Nucool TEC Fridge PSU acting up
  • coolin67
    • Jun 2014
    • 10
    Hi all. A while back one of the fans on my Haier Nucool c-rnu281vs was making noise, so I would unplug it at night to sleep. I have since replaced the fan, but turning the fridge on and off has created another problem.
    It now will turn on for ~6 hours, then stop running and making a clicking noise from the PSU, maybe once per second. If unplugged for a day or so, it will again run for a few hours and then stop again, with the same issue. I was hoping to be able to repair the board, but don't really know where to start. I have taken pictures of the board and will include those in the post.
    Let me know if any more information or pictures are needed.
    Thanks in advance to any help.
    Kevin
    • 31246
    Re: Nucool TEC Fridge PSU acting up
    look at the bottom of the board,
    one of the transistors bolted to a heatsink has soldering so bad that the center pin looks like it was never soldered at all!!!!
    look real close at ALL the soldering.
    • coolin67
      • Jun 2014
      • 10
      Are you talking about the hole next to c7? I don't think that there is supposed to be a leg soldered there.
      Or are you talking about the transistor near R35/R36, where sharpee lines are?
      When you say check soldering, do you mean check to make sure pins are sticking out? Here are some more pictures, hopefully of better quality.
      Thanks for the help!
        • 31246
        i mean look for cracked solder.
        • japlytic
          • Oct 2005
          • 2086
          I see a badly darkened polyester capacitor (used for current transfer) near two medium heatsinks.
          From what I see, this power supply is a variant of an "old-school" design (TL494, two primary switchers in push-pull configuration, an artificial centre-tap formed with two 200/250V primary electrolytics, and a large polyester unit connected between the artifical centre-tap and the transformer) used with many low cost computer power supplies.
          • coolin67
            • Jun 2014
            • 10
            @ japlytic Are you referring to C16?
            @stj thanks, just got a new soldering iron, will re solder all of the points
            Thanks guys.
            • japlytic
              • Oct 2005
              • 2086
              Yes, this is the capacitor I am talking about.
              • coolin67
                • Jun 2014
                • 10
                So you would replace that? Any idea what a good replacement would be? Not sure if the numbers are visible any longer.
                  master hoarder
                  • May 2008
                  • 12175
                  • Bulgaria
                  It's probably a 1 uF, 400 V, 5% (if it has 105J written on it, it probably is). Check what yours says, though.
                  Here's a compatible one if it is 1 uF:
                  http://www.mouser.com/ProductDetail/...bpto1kSWtZk%3d
                  (part # ECW-FA2J105J)
                  I picked a 630V one, just in case. It will be a bit bigger, but that's good - can dissipate a bit more heat.
                  I also second stj's suggestion to check all the solder joints. If any of them look rough, cloudy, or appear to have a fracture "ring" around the component's leads, then re-solder them. A 40W iron and 60/40 solder with rosin flux core should work nicely for this.
                  • MegaZAC
                    Onkyo TX-SR805 noise in one channel
                    by MegaZAC
                    Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                    Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                    There's some logic behind it. As soon as I select an input I get only left...
                    04-23-2025, 10:09 PM
                  • mikey5791
                    Help repair Panasonic fridge not cooling
                    by mikey5791
                    Hi all forum members,
                    Few days ago, i might have forgotten to close my home fridge freezer door completely. The next day, the ice cubes and frozen meat almost melted halfway and the freezer doesn't feel cool. I shut it off, wipe dry and let it air dry for one whole day. The next day i switched on the fridge, the compressor run for a second and it shuts off(no vibration and no sound at all) only the internal freezer compartment fan is running but is not cooling even i switched on a full day.
                    After shut off, i dismantle the rear water pan holder and reached to the compressor wiring....
                    07-16-2025, 02:01 AM
                  • karatzdi
                    Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                    by karatzdi
                    I know some might say... just buy another one. Sell it as parts..!
                    So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                    Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                    Spent some time downloading the Service...
                    06-11-2024, 08:38 AM
                  • x_orange90_x
                    Seven Leagues Slot Machine stop button issues
                    by x_orange90_x
                    I don't know if anyone here has experience with Japanese slot (pachislo) machines, but I sure hope so. I bought this machine last week in semi-working order. It would play and the reels would spin, but the stop buttons would not stop them at all. I found that the high-frequency filtering tantalum capacitor was bad on the reel stop board, along with the fuse being blown. I replaced the fuse and removed the capacitor. I haven't replaced the cap yet because I didn't have one on hand, but it's not necessary for the operation of the machine.
                    The issue now is the Stop buttons are intermittently...
                    02-12-2025, 10:01 AM
                  • tony359
                    by tony359
                    11-28-2023, 05:18 AM
