Welder not turning on - Learning
  • Olles4
    • Apr 2022
    • 63
    • Slovakia
    Is it better to put higher or lower value resistor on R209 and R207 ? I mean which way is safer.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8090
      That's the problem. Them 2 resistors I am not so sure of what there was in there, I went after the carnage trying to identify what was there first place. Some were really easy to identify, others not so. The thing here is to go through example circuits that are similar to yours and see what they used. Pull up some datasheets from the PWM from different manufacturers and compare. Sometime you know the resistor code started with a 1 and ended in a zero for example. So far R207 and R209 I haven't come up with anything too good uet.
      R207 ended with xx01. So a 1001 = 1k ohm. Sounds plausible and should work.
      R209 got not a clue. Cording to your schematic, it is a gate drive resistor to a different MOSFET. Knowing that it should be something less than 100 Ohm. Don’t forget there are already 22Ohms in line.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8090
        Oyyy, made a mistake yesterday, R209 goes to the Source, not to the gate. It’s a current sense resistor. So 1 v is the max here. As soon as the CS pin goes above 1V there is current limiting / cut off. Thinking about this, the resistance must be quite high. Higher than 1k Ohms. More like something 10k or 100k Ohms. Can you check the capacitance of C204?
        • Olles4
          • Apr 2022
          • 63
          • Slovakia
          Oyyy, made a mistake yesterday, R209 goes to the Source, not to the gate. It's a current sense resistor. So 1 v is the max here. As soon as the CS pin goes above 1V there is current limiting / cut off. Thinking about this, the resistance must be quite high. Higher than 1k Ohms. More like something 10k or 100k Ohms. Can you check the capacitance of C204?
          Update:
          Here is some photos of the main board. Im trying to remove the big heatsinks right now to see what is under them.
          • Olles4
            • Apr 2022
            • 63
            • Slovakia
            Heatsinks and fans out here are some more photos.
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8090
              What a pain that is! Looks like it has some bad solder joints too.
              • Olles4
                • Apr 2022
                • 63
                • Slovakia
                #27
                Which one?
                  • Jul 2011
                  • 6033
                  Some soldering joints do not look so good especially the lager pin components if it were me doing this I would re-solder those joints for good measure
                  • CapLeaker
                    Leaking Member
                    • Dec 2014
                    • 8090
                    The biggest problem with an inverter welder is not continuity like voltage, it's more current based like. The circuit has to be able to carry the current. I do remember a case not too long ago, where one of the problems was burnt track on the PCB that made continuity but couldn't carry any load.
                    So what was your “incident”? I don't see anything blown up (yet)?
                    • Olles4
                      • Apr 2022
                      • 63
                      • Slovakia
                      #30
                      Nothing blown up just one of the heatsink was under voltage so it shocked me.. but it’s connected to diode which’s base is connected to the line.
                      I understand that but the problem is it didn’t even turns on.
                      • CapLeaker
                        Leaking Member
                        • Dec 2014
                        • 8090
                        Show me what heatsink and what diode. The welder may not turn on if the low voltage supply isn’t working.
                        • Olles4
                          • Apr 2022
                          • 63
                          • Slovakia
                          #32
                          Heatsink connected to this row of components.
                          4x STTH12R06D
                          2x 1H18AF
                          • Olles4
                            • Apr 2022
                            • 63
                            • Slovakia
                            #33
                            So this is the front lcd panel with potentiometers and welding style adjustments with a small pcb it’s connected with 2 cables to the main board
                            • Olles4
                              • Apr 2022
                              • 63
                              • Slovakia
                              #34
                              These are the 2 connectors. So I assume the small board next to it what we were fixing it’s part of the supply.
                              • CapLeaker
                                Leaking Member
                                • Dec 2014
                                • 8090
                                4x STTH12R06D
                                2x 1H18AF
                                The 2 IGBT’s are FGH60N60’s. If they are blown, there is plenty to be had.
                                • CapLeaker
                                  Leaking Member
                                  • Dec 2014
                                  • 8090
                                  So this is the front lcd panel with potentiometers and welding style adjustments with a small pcb it's connected with 2 cables to the main board
                                  I was pretty sure that front LCD panel works of that board, but I guess not. Or does it loop just through that main board, but the power comes from the little board?
                                  • Olles4
                                    • Apr 2022
                                    • 63
                                    • Slovakia
                                    #37
                                    These two are bridge rectifier’s am I right ?
                                    • CapLeaker
                                      Leaking Member
                                      • Dec 2014
                                      • 8090
                                      yes
                                      • Olles4
                                        • Apr 2022
                                        • 63
                                        • Slovakia
                                        #39
                                        yes
                                        Hello. I have done some measurings. So on the small board the IC UC3843 pin6 (output to gate) is only 0,7mV and it seems like it didn't want to drive the mosfet
                                        How much Volts should i get on mosfet Drain and Source ?
                                        here is a link to ic UC3843BN datasheet(1/15 Pages) STMICROELECTRONICS | HIGH PERFORMANCE CURRENT MODE PWM CONTROLLER (alldatasheet.com)
                                        • Olles4
                                          • Apr 2022
                                          • 63
                                          • Slovakia
                                          #40
                                          c209 is jumpy but its something around 17 nanoF
                                          • spleenharvester
                                            Reverse engineering of DoCreate DHJ567 handheld spot welder
                                            by spleenharvester
                                            Hello everyone
                                            I attach a schematic and teardown photos for the DoCreate DHJ567 handheld spot welder. I bought this welder for temporary use while my supercapacitor welder was waiting for replacement parts. It cost only £24, though there is a screenless version available for £17.
                                            Performance: The absolute maximum it can handle appears to be 0.15mm of pure nickel. Reliability was not great - welds were very inconsistent, ranging from weak attachment to burning through the strip. However, I was able to build a 5S2P pack without losing any cells. It's a bit difficult getting...
                                            05-08-2025, 02:52 PM
                                          • Olles4
                                            Sencor SLE 40F82M4 - not turning on - Learning
                                            by Olles4
                                            Hello people. I trying to repair my Sencor TV. No standby light, not tuning on what i found there is 6V where 12V should be and 8V where 16V should be. Any suggestion?
                                            05-18-2024, 01:40 PM
                                          • tibimakai
                                            Lincoln Electric LE31MP welder not turning on
                                            by tibimakai
                                            This is my own welder, that blew up while welding. There is no warranty on it. Purchased it a year ago, sealed box from Craigslist.
                                            It worked great until now, about a year.
                                            What I have found is a blown trace next to the main capacitors, it seems like also got damaged the SMPS IC, output MOSFET and a 1 Ohm resistor to the ground from the MOSFET.
                                            After replacing these components, the relay, fans turn on and it sounds like it's working, but there is no output voltage for the welder, LEDs do not turn on.
                                            So there are more components that are damaged.
                                            I'm having a hard...
                                            10-14-2023, 07:40 PM
                                          • nicktasios
                                            Macintosh Quadra 840AV PSU
                                            by nicktasios
                                            I had my Quadra 840AV (which I recapped and had working) plugged in for some time without using it and randomly decided to turn it on today. Unfortunately it did not turn on. After checking the PSU, I found out I was not getting anything from 12V, only from the 5V rail. After a few minutes, I removed the PSU and plugged it back in the electrical outlet and it suddenly started making a weird sound and soon after smoke started coming out. I quickly unplugged it. I opened it up but on first instance I didn't see anything out of the ordinary really. I later turned it back on and one of the MOVs blew...
                                            12-22-2024, 05:07 AM
                                          • drscoot
                                            HP X360 convertible battery blown fuse error, not charging
                                            by drscoot
                                            HP Modelnumber: 14-dh0061nb​
                                            This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
                                            The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
                                            I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
                                            And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
                                            All these 3 batteries are charging...
                                            12-15-2023, 05:54 AM
