , BD9777 ,
    BD9882F , BD9883 , BD9884VF , BD9896 , BD9897 , BD9897F , BD9897FS ,
    BI3101 , BIT3102A , BIT3102B , BIT3105 , BIT3193 , BIT3251 - BIT3252 ,
    BIT3713 , DDA009 , DT8211 , ILN816GN , INL837GL , FAN7311 , FAN7314 ,
    FAN7316 , FAN7547 , KH0803A , LX1691A , MAX8722 , MP1006 ,
    MP1007ES , MP10072E , MP1008 , MP1009 , MP1010 , MP1027EF ,
    MP1038 , MSC1692 , OB3302CP , OB3309 , OB3316QP , OB3328UQP ,
    OB3362RP , OZ5508G - OZ5508GN , OZ960 , OZ964 , OZ9643N , OZ971SN
    , OZ972GN , OZ9910GN , OZ9919GN , OZ99361 , OZ9938Q , OZ9939GN ,
    OZ9966SN , OZ9972 , OZ9976 , OZL68GN , OZT1060GN , SAQ8818 ,
    SEM2005 , SEM2006 , SEM2105 , SEM2107 , SP5001Q , SP5005 ,
    SS1091ASN , TA9687GN , TL1451 , UBA2070 , UBA2071AT , UBA2074​
  • Cardioman
    Toshiba 49L621U - Backlight protection shutdown
    by Cardioman
    Have common flash of Toshiba logo and backlight shutdown. Set uses power supply / LED driver bd. PK101W1230I. I Measured power supply to main board connector. (at power supply connector P802) and power supply LED driver connector to LEDS. (P803) All measured to chassis ground.
    At logo flash: All 16V lines (16V2, 16VA) = 16.8V & 16.2V, 5V1= 5.1V, ACD=3.34V, PWON= 4.05V, BLON= 3.35V, 5V1= 5.1V, DIM= 5.1V
    Two readings, one at power on, second at logo flash: -VLED 1, = 6V/ 34V, -VLED2 = 6.6V/37V, & -VLED3= 6.6V/ 37V. +VLED (3 COMMON WIRES) = 66V/101V
    Pulled PS led connector...
    08-29-2020, 08:19 AM
  • x_orange90_x
    Vizio E55-E1 bad backlights or bad inverter?
    by x_orange90_x
    I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
    I don't know how exactly to test the inverter itself. Is it...
    01-29-2025, 09:24 PM
  • kacangpolo
    Asus X415EA Auto start when shutdown ( Laptop cannot shutdown with baterai only )
    by kacangpolo
    I have problem with my laptop, with code board X415EA 2.0,
    laptop cannot shutdown with baterai only, if i plug the adaptor, laptop can shutdown, but when the adaptor was unplug, laptop wake up
    I did :
    1. Flash Bios
    2. RTC_RST 3.3V
    3. LID_SW 3.3V
    4. WLAN_WAKE# 3.3V
    08-26-2025, 04:42 AM
  • Supradin
    TEAC AG 980 going protection mode
    by Supradin
    Hi everyone. I'm new on this things, this is my first amplifier after I start offering repair service almost for free, just for learning purpouse
    So I have a amp that is going to protection mode. I saw that if I remove the ribbon cable which sends from main board B+,B- and signal for amplifiers card, is not going to protection mode.
    So, from that ribbon cable y disconnect everything but b+ b-, and amp goes again to protection mode. So my guess was something is wrong in the amp board.
    I disconnect all transistors and amp is ok.
    After, I connect the...
    Electronics forum for electronics experts to repair defective appliance.
    05-01-2024, 08:34 AM
  • Gentian
    APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
    by Gentian
    I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
    It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
    03-06-2023, 07:07 AM
