Delta PS Only 5vsb No Secondaries
  • mmartell
    • Oct 2013
    • 3189
    There is a V+ and V- as seen in one of the pics which I think is voltage across the main filter caps and that measures 330v when plugged in and doesn't change when I jump the pson pin to ground on main connector. When I DO jumper it there is a short "chirp".
    I've changed out nine bulged caps. Where tollook/measure now ?
  • Dgtech
    E. Technician
    • Apr 2009
    • 1462
    • Steeler
    Re: Delta PS Only 5vsb No Secondaries
    When you jumper the ps_on, do you momentarily jumper it or keep it jumpered solid?
    • mmartell
      • Oct 2013
      • 3189
      Uh oh. I keep it jumpered. Is it a momentary contact thing ?
      • Dgtech
        E. Technician
        • Apr 2009
        • 1462
        • Steeler
        No...you're good.
        • mmartell
          • Oct 2013
          • 3189
          I just read that some supplies are unhappy without a load so I will connect something to rule that out.
          • mmartell
            • Oct 2013
            • 3189
            Ok ruled it out, still no secondary voltages.
            Looks like I need some old fashioned troubleshooting tips please.
              • 31070
              check the rectifiers on the output side for shorts.
              • mmartell
                • Oct 2013
                • 3189
                The ones on the heatsink ?
                  • 31070
                  yes
                  • RJARRRPCGP
                    • Jul 2004
                    • 6304
                    Looks like a fake Delta PSU.
                    ASRock B550 PG Velocita
                    Ryzen 9 "Vermeer" 5900X
                    Arc A770 16 GB
                    eVGA Supernova G3 750W
                    Alienware AW3423DWF OLED
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 4974
                      • New Zealand
                      I agree.
                      -David VanHorn
                      • lti
                        • May 2011
                        • 2551
                        I wouldn't call it a fake. They only used the name and didn't make any attempt to make it look like a real Delta PSU.
                        The output toroid looks burnt.
                        • mmartell
                          • Oct 2013
                          • 3189
                          What is that ? Transformer ?
                          There is a short. Thought it was the rectifier diode ? (heatsinked) but it was a smaller fast recovery diode in front of it that was shorted. Replaced it and stupidly put it all back together THEN tested again. There is still a short between each outer pin and the center pin on one of the rectifiers (my meter reads it as 50 ohms) where the other two don't do that. That part tested good out of circuit so I pulled a couple of parts up in the vicinity and can't find a shorted part.
                          Is that a normal reading for that rectifier or is there a spot I should be checking given the shorted diode I did find ?
                          • linuxguru
                            • Apr 2005
                            • 1564
                            Did you check the rectifier out-of-circuit or in-circuit? In circuit, the bleeder resistor for the +5v rail may be around 50 ohms, so you won't be able to measure the rectifier accurately.
                            On +5Vsb, replace the secondary electrolytics (1 or 2, typically 1000uF/10V) as well as a small primary-side electrolytic (typically 22 or 47uF/50V) near the auxiliary trafo.
                            If it still doesn't start up, unsolder and check all large secondary rectifiers and replace any that are shorted. Then check the primary switching transistors.
                            • mmartell
                              • Oct 2013
                              • 3189
                              Checked it out of circuit and it checked fine. Are you saying that I SHOULD be seeing that 50ohms because I don't see it on the other two rectifiers maybe they don't have bleeder resistors ?
                              Is it possible to point out the bleeder resistor on one of the photos above ? I'd like to unsolder one of the legs to see if the short goes away. Thanks
                                • 31070
                                the load resistors are big ones mounted vertical near where all the wires come out usually.
                                • mmartell
                                  • Oct 2013
                                  • 3189
                                  Thanks stj, you nailed it. The resistor on the 5v rail traced directly back to the rectifier so I figured that would account for the measurements I was seeing. I put it back together and jumped pson and it came to life with all voltages. Only needed to replace one shorted FR153 diode.
                                  Thanks again!
                                  • Agent24
                                    I see dead caps
                                    • Oct 2007
                                    • 4974
                                    • New Zealand
                                    But why else would they call it "Delta" if not to try and fool people into thinking it was a real Delta? Probably hoping people who have never seen one close up would buy it thinking "I've heard Delta is good, so this must be a good PSU"
                                    Still shady behavior, IMHO.
                                    -David VanHorn
                                    • mmartell
                                      • Oct 2013
                                      • 3189
                                      I detected sarcasm in Iti's post meaning calling it a "fake" is an insult to counterfeits that try a little harder.
                                        master hoarder
                                        • May 2008
                                        • 12175
                                        • Bulgaria
                                        The "real" Delta is actually called Delta Electronics.
                                        So technically, this PSU is not a fake, but they used a similar name on purpose, of course. Just like all of those other crafty brand names on knockingoff.com.
                                        That aside, Delta PSUs are crappy. I wouldn't put one in any computer. I think newbie2 here on BCN upgraded one and still uses it. Thread should still be here. Just a bit old by now.
                                          MSI Delta DELTA 15 A5EFK-008 Notebook 15 Specification for Upgrade or Repair
                                          This specification for the MSI Delta DELTA 15 A5EFK-008 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the DELTA 15 A5EFK-008 boardview and DELTA 15 A5EFK-008 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 03:40 AM
                                        • Junkrepair
                                          Calculating ESR from tan delta -- tan delta's dependence on capacitance
                                          by Junkrepair
                                          I'm finally recapping my Soyo K7VX6 motherboard (aka KT600 Dragon Ultra) and replacing Sacon SZ-series caps. The Sacon SZ datasheet provides a spec for tan delta, but not for ESR, while the candidate replacement caps are specified in terms of ESR.
                                          I found this nice little description of the conversion:
                                          Calculating capacitor ESR from Tan(delta)
                                          https://forum.digikey.com/t/calculat...-from-tan/2633
                                          It mentions that a general spec for tan delta has to be adjusted for the specific capacitance before plugging tan delta into the formula...
                                          06-12-2023, 02:45 PM
                                          MSI Delta 15 A5EFK-081AU Notebook 15 Specification for Upgrade or Repair
                                          This specification for the MSI Delta 15 A5EFK-081AU Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15 A5EFK-081AU boardview and 15 A5EFK-081AU schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-07-2024, 06:11 AM
                                          MSI Delta 15 A5EFK-046UK Notebook 15 Specification for Upgrade or Repair
                                          This specification for the MSI Delta 15 A5EFK-046UK Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15 A5EFK-046UK boardview and 15 A5EFK-046UK schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-07-2024, 05:50 AM
                                          MSI Delta 15 A5EFK-088NL Notebook 15 Specification for Upgrade or Repair
                                          This specification for the MSI Delta 15 A5EFK-088NL Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15 A5EFK-088NL boardview and 15 A5EFK-088NL schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-07-2024, 04:30 AM
