Another one psu with only +5vsb output
  • stefos
    • May 2012
    • 91
    • Greece
    Hello guys.
    Looks like +5vsb output only is very common problem with atx psu.
    First I had replaced three 10uf at 50v caps on primary side as esr was high. I give a try with light bulp and psu power on for 5 seconds all outputs and then shutdown. After then in every test I am getting only +5vsb.
    As this psu is quite similar to previous fixed model, I changed the inductor coil but the problem did not fixed.
    I have already made some voltages measurements at diodes, caps with esr, rectifiers etc.
    Voltages at PS_ON state are:
    KA7500C
    1: 2.7 mv
    2: 4.868v v
    3: 105.3 mv
    4: 6.9 mv (3.369v on PS switching OFF)
    5: 1.642 v
    6: 3.620 v
    7: 0.8 mv
    8: 1.485 v
    9: 0.8 mv
    10: 0.8 mv
    11: 1.478 v
    12: 12.07 v
    13: 5.023v
    14: 5.023v
    15: 5.023v
    16: 08.mv
    LM339N
    1: 3.844 v
    2: 133.7 mv
    3: 5.024v
    4: 1.358 v
    5: 502.mv
    6: 1.4 mv
    7: 2.687 v
    8: 0.852 v
    9: 105.4 mv
    10: 2.208v
    11: 115.5 mv
    12: 0.7 mv
    13: 2.8 mv
    14: 2.8 mv
    OPTO volatges (PS_ON state)
    pin 1: 3.923 v
    pin 2: 2.783 v
    T2 transformer voltages (PS_ON state)
    pin 1: 4.688 v
    pin 2: 4.686 v
    pin 3: 4.703 v
    a) Green color at PS_ON state does not have any voltages, but on switching off state has 5.018 v
    In image 387 marked the points I have already checked.
    Can you please guide me what else can I check?
    Thanks a lot.
  • Escort Eagle
    • Jul 2012
    • 110
    Re: Another one psu with only +5vsb output
    What is the voltage in PIN 4, 8, 11 & 12 of KA7500C IC in Off_State ? Also needed Voltage of T2 Transformer's PIN 1, 2, 3 in Off_State .
    Also need a clear Picture of Image 387 without Text .
    • c_hegge
      • Sep 2009
      • 5219
      That PSU looks like it runs seriously hot. Note the discolouration on the PCB. Did this PSU previously have its fan fail?
      • PeteS in CA
        • Aug 2005
        • 3581
        • USA, Unsure of Planet
        450W? Maybe 250W, with those heatsinks, that main transformer, those input rectifiers and that inrush-limiting thermistor.
        PeteS in CA
        • senz_90
          • Aug 2013
          • 328
          • Indonesia
          Every PSUs with this 2 IC is very very common in 250W from my experience. those are cheap Chinese products that labeling 450W sh*t on their case.
          For stefos.
          It looks like your ground cable on mains transformer(the big one) is really bad burned. I would checks it If I were you. congrats on your repaired previously. I likes people with never give up attitude.
          sometimes you will found there is one that post a thread and just WAIT for answer without effort likes make a voltage measurement, what he have checked and done.
          "There is no shortcut to be successful. No pain, no gain."
          Best Regards
          Rudi
          Thank You
          • stefos
            • May 2012
            • 91
            • Greece
            Hello friend.
            I measured KA7500C IC voltages in Off_State and got:
            pin 4: 3.367v
            pin 8: 2.239v
            pin 11: 12.36v
            pin 12: 5.024v
            also on T2 transformer pins (1, 2, 3) got 1.490v
            Thanks !!!
            • stefos
              • May 2012
              • 91
              • Greece
              Hi !!!
              When i got the psu from a friend of mine was full of dust. Perhaps, the fan wasn't working well and at the time passed, appeared this discolouration on the PCB.
              • stefos
                • May 2012
                • 91
                • Greece
                For stefos.
                Dear senz_90 thank you very much for your kindness.
                I have one more same type main transformer and if needed i can change it. If it was faulty, it wouldn't faill the T2 transformer too (no voltages at all).
                Stay cool !!!
                • stefos
                  • May 2012
                  • 91
                  • Greece
                  Hmm....If i short pin 4 with pin 11 of KA7500C psu works with light bulp showing no shorts.
                  • Escort Eagle
                    • Jul 2012
                    • 110
                    Are you shorting PIN 4 With PIN 11 or PIN 4 with Ground ??
                    • stefos
                      • May 2012
                      • 91
                      • Greece
                      I forgot to mention that found a broken sata cable and replace it. While i was looking at 7500c circuit, short pin 4 and 11 instead of GRD (test inputs) and psu worked. I remove the short and now psu still works. Tried with hd load and seems to be ok. I don't understand what happen but seems psu is ok.
                      • Escort Eagle
                        • Jul 2012
                        • 110
                        Hahahahaha ................. Very Interesting !! I have no idea what happened !! I am shocked too ..... !!
                        • goodpsusearch
                          • Oct 2009
                          • 2850
                          • Greece
                          wtf!
                          • senz_90
                            • Aug 2013
                            • 328
                            • Indonesia
                            Maybe just a cold solder joint around the IC and you accidentally add a new solder and it works !!
                            Best Regards
                            Rudi
                            Thank You
                            • scottsman76
                              Samsung UA40D5000PR Pulsing output voltages
                              by scottsman76
                              Hi Guys
                              I Have this Samsung smart tv that needs repair.
                              with everything connected i get pulsing A5V at the PSU connector. if i unplug the main board then all voltages pulse on the output connector.
                              I dont get any voltage on the LED connector.
                              there is also an audible click around the mosfet marked below
                              The connector to the Buttons all voltages pulse (3v)
                              I have searched and found a similar problem but there was a stable 14v, but was also not repaired.
                              I checked and replaced the mosfets with no effect.
                              Any ideas where...
                              03-30-2023, 10:33 AM
                            • Joekhoe
                              Sharp Aquos Quattron LC-52LE835X Totally Dead, no output voltages
                              by Joekhoe
                              Hello all, I'm Joekhoe, a newbie here and ask your masters permissions and solutions for the problem i'm facing at the present.
                              I am in the middle of working on a SHARP Smart TV model LC-52LE835X from my customer, which totally dead and there's no output voltages at all at the output pins even though i have replace some of the components the output voltages remain the same with 0 volt.
                              The replacement as follows:
                              1. IC7905 : TNY264PN (first found exploded)
                              2. Q7915 : BT169D (exploded too)
                              3. IC7901 : 1608B (controller ic)
                              4. IC7601 :...
                              09-17-2020, 05:52 AM
                            • organman
                              Sharp LC-60LE633U Inverter output voltages
                              by organman
                              Greetings, I have a Sharp LC-60LE633U when powered up only the V light comes on. I have checked the LED strips and they all light up. When the LED's are plugged into the PS board I get an output voltage of 74v DC. If I unplug the LED's the output voltage on the PS is 184v DC. Does this indicate a weak PS?
                              Thanks...
                              03-22-2023, 06:47 PM
                            • organman
                              Sharp LV-60LE633U inverter output voltages
                              by organman
                              03-13-2023, 06:48 PM
                              KingWin ABT-650MM 650 Watt ATX PSU [PCB: SW8835REV:A]
                              by momaka
                              For today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
                              http://www.rmac.kingwin.com/products.../abt_650MM.asp
                              I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
                              What mostly drew me into buying it is its 2x PCI-E power connectors...
                              03-29-2022, 11:34 PM
