Periodically problems in PSU type: Antec SP350 P
  • Hurup
    Hurup the Dane
    • Mar 2014
    • 11
    • Denmark
    Hello I have some periodically problems in my old PSU type: Antec SP350 P
    I have made following measuring on the PSU when it's operating the computer.
    All the results of voltage measuring are placed in the centre of the specification except the – 12 volt.
    The -12volt are measured to -11,45volt some times little higher -11,55volt.
    In the Specification for SP350 P following detail is shown: -12volt +-5% (-11,40 – 12,60)
    I have observed that the Power good signal pin 8 some time changes to 0 and the CPU stop running. The -12 voltage is then measured to -11,40volt, so safety circuit in the PSU is well working.
    My question is:
    How do I adjust the voltage, it‘s fixed, so I think it is one or two defective capacitors, but witch one?
    Can someone give a solution?
    Mvh
    Hurup
  • mockingbird
    • Dec 2008
    • 5484
    Re: Periodically problems in PSU type: Antec SP350 P
    This PSU will need a full capacitor replacement.
    In order to do so, you'll need to remove the PSU cover and then unscrew the PSB from the chassis. Then you can desolder the live and neutral wires going from the socket to the PCB as well as the two thin switch wires. Once you have the PCB free from the chassis, you can start to desolder -all- the capacitors and document their properties in the following format:
    Code:
    Voltage, Capacity, Width * Height (In mm), Brand, Series
    So, for example:
    16V 3300uF, 10x30, Fuhjyyu "TN"
    • Hurup
      Hurup the Dane
      • Mar 2014
      • 11
      • Denmark
      Thank you for response.
      I don’t understand why you will change all the electrolytic capacitors!
      As I wrote, the supply voltage: -5v, +5v, +3,3v, +12v, st.by 5v are measured to be very fine. The values are in the centre of the specifications, you have +-5% safety. All measuring on running computer!
      It’s only the -12v that gives the periodically problem and shut down the PSU (pin 8 goes low) when the -12v degrease to -11,40v equal to (-12v -5% = -11,40v).
      Specification: -12v +- 5%, 0,3a
      When the computer is operating I can measure -12v voltage switching around -11,50v.
      Now I have removed the electrolytic capacitor mounted in the output for -12v.
      The type is: manufacture is Teapo 330 micro 16v.
      I have suspect to this electrolytic capacitor; maybe the problem is the ESR that is too high?
      As I can conclude all the switching and safety system running well! I can’t see any physically change of the electrolytic capacitor as you normally can in Samsung, LG television and screens.
      Specifically about PSU for computer I am beginner, but have 40 years experience in electronics.
      Regards
      Hurup
      • cheapie
        null
        • Jul 2010
        • 849
        Because this particular power supply is known to kill all of them eventually. If you just replace the one, you'll be back in there eventually to replace more.
        Besides, just because the voltage is in spec doesn't mean that the ripple/noise is.
        • goodpsusearch
          • Oct 2009
          • 2850
          • Greece
          Those Antec power supplies combine a terrible capacitor selection and a fan controller circuit that keeps the psu insanely hot.
          I always do a full recap AND a fan mod to keep the new caps cooler.
          • c_hegge
            • Sep 2009
            • 5219
            Yup. Replace every single cap, including all of the small <100uF caps. My usual way to deal with the fan controller is to add a 2.4K or 2.5K resistor in parallel with the fan control thermistor. I usually replace the front fan on them too, since I often find them with stuck front fans.
            • mockingbird
              • Dec 2008
              • 5484
              No need to replace the fans when they can be refurbished... Just peel off the sticker, remove the rubber cover, take out the spring clip and lift it from the sleeve. Then clean the shaft and sleeve with some acetone and a q-tip... Mix some PTFE bearing grease with your favorite thinning oil (This step can be omitted, but the PTFE grease alone will slow down the fan slightly) and apply liberally with a toothpick.
              Regarding your fan MOD, I didn't end up doing it because my system is only getting some 200W of power draw if even that... And the fan does kick in by itself eventually without the mod. I'm afraid that with the mod, the fan will stay on even after the system turns off. Is this the case?
              • c_hegge
                • Sep 2009
                • 5219
                You can do that with the rear one, but the 10mm front fan has no rubber plug, so any lubricant you put in just leaks out and the fan quits again.
                For the fan to stay running after the PC is off, it has to have special circuitry to power the fan from the 5vsb, which the SP series lack altogether. Adding the resistor in parallel with the thermistor just means that both fans stay running whenever the PSU is on, and that they ramp up sooner. 200W power draw will get an SP-350 quite toasty.
                • mockingbird
                  • Dec 2008
                  • 5484
                  Ok thanks. No, I've got the SP-450... Then PTFE bearing grease is good for those fans without the rubber plug. The stuff is pretty viscous and will not leak out. All you need to do is seal the hole with good electrical tape so that no dust gets into the sleeve.
                  • Hurup
                    Hurup the Dane
                    • Mar 2014
                    • 11
                    • Denmark
                    Thank you to all for the feedbacks.
                    I am very surprised at the quick and useful response.
                    With regard to change all the capacitors, I acknowledge that it may be necessary.
                    For ripple voltage level, I have had an oscilloscope in order to control and it showed very small and acceptable levels of ripple.
                    I have changed the 330mikro capacitor, but still have the problem on the -12v supply.
                    Subsequently, I found that the -12v supply is not used in the computer as there is no com port installed.
                    My periodic problem might be bugs, cold soldering on the safety circuit for good voltage pin 8.
                    The voltage at pin 8 switches suddenly short from 4.3 V to 0 and back then the computer resets and reboots.
                    This error can be triggered by mechanically affect the box with the power supply but I don’t checked it yet.
                    I will modify the fan control as described, thank you!
                    Regards
                    Hurup
                      master hoarder
                      • May 2008
                      • 12175
                      • Bulgaria
                      I have serviced plenty of truly "non-serviceable" fans like that before (and by that, I mean not just fans that didn't have a rubber plug, but also fans where I had to actually drill a hole through their back to get to the c-clip that holds the rotor shaft). Never had problems with them, though - at least with the good ones. The key is to clean the sleeve bearing very well. If you use a small screw driver or something that is slightly abrasive and small enough to fit in the bearing, you then make scratches and "channels" parallel to the shaft direction. Then clean with paper towel and lubricate. Those scratches will make the bearing retain the oil a lot longer. If the fan was very "stuck" when you found it, the bearing might be quite worn. In such cases, I also rotate the fan 90 degrees when I install it back in the PSU. If the PSU is to go back in the same orientation that it was before (which, for most cases where the PSU is on to is, PCB in PSU is upside down).
                      Yes. Any PSU with "average" efficiency will get toasty. Think about it. If the PSU is 80% efficient, that means you'll be dissipating 20W for every 100W of power draw from the wall. So for 200W from the wall, you have about 40W (mostly) dissipated by the heatsinks. With a very slow fan, they could reach some hot temperatures.
                      • jean luc ferre
                        laptop hp g72 b52sf screen problems
                        by jean luc ferre
                        on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                        the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                        i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                        i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                        06-07-2025, 03:27 PM
                      • Hondaman
                        USB problems?
                        by Hondaman
                        Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
                        (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
                        I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
                        08-12-2024, 03:26 PM
                      • clabr
                        Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
                        by clabr
                        Need help to solve some problems with this laptop.
                        After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
                        After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
                        Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
                        Before this had happened I observed some other problems:
                        When I tried replacing original mecanical HDD with a SSD HDD could not get them...
                        12-02-2021, 08:09 AM
                      • jean luc ferre
                        display screen problems after changing motherboard
                        by jean luc ferre
                        First on my laptop i had a motherboard with a pentium 6100 processor. Installing w11 i was blocked on the 23h2 version...impossibility to upgrade toward 24h2 because the SSE4.2 functionnality of the cpu was missing. About displaying and screen looking all was perfect.
                        I changed of motherboard with an intel I3 processor...and now i don't find the previous aspects of the displaying.
                        Now i have a veiled screen and pixels are missing though the graphics parameters have not changed.
                        Desinstalling and reloading the drivers in the same time on the graphic card (intel hd...
                        09-11-2025, 10:28 AM
                      • rumpumpel1
                        Lenovo X13-Yoga Gen 1: hibernation problems
                        by rumpumpel1
                        I have a Lenovo X13-Yoga Gen 1 that has problems with hibernation mode. When the laptop goes to hibernation mode - either via the start menu or after a time-out - after a short period of activity where the power-on LED flashes, the power consumption should go down to almost 0 and the LED should go out. Most of the time, however, the power consumption indicates further CPU activity and the power LED remains on, but there is no image. Sometimes the CPU activity stops after a few minutes, sometimes not at all. If the laptop enters this state, it can only be brought back to life by a long press on...
                        11-03-2024, 12:31 AM
