Linkworld LPH6-250W innovations...
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    I have already posted about this power supply here:
    https://www.badcaps.net/forum/showth...250W#post99122
    Its parts are decent and I am quite confident it can do the label ratings.
    But some days ago I opened it to check the caps and I noticed something strange:
    https://www.badcaps.net/forum/attach...1&d=1389923108
    The yellow cables of the ATX 12V connector are not directly connected to the PCB, but there is a large resistor in series with them! That resistor rating is 0.1ohm. Why did they do that???
    But wait. There is more! If you can't find the supervisor IC in the photos, well it's because there isn't one! Does this mean that the psu has no protections at all??? Is it possible that it doesn't even have a short circuit protection?
    Btw is there a chance that they put the resistor as over-current protection for CPU-12V?
  • c_hegge
    • Sep 2009
    • 5219
    Re: Linkworld LPH6-250W innovations...
    With no supervisor IC, the thing wouldn't work. It's in the same place it usually is on half bridge PSUs (although it may use one combo IC, rather than two separate ICs). As for the resistor, I have no idea why that would be there. maybe they were just trying to compensate for bad 12V voltage regulation?
    • goodpsusearch
      • Oct 2009
      • 2850
      • Greece
      There is KA7500B. Usually there is also LM339 or WT7510 or other but there is none here.
      • Pentium4
        CapXon Be Gone
        • Sep 2011
        • 3741
        A Linkworld with a varistor, input filtering, bridge rectifier, and good sized PI filter on the 12V? That's a rare species right there! I guess Linkworld was better back in 2001. And all the CS caps look "fine" I wonder if they're still in spec. I'd go as far to say that they're even better than Fuckyou's
        As for the resistor, I have no idea! I have never seen that before.
        It's not uncommon to see old half bridge units with just one IC for the entire unit.
        • TELVM
          • Oct 2012
          • 547
          • Spain
          Also one of the secondary PI coils seems to lack its core .
          • goodpsusearch
            • Oct 2009
            • 2850
            • Greece
            This is not rare:
            https://www.badcaps.net/forum/showth...8282#post98282
            • lti
              • May 2011
              • 2558
              Maybe they wanted to limit the current so the CPU won't draw too much power from their crappy PSU.
              It could work without the supervisor chip. They can always fake all the signals it produces so it stays running until something goes . Just connect the gray wire to +5V and make sure the controller is always running.
              • goodpsusearch
                • Oct 2009
                • 2850
                • Greece
                Wonderful! I removed the resistor and reoiled the fan...
                  master hoarder
                  • May 2008
                  • 12175
                  • Bulgaria
                  I can only think of two reasons:
                  1) Limit the current that can be drawn by the 12V rail - most probably meant for large transient currents that may trip the under-voltage protection (if there is even one) or short circuit protection. If that's the case, this screams CRAPPY FEEDBACK LOOP DESIGN!
                  2) Reduce ripple going to the motherboard. The resistor and the CPU VRM high-side capacitors on the motherboard form an RC low-pass filter, thus greatly reducing any ripple that may be coming from the PSU. This allows the PSU to be more "sloppy" with the ripple output.
                  Funny how they gave the 12V rail a rating of 10A. At 10A, this 0.1 Ohm resistor would have dissipated R*I^2 = 0.1 * 10^2 = 10 Watts! Even at 5A, that's still 2.5 Watts. NOT GOOD!
                  I doubt there are no protections. Even the most cheap and dirty PSUs have short circuit protection. OVP and UVP.... maybe.
                  The protection(s) are probably implemented in a discrete manner with TO-92 transistors. Not unusual on old half-bridge designs that have only a 494 or 7500 secondary-side PWM controller and nothing else.
                  • goodpsusearch
                    • Oct 2009
                    • 2850
                    • Greece
                    You are right. That resistor got really hot during operation! The glue they used that made the resistor contact with nearby capacitors didn't help either!
                    When measuring 12V from molex connectors or 20pin mb connector I got 12.5-12.8V. At the same time the ATX12V connector gave me 11.2-11.4V. This is really bad.
                    • jinu_j
                      by jinu_j
                      Hi
                      05-03-2025, 10:51 PM
                    • mikey5791
                      Need help to replace burned resistor in 350w atx psu
                      by mikey5791
                      Hi to all forum members,
                      Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                      The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                      Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                      Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                      12-26-2024, 04:55 AM
                    • MidnightRoller
                      Can a resistor lose resistance after hot air?
                      by MidnightRoller
                      I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                      I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                      02-02-2022, 11:46 PM
                    • artvandalai
                      What resistor ohm will work better to repair this waterpik?
                      by artvandalai
                      The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                      01-05-2025, 04:10 PM
                    • chth96
                      Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
                      by chth96
                      I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
                      Since then, This AC/DC adaptor have been out of order.
                      But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
                      After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
                      And Is there any possibility that it will suddenly explode as well as to be out...
                      12-03-2023, 04:40 AM
