Power amplifier SMPS IGBT keeps blowing - Artcoustic PDA1000
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8340
    That’s much better! Good job!
    • Francesc V.
      Tempus fugit
      • Nov 2022
      • 231
      • Catalonia
      That's real satisfaction. :-)
      • Sik_6ty_Sixx
        HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
        by Sik_6ty_Sixx
        So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
        02-18-2025, 05:06 AM
      • Lvsitano
        Asus X532FL 3.2V at source and gate
        by Lvsitano
        I am having some trouble with troubleshooting a Asus X532FL rev 2.0 motherboard, which does not power on. So at the first MOSFET, I am getting 19V at the drain, and then 3.2V on both gate and source (compared with ground). Of course, the 2nd MOSFET's source will have 3.2v at source.
        First MOSFET is a QM3056M6 and 2nd MOSFET is a QM0930M3
        I already checked first MOSFET and source and gate are not shorted (drain with source not shorted either). Also I have 1.7V at the LDO rail (measured at the keyboard connector, as the power button is on the keyboard).
        First...
        06-26-2024, 02:13 PM
      • dkneyle
        Onkyo DX-V500 Laser Disc Player - weird SMPS fault
        by dkneyle
        This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
        Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS...
        02-01-2022, 02:08 AM
      • shamsudeen
        Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
        by shamsudeen
        Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
        I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
        i know that in linear power supply the noise will be very low comparing to SMPS supply....
        07-19-2025, 07:14 AM
      • Dan the Dog
        SMD Diode S3 marked on package
        by Dan the Dog
        I need to find a replacement for this diode on one of the six gate drivers of a full-bridge IGBT inverter for a servo motor. It has S3 on the package. How can I find out for sure the right diode that I need. I believe it is schottky because it has 0.2V drop across.
        The anode is on pin Ve and cathode on pin DESAT on 316J gate driver IC. Also would be nice if anyone had an idea of the purpose it is serving as it is not included in the suggested schematic of the 316J datasheet.
        I have also drawn a partial schematic of the gate driver in this servo amplifier to try...
        05-26-2024, 09:45 AM
