Psu makes PC hibernate? Is it possible?
+ More Options
Posts
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    Is it possible that a power supply can send a signal at the motherboard and make Windows 7 Ultimate enter hibernate mode?
    Pc shuts down while running 3DMark05 and Super Pi benchnmarks, but when I boot back into Windows7 Super PI resumes and 3DMark shows a message that it was interrupted.
  • t.j.
    • Apr 2010
    • 383
    • canada
    Re: Psu makes PC hibernate? Is it possible?
    there is an advanced hibernation setting you have to change, an do you have all other power savings features off?
    • goodpsusearch
      • Oct 2009
      • 2850
      • Greece
      I just turned off every energy saving settings I found in windows7 control panel. But, I thought that when running a full screen benchmark such as 3DMark, it would prevent Computer from entering standby/hibernation...
      • RJARRRPCGP
        • Jul 2004
        • 6304
        Sounds like the video just stopped, likely because of an unstable GPU core.....
        The 3D Mark error message description sounds like an unstable GPU core OC.
        It sounds more like the Windows video driver stopped and recovered. You may or may not see an error message on the bottom right about the display driver not responding. It don't sound like it went to hibernation.
        ASRock B550 PG Velocita
        Ryzen 9 "Vermeer" 5900X
        Arc A770 16 GB
        eVGA Supernova G3 750W
        Alienware AW3423DWF OLED
        • goodpsusearch
          • Oct 2009
          • 2850
          • Greece
          But all the fans stopped moving...
          • RJARRRPCGP
            • Jul 2004
            • 6304
            I dunno why.....
            Arc A770 16 GB
              master hoarder
              • May 2008
              • 12175
              As far as I know, no.
              You only have the PS-ON and PG signals. PS-ON is controlled by the motherboard and not the PSU, so PSU can't cause a motherboard to go to sleep from there.
              With PG, however, I'm not sure what a lack of that signal will do when motherboard is running. I somehow think it shouldn't affect the PC operation either once the PC is running, but I don't know for sure. Maybe try it on a spare "junk" motherboard and see.
              I highly doubt that's the problem.
              When the GPU trips, the system won't go in sleep. Either hard reset, blue screen, or back to desktop if you are lucky. Usually you get looping audio too when it happens.
              • goodpsusearch
                • Oct 2009
                • 2850
                • Greece
                Mystery solved!
                It seems that 3DMark05 couldn't prevent Windows7 from entering standby.
                The OS was Windows 7 fresh install and the default power management settings set the PC to enter standby after 30 minutes...
                The power supply is ok and has been returned to customer.
                  • 31063
                  that's stupid,
                  power management should only be on by default in laptops.
                  typical ms crap-coding!
                  • Ed Herdman
                    • Apr 2014
                    • 31
                    Nah, probably this prevents many goobers from burning through hundreds of dollars of power (per machine) each year. Multiply that by however many people leave their PCs running full tilt for no reason...
                      • 31063
                      but most desktops these days are checking mail & stuff as background tasks!
                      • jean luc ferre
                        upgrading windows7 to windows10 on an old laptop toshiba satellite m40 331 allways in error
                        by jean luc ferre
                        on this old laptop toshiba satellite m40 331 i am trying (but failing) to upgrade frow w7 to w10 and allways i have the error : 0xc1900101 - 0c20017. The upgrading process stops with the pc blocked with the logo screen w10 on the display; then there is no activity on the disk hdd or ssd.
                        it's also impossible to boot from a dvd iso bootable, the device equally blocks on the w10 logo screen...
                        i verified the informations in the device manager and it seems there are no problems...
                        i wonder if it's not an issue about the bios (which is very old) or an interface problem...
                        05-27-2025, 07:13 AM
                      • ugamazing
                        Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                        by ugamazing
                        I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                        We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                        12-17-2024, 07:05 PM
                      • bociub
                        laptop freezes, usb 2.0 not working, usb 3.0 working
                        by bociub
                        Hi there,
                        It is sunday and I got a faulty hp pavilion 15-cs1006na. No available schematics on the entire world. It flashed 5 long 4 short and no post then I discovered the usb 2.0 2. pin in one of the usb-a socket bent backwards and been shorted to 2. and 3. pin of the 3.0. after removing this short in the port the laptop came alive.
                        Now the laptop freezing randomly. The webcam, the built in mic and according to the device manager one more thing not working which are connected to usb. If I connect anything what have usb 2.0 plug that wont work if i plug anything what...
                        08-25-2024, 03:44 PM
                      • edugimeno
                        HP envy i7 laptop won't boot
                        by edugimeno
                        Hi there!
                        i have owned this laptop for at least 10 years but It's still way powerful as I bought a little above my required specs, so it was working like the first day and it had all In needed.
                        Then suddenly today, this happened
                        • It was on battery (too aged) anew went to hibernate due to low bat
                        • I plugged the power supply to it and clicked the power button to de-hibernate it
                        • It came back up but was irresponsive to keyboard or mouse and the mouse flickered to all black every 4 or 5 seconds and then back
                        • I had to forcedly turn it off holding the power button for some time
                        • After
                        01-23-2024, 08:14 AM
                      • Ju.salem
                        Black screen. Need bios for hp 250 g10
                        by Ju.salem
                        I put the device into hibernate mode, and after turning it back on, it didn't work. The screen remains black, and the power button blinks as if it's still in sleep mode. I removed the battery and tried turning it on with the charger only, but nothing changed. The power button just keeps blinking like it's in sleep mode repeatedly.
                        I need a BIOS file.
                        Hp 250 G10
                        Sn: 5CD512HH34
                        Motherboard: DA0PDIMB8G0
                        Yesterday, 12:45 PM
