what fuckery is this!?
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    look at these bricks, how have they not killed the HDD they power yet? can i replace them with this powerman PSU because its only 300w rated and it actually has input filtering?
    Follow the white rabbit.
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: what fuckery is this!?
    A power supply should only care about noise passed to its secondary circuit.
    Noise it generates itself that passes upstream...well it's not its problem. Some of these devices' parts are small enough that it won't generate that much noise to pass upstream (low impedance loads and long extension wires connected on the same circuit tend to low pass filter the noise anyway), so they omit these parts...
    As the chicken hatchling goes... Cheep cheep cheep...
    I still think the half bridge cell phone chargers are the more worrisome PSUs... Have enough of them, and it would cause some power factor annoyance...
    • lti
      • May 2011
      • 2550
      I think the output filtering is a bigger problem.
      Look at how the output devices are mounted to the heatsink.
      • Behemot
        • 4845
        • CZ
        Well, if it was fan-cooled, at least the airflow would be nice. It's not really crowded inside
        • goontron
          5000!
          • Dec 2011
          • 4108
          • US
          so can i use the powerman PSU instead of this fuckery? and the bricks turn into a cookery when running!
          • Behemot
            • 4845
            • CZ
            If you want to carry that thing with you…
            • dmill89
              • Dec 2011
              • 2534
              Yes, as long as the pin-out is correct, you'll have to jumper the ATX connector on or wire in a switch. Granted using a 300w ATX PSU to run a drive or two that might draw 5W ea. is a little overkill, but if you don't have any other use for it, it might not be a bad option.
              • goontron
                5000!
                • Dec 2011
                • 4108
                • US
                its about the size of both bricks, and how many more drives can it run
                do you think i might need a 5v minimum load resistor?
                • Behemot
                  • 4845
                  • CZ
                  I have the feeling hard drives consume something on +5 V. The question is what the efficiency will be and how the ripple will look.
                  • goontron
                    5000!
                    • Dec 2011
                    • 4108
                    • US
                    i know hard drives use about 150mA on 5v and the rest is 12v, so the ripple might be high on the 5v rail and for the efficiency, well, its probably more efficient than my zenith 12 valve valve radio set
                    • Pentium4
                      CapXon Be Gone
                      • Sep 2011
                      • 3741
                      if you're using 2.5" drives, those only use 5V
                      • goontron
                        5000!
                        • Dec 2011
                        • 4108
                        • US
                        it will run laptop drives (blue-ray and HDD) and desktop drives (iomega ZIP, dvd, and HDD). i have noticed that my quantum BIGFOOT HDD didn't like those bricks
                        here is one of the adapters (the adapters are good not the bricks)
                        http://www.microcenter.com/product/2...to_USB_Adapter
                        yay 701 posts
                        • goontron
                          5000!
                          • Dec 2011
                          • 4108
                          • US
                          here is the second adapter http://www.microcenter.com/product/3...E-SATA_Adapter
                          and here is the pics of the adaption. you might notice that i kept the power-good wire, im not sure what to do with that
                          • Behemot
                            • 4845
                            • CZ
                            Stick it wherever you want That's just signal for MoBo that everything is OK and it is safe for it to turn on.
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8701
                              This reminds me of something.
                              A long time ago I tried using an IBM AT PSU (yes the real one) in this manner to power hard drives. It's even easier for these AT PSUs because you don't need to ground the green pin to turn it on.
                              First thing that happened when I tried the HDD?
                              Fried the HDD. Magic smoke leaked out.
                              Then I noticed the minimum load needed and it was fairly hefty.
                              *sigh*
                              • Behemot
                                • 4845
                                • CZ
                                Must have been some crap, I have pretty old Enlight Corporation PSU, I say pretty good for an AT, I've run so much stuff on that without any extra load…just turn it on, tha's all I need to do…
                                • kaboom
                                  "Oh, Grouchy!"
                                  • Jan 2011
                                  • 2507
                                  *sigh*
                                  Those could "spike" connected loads as the PWM "skips" after it overshoots. Without enough load, "continuous current operation" never happens, in addition to said overshoot.
                                  Those old AT supplies were rather tough, but seemed to be more sensitive to loading than newer supplies.
                                  I think that some only used one output for PWM feedback, counting on proportioning of load current to even out the voltages.
                                  With newer (1998+) supplies, not only does the coupled output inductor help, but the +5 and +12 are summed, proportionally with resistors, for feedback. This is why they can be worse with +5/+12 "crossloading," but better (safer) in a case of no load.
                                  Better yet, some supplies simply shut down during such "unregulation" under light load, as +5, for example, heads toward 5.4v with only +12 loaded. Hence the "5v minimum load" resistor, when using such supplies for 12v-only.
                                  The old-fashioned alternative would be for +5 to become 6v or more...
                                  "pokemon go... to hell!"
                                  EOL it...
                                  All style and no substance.
                                  guilty,guilty,guilty,guilty!
                                  guilty of being cheap-made!
                                  • goontron
                                    5000!
                                    • Dec 2011
                                    • 4108
                                    • US
                                    the powerman PSU handles it fine...
                                    • kaboom
                                      "Oh, Grouchy!"
                                      • Jan 2011
                                      • 2507
                                      Not surprising at all.
                                      OTOH, I once tried operating the PS out of a Compaq Deskpro 386s outside the system, no load.
                                      That thing sounded like squeaking crickets or grasshoppers! Evidently, no damage was done, since it still worked when put back in the system. I wonder what those voltages were like...
                                      Gimme a break- I think I was 12 or something...
                                      EOL it...
                                      • goontron
                                        5000!
                                        • Dec 2011
                                        • 4108
                                        • US
                                        DOH, i just put 12v to a 5v HDD
                                        • tony359
                                          by tony359
                                          11-28-2023, 05:18 AM
                                        • MegaZAC
                                          Onkyo TX-SR805 noise in one channel
                                          by MegaZAC
                                          Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                                          Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                                          There's some logic behind it. As soon as I select an input I get only left...
                                          04-23-2025, 10:09 PM
                                        • courtcircuit
                                          Philips HTS8000 home cinema noise problem
                                          by courtcircuit
                                          Hello
                                          I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
                                          Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
                                          Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
                                          I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
                                          Removed each of tyhe boards
                                          02-08-2025, 08:22 AM
                                        • karatzdi
                                          Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                                          by karatzdi
                                          I know some might say... just buy another one. Sell it as parts..!
                                          So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                                          Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                                          Spent some time downloading the Service...
                                          06-11-2024, 08:38 AM
                                        • Biruslapio
                                          LG 50PB690 power supply terrible noise
                                          by Biruslapio
                                          I bought this TV with really bad oxidation on the power supply and bottom X boards, it was working but during pickup there was a lot of background noise so I don't know if it had this problem before.
                                          As soon as I could I opened the tv and started working on it, did not test it before since it had back bars on the screen and obvious signs of humidity. The X boards were replaced and the screen now works 100%, but the power supply...
                                          I washed the board and resoldered almost everything on the primary, the oxidation happened because of constant mains AC current flowing,...
                                          07-13-2022, 12:46 PM
