Problem: PSU does not allow pc to start
Testing: Fuse checked fine, primary startup cap fine, ~330v on the primary cap, psu tester does not register anything at all. Apart from the primary voltage I am getting 5.05v at the PS-ON (green lead) and the same at the 5VSB (dark blue lead). None of the other 3.3v or 12v rails have any voltage.
Question: I can't see anything that appears burnt, cracked or smells bad, the caps (teapo) which I know are poor are not bulged and test good on esr meter. Can you suggest where I can test next? ...also can anyone identify the manufacturer of this unit so I can check for a schematic.
Half of the computer problems is caused by bad contacts
