Hello guys.
Looks like +5vsb output only is very common problem with atx psu.
First I had replaced three 10uf at 50v caps on primary side as esr was high. I give a try with light bulp and psu power on for 5 seconds all outputs and then shutdown. After then in every test I am getting only +5vsb.
As this psu is quite similar to previous fixed model, I changed the inductor coil but the problem did not fixed.
I have already made some voltages measurements at diodes, caps with esr, rectifiers etc.
Voltages at PS_ON state are:
KA7500C
1: 2.7 mv
2: 4.868v v
3: 105.3 mv
4: 6.9 mv (3.369v on PS switching OFF)
5: 1.642 v
6: 3.620 v
7: 0.8 mv
8: 1.485 v
9: 0.8 mv
10: 0.8 mv
11: 1.478 v
12: 12.07 v
13: 5.023v
14: 5.023v
15: 5.023v
16: 08.mv
LM339N
1: 3.844 v
2: 133.7 mv
3: 5.024v
4: 1.358 v
5: 502.mv
6: 1.4 mv
7: 2.687 v
8: 0.852 v
9: 105.4 mv
10: 2.208v
11: 115.5 mv
12: 0.7 mv
13: 2.8 mv
14: 2.8 mv
OPTO volatges (PS_ON state)
pin 1: 3.923 v
pin 2: 2.783 v
T2 transformer voltages (PS_ON state)
pin 1: 4.688 v
pin 2: 4.686 v
pin 3: 4.703 v
a) Green color at PS_ON state does not have any voltages, but on switching off state has 5.018 v
In image 387 marked the points I have already checked.
Can you please guide me what else can I check?
Thanks a lot.
KA7500C
1: 2.7 mv
2: 4.868v v
3: 105.3 mv
5: 1.642 v
6: 3.620 v
7: 0.8 mv
8: 1.485 v
9: 0.8 mv
10: 0.8 mv
11: 1.478 v
12: 12.07 v
13: 5.023v
14: 5.023v
15: 5.023v
16: 08.mv
LM339N
1: 3.844 v
2: 133.7 mv
3: 5.024v
4: 1.358 v
5: 502.mv
6: 1.4 mv
7: 2.687 v
8: 0.852 v
9: 105.4 mv
10: 2.208v
11: 115.5 mv
12: 0.7 mv
13: 2.8 mv
14: 2.8 mv
pin 1: 3.923 v
pin 2: 2.783 v
pin 1: 4.688 v
pin 2: 4.686 v
pin 3: 4.703 v
Thanks a lot.
