LC Power Arkangel with bad caps
  • Half-Saint
    • Jan 2010
    • 213
    • Slovenia
    I was just given a pretty beefy modular LC Power Arkangel power supply rated at 800W. It seemed worth trying to repair so I took it to the office, opened it up and sure enough, found a bad 2200uF 10V cap. The caps in the PSU are all Samxon (green). Looks like not even Samxons are immune to the plague!
    I was thinking of replacing the cap with a Rubycon ZLJ series cap as that's currently available: http://uk.farnell.com/rubycon/10zlj2...46?Ntt=2346446
    Should I replace the rest of the caps as well? There are some 2200uF 16V around ATX connector wires, haven't identified the rest but all the other caps look fine (except the aforementioned 2200uF 10V cap).
    It's going to be a bi*ch getting the PCB out of the case as it's all horribly cramped up.
    What do you guys think?
  • Agent24
    I see dead caps
    • Oct 2007
    • 4952
    • New Zealand
    Re: LC Power Arkangel with bad caps
    Is it a Samxon GF? Those are known to be crappy. If they are all the same series\crap brand, replace the lot.
    It's best if you find the series of the original capacitor, lookup the datasheet, and then you know ESR (Equivalent series resistance) and RCR (Ripple current rating). Find something that matches with same or lower ESR and same or higher RCR. Don't get a replacement with ESR that's too low or you may upset the circuit stability and cause more problems.
    -David VanHorn
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      moved to the proper forum..
      do post pictures before you buy parts.lc stuff is notoriously junky.it would suck to buy good parts for a unit that belongs in the trash.
      • mockingbird
        • Dec 2008
        • 5484
        Get these instead:
        http://uk.farnell.com/panasonic/eeuf...rad/dp/1744922
        • Half-Saint
          • Jan 2010
          • 213
          • Slovenia
          I'll take some pictures tomorrow and post them. Thanks for your willing to help
          • Half-Saint
            • Jan 2010
            • 213
            • Slovenia
            Added some pics. The bad cap is indeed Samxon GF.
            Trash or not?
            EDIT: Never in my entire life have I seen such shitty soldering...
            EDIT #2: The cap in question is a GF(M) X5A
            • 999999999
              • Sep 2006
              • 774
              Trash or not?
              There are some with much, much worse soldering than that. Mainly it looks like you need a high wattage iron to reflow the solder on the wiring harness locations.
              It looks worth a recap to me but it all depends on the value of a spare PSU vs time and parts cost. It's a fairly inefficient design that I wouldn't trust past 500W load if that.
              • Half-Saint
                • Jan 2010
                • 213
                • Slovenia
                I got it for free so I guess it's worth repairing - the caps aren't exactly expensive.
                • c_hegge
                  • Sep 2009
                  • 5219
                  That's actually a decent power supply. I had the same thing happen to an almost identical PSU (A Thermaltake ToughPower 750W). In my case, it took the board out, but if you care to recap it, it would be a decent power supply.
                  EDIT: As stated by Half-Saint, I agree that's actually quite good soldering for a CWT-built unit. I've seen much worse from them.
                  • Half-Saint
                    • Jan 2010
                    • 213
                    • Slovenia
                    I've been looking at data sheets and you typically get Impedance and Ripple Current. What exactly should I be looking for in a replacement cap? Would having identical or near identical values for those two be enough?
                    I don't like seeing huge blobs of solder. I already reworked one of the smaller blobs so that they're not connecting anymore. Having a max. of 450C solder probably isn't helping but the rest are going to be quite difficult to do.
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      • Romania
                      Match ESR and impedance as close as possible, ripple current same or higher.
                      A working TV? How boring!
                      • Half-Saint
                        • Jan 2010
                        • 213
                        • Slovenia
                        The trouble is, I can't find ESR as such on any data sheets...
                        • mariushm
                          • May 2011
                          • 3799
                          Impedance is almost the same as ESR at high frequencies, so you can use that Impedance @ 100kHz column.
                          • goodpsusearch
                            • Oct 2009
                            • 2850
                            • Greece
                            I have a psu identical to yours. The problem seems to be the same too:
                            https://www.badcaps.net/forum/showthread.php?p=428448
                            • Half-Saint
                              • Jan 2010
                              • 213
                              • Slovenia
                              I'll try finding some replacements from Panasonic later today.. when I have a bit more time to deal with this.
                              • Half-Saint
                                • Jan 2010
                                • 213
                                • Slovenia
                                Argh, data overload!!! Can someone help me with this? Can't find a suitable Panasonic replacement cap for that Samxon GF 10x20 2200uF 10V. Everything I look at, has different Impedance/Ripple Current values...
                                UPDATE: ok, after reading some general recommendations on the net I came to the following conclusions...
                                1) voltage rating can be higher than that of the original cap
                                2) Impedance should be equal or lower
                                3) Ripple Current should be equal or higher
                                This brings me to the conclusion that I can use the cap mockingbird already suggested to replace all of the 2200uF 16V and 10V caps. Can someone confirm that this cap is also suitable: http://uk.farnell.com/panasonic/eeuf...-me-pd-r2-alte
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 4952
                                  • New Zealand
                                  Looks fine to me for replacing the 16v ones (same size) But note it is a larger diameter, and taller than the 10v size. Check to ensure it will actually fit. Other than that it should be OK.
                                  Also, it doesn't *have* to be a Panasonic. There are several other brands which will work, eg: Nichicon, UCC, Rubycon.
                                  -David VanHorn
                                  • mockingbird
                                    • Dec 2008
                                    • 5484
                                    Probably not... The reason I listed that specific cap is because that is the only suitable cap for the application in 10mm width... The cap you listed is 12.5mm and may not fit properly.
                                    • Half-Saint
                                      • Jan 2010
                                      • 213
                                      • Slovenia
                                      I think I'm gonna order Panasonic FC series caps for this recap. Should be good enough.
                                      • c_hegge
                                        • Sep 2009
                                        • 5219
                                        In terms of electrical performance, they will be fine. However, there will probably be some 3300uF 10V/6.3V and 2200uF 16V caps in 10mm diameter, in which case you will need to use FK series, as it's a tight enough squeeze even with 10mm caps. 12.5mm FCs will be darn near impossible to squeeze in there.
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • eryjus
                                          by eryjus
                                          05-10-2023, 11:21 AM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • bcstedt
                                          LG 42LB5D, 42LB5DF-UL, 2008-01, Power On Issue, Replaced PS Caps
                                          by bcstedt
                                          LG 42LB5D (42LB5DF-UL) from 2008-01, unit is in good shape and no obvious heat damage or cracked solder on the boards.
                                          Problem:
                                          On first power-up the power LED flashes green about 18x and then stays solid. No backlight or image is present. Click power button, wait 10s for a click and the LED turns red. Wait 1-2s and hit power again and maybe it'll power up fully after 6 green flashes. If it doesn't light up on the sixth flash then the cycle repeats.
                                          It seems that if the mainboard power is left on for a few minutes (solid green power, no backlight, no image)...
                                          01-18-2024, 01:03 PM
