Power amplifier SMPS IGBT keeps blowing - Artcoustic PDA1000
  • mikkele86
    • Apr 2017
    • 78
    • Danmark
    hello.
    I have two power amplifiers, both having their IGBT blown on the PSU.
    The original mounted IGBT where marked with IRGB20B60PD1PbF and the gate driver is a IR2156STRPBF.
    I looked at mouser and digikey and could not find any available IRGB20B60PD1PbF and somehow ended up using a Bourns BIDW20N60T.
    I replaced the gate driver, the gate resistor and both IGBT. But as soon power is turned on, both IGBT shorts out completely (gate, emitter, collector) and the fuse on the AC line gets killed.
    So I though i missed a capacitor or diode. I removed allmost every component between the bridge rectifier and trafo. compared them to a new component, didnt find anything of interest..
    anyways i decided to replace the gate driver (again) , snubber, diodes and some SMD caps.
    installed a new set of BIDW20N60T and the same thing happend again, both IGBT dead instant.
    I removed the IGBT and measured the DC voltage coming from the bridge rect. 323v stable.
    So im wondering if the BIDW20N60T was a bad choice ? maybe I should have used a IKP20N65H5 instead ?
    Tips to what to look for or check is appreciated
    I have attached my homemade schematic and some pictures.
    Schematic_Artcoustic PDA1000_2024-01-06.pdf
    my tools for measurement
    FLUKE 123 20MHz scopemeter.
    LCR meter DE-5000
    Original IGBT and parts.
    Click image for larger version  Name:	20231021_153645.jpg Views:	9 Size:	560.4 KB ID:	3173891
    Parts removed and SMD caps checked.
    Click image for larger version  Name:	20231123_184341.jpg Views:	10 Size:	517.2 KB ID:	3173892
    Rectifier and Caps checked.
    Click image for larger version  Name:	20231125_194955.jpg Views:	10 Size:	736.0 KB ID:	3173888
    • 30931
    what drives the gate driver?
    i dont see a psu chip in the pictures - on the underside?
    • mikkele86
      • Apr 2017
      • 78
      • Danmark
      thought i attached at PDF schematic, but its gone. i will try again with the schematic.
      But the Gate driver is the only IC on the board, nothing on th back
        • 30931
        do you have a component tester that can check caps for esr and leakage?
        • mikkele86
          • Apr 2017
          • 78
          • Danmark
          I have my DE-5000 LCR meter, i can measure ESR and capacity but not leakage.
          • CapLeaker
            Leaking Member
            • 7985
            I don't think your Bourns IGBT is a good replacement. The gate emitter threshold voltage is off, the rise and fall times are off. It's like the Bourns is too slow and it needs more gate emitter voltage than the original one.
            Compare IRGB20B60PD1 to IKP20N65H5​ and that to your BIDW20N60T.
            You can get the IKP20N65H5 from Mouser... they have a few in stock.
              • 30931
              it's a shit design, if some of those film caps go leaky the igbt's can short each other
              • mikkele86
                • Apr 2017
                • 78
                • Danmark
                Thanks for pointing that out CapsLeaker.
                there is a huge difference in rise and fall times.
                IRBG20B60PD
Name:	IRBG20B60PD rise fall time.jpg
                Bournes
Name:	Bournes rise fall time.jpg
                IKP20N65H5
Name:	IKP20N65H5 rise fall time.jpg
                Some measurement on C14 and C15 cap.
                Looks good to me.
ID:	3174310 Click image for larger version
                • CapLeaker
                  Leaking Member
                  • 7985
                  I thought about these 2 film caps as well. I would build a incandescent lamp in series trick to limit the current going to the PSU, so you don't blow up parts all the time. Then I'd assemble this PSU but leave the IGBT's out and check the gate drive. Install the right IGBT's and see what happens.
                  See how close the original IRBG20B60PD​ is to the IKP20N65H5? The BIDW20N60T has similar values in most categories, but is much slower that the original. While the IGBT turns on all right, it may be too slow turning off (so it kind of behaves like a stuck on gate drive). The gate voltage is off too...
                  • mikkele86
                    • Apr 2017
                    • 78
                    • Danmark
                    will try a incandescent lamp in series.
                    I got a 40W, will it do the trick ?
                    • petehall347
                      • Jan 2015
                      • 4423
                      • United Kingdom
                      that is LED
                      • mikkele86
                        mikkele86 commented
                        Editing a comment
                        dang it. your right. need to go shopping then
                    • CapLeaker
                      Leaking Member
                      • 7985
                      No. It has to be an old style incandescent light bulb, not a CFL or LED strings like this one you pictured. I use 60w, 100w and 150w bulbs, depending on how much I want to limit the current. Start with 100w.
                      • mikkele86
                        • Apr 2017
                        • 78
                        • Danmark
                        got it. just made ordre online, couldnt find any local retailer which had old style incandescent light bulb.
                        ill will post again when things are ready
                        • Francesc V.
                          Tempus fugit
                          • Nov 2022
                          • 221
                          • Catalonia
                          I hope not to say something stupid, but:
                          If you would have an osciloscope, without installing the IGBTs, you could check gate signal..........and see if both signals are well synchronised. Before burning them again an again..... :-)
                            • 30931
                            Click image for larger version  Name:	20240107_161014.jpg Views:	22 Size:	823.1 KB ID:	3174413
                            i have been waiting for almost a year for somebody to post that!
                            it's not 40w anyway - it's gonna be 2w or 4w with that number of led-strips
                            • mikkele86
                              • Apr 2017
                              • 78
                              • Danmark
                              Got the bulbs. used the 100watt, lights up for split sec.
                              Everything seems to be running without the IGBTs
                              I have taken some measurements, with COM/negativ from the oscilloscope to the COM on the PCB (pin 8 on gate driver)
                              hope its done right 😅
                              HO and LO gate at the same time.
                              HO - pin 13 channel A (upper)
                              LO - pin 11 channel B (lower)
Name:	HO + LO gate.jpg
                              CPH - pin 7 on gate driver
                              RT - pin 4 on gate driver
                              CT - pin 6 on gate driver
                              • CapLeaker
                                Leaking Member
                                • 7985
                                The first pic that shows HO and LO, I only see one channel B and nothing much on channel A. That's not right. Also check the gate drive resistors.
                                • mikkele86
                                  • Apr 2017
                                  • 78
                                  • Danmark
                                  Measured the gate resistor, 15ohm as stated. Path from Gate Pin on the IC to the pad where IGBT gate is, is also fine.
                                  I did some reading on the gate driver and I think the driver is in a UVLO state. Under Voltage Lock-Out.
                                  Im measuring +10.5v on the VCC pin on the IC.
                                  Im measuring +4.5v on the SD (shutdown) pin
                                  I did reach the Start up treshold VCCUV+ on VCC at +10.5v
                                  I dont think we would see a pulse on HO before we enter a preheat stage
                                  • CapLeaker
                                    Leaking Member
                                    • 7985
                                    O,k, that is squared off now. I guess it’s time to put in the new correct IGBT’s and fire it up using the light bulb trick. The light should come on for a blip and go out. As more current you draw, the light bulb should get brighter and stay on.
                                    If you turn the PSU on and the light bulb shines bright there is something wrong.
                                    • mikkele86
                                      • Apr 2017
                                      • 78
                                      • Danmark
                                      its alive 🤩
                                      thanks for the inputs
                                      • Sik_6ty_Sixx
                                        HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
                                        by Sik_6ty_Sixx
                                        So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
                                        02-18-2025, 05:06 AM
                                      • dkneyle
                                        Onkyo DX-V500 Laser Disc Player - weird SMPS fault
                                        by dkneyle
                                        This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
                                        Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS...
                                        02-01-2022, 02:08 AM
                                      • Lvsitano
                                        Asus X532FL 3.2V at source and gate
                                        by Lvsitano
                                        I am having some trouble with troubleshooting a Asus X532FL rev 2.0 motherboard, which does not power on. So at the first MOSFET, I am getting 19V at the drain, and then 3.2V on both gate and source (compared with ground). Of course, the 2nd MOSFET's source will have 3.2v at source.
                                        First MOSFET is a QM3056M6 and 2nd MOSFET is a QM0930M3
                                        I already checked first MOSFET and source and gate are not shorted (drain with source not shorted either). Also I have 1.7V at the LDO rail (measured at the keyboard connector, as the power button is on the keyboard).
                                        First...
                                        06-26-2024, 02:13 PM
                                      • Dan the Dog
                                        SMD Diode S3 marked on package
                                        by Dan the Dog
                                        I need to find a replacement for this diode on one of the six gate drivers of a full-bridge IGBT inverter for a servo motor. It has S3 on the package. How can I find out for sure the right diode that I need. I believe it is schottky because it has 0.2V drop across.
                                        The anode is on pin Ve and cathode on pin DESAT on 316J gate driver IC. Also would be nice if anyone had an idea of the purpose it is serving as it is not included in the suggested schematic of the 316J datasheet.
                                        I have also drawn a partial schematic of the gate driver in this servo amplifier to try...
                                        05-26-2024, 09:45 AM
                                      • MrCommunistGen
                                        Polk Audio RTi100 Plate Amplifier won't power on and intermittently honks and buzzes
                                        by MrCommunistGen
                                        My childhood best friend was killed about 9 years ago. His parents are finally letting go of his things, and they offered me his Polk RTi100 tower speakers. The Polk RTi100 towers are one of a handful of designs from the early 2000s that is a full range 3-way tower with a built-in self-powered subwoofer. This is accomplished with a plate amp integrated into the speaker input panel.
                                        I think they used them for a while, but they've been sitting for at least a few years now. After about 40 hours of driving to their house and back (both they and I have moved in the last 9 years) I got...
                                        07-12-2021, 05:11 PM
