what fuckery is this!?
Re: what fuckery is this!?
^ and just earned my title
Follow the white rabbit.Comment
I was servicing something a few months ago where I needed to isolate the external SMPS wall wart (bad caps) from the device. As well as test the device.
I made up a 10v supply with a 7809 and two 4004 diodes in the common. Two 1000u electrolytics, too.
Except I happened to use a 6.3v one on the input side. Input was 14V- in less than three minutes, the cap blew (Nichicon HM) and I got a slight whiff of ammonia.
"Kaboom pulls a kaboom."
Accidents happen.
"pokemon go... to hell!"
EOL it...
Originally posted by shango066All style and no substance.Originally posted by smashstuff30guilty,guilty,guilty,guilty!
guilty of being cheap-made!
*bangs head on desk* damit! i just plugged my blueray drive into the same cord
edit: ugh, i just wanted RD to chill his shit, not resign..Last edited by goontron; 09-10-2013, 09:57 PM.Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
"look before you leap"Less jewellery, more gold into electrotech industry!
Half of the computer problems is caused by bad contacts
Exclusive caps, meters and more!Hardware Insights - power supply reviews and more!Comment
Last edited by goontron; 09-10-2013, 10:03 PM.Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
Well, for me, I wouldn't immediatelly connect on two devices for a test run, still better to burn one than two…it was more like *check multiple times if everything is OK even BEFORE you plug that to something*.Less jewellery, more gold into electrotech industry!
Oh this particular AT power supply I was using was the original in the IBM AT. I didn't have the original full sized motherboard with all its TTL chips and a 5.25" hard drive hooked up to it, so the only load was a miniscule 3.5" hard drive which it promptly fried. Honestly I was kind of surprised (thought the HDD is good enough as a minimum load) but the HDD definitely released its magic smoke and there was a burnt chip on the board.
I'm still furious at it, it was a 6.4GB HDD if I remember correctly... and the drive was kind of flaky to begin with anyway. No big loss, but was 100% unexpected... May have been a smooth anyway.
And yes... whenever I deal with power I usually double, triple check connections. The +5/+12 is soooo easy to mix up. Kind of funny, I had a DEC Rainbow or something at one point that used purple for +5 and red for +12, which made it very confusing. That's when I had to start doublechecking and never trust the red...Last edited by eccerr0r; 09-11-2013, 12:27 AM.Comment
This is equally stupid:
http://www.newegg.com/Product/Produc...82E16812123300
Look carefully at the wire color!Comment
^smoky popingThings I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
Fortunatelly, nothing can go wrong here.
But did you know you could plug the PCIe into ATX 12 V and even EPS? And it just has the polarity reversed?Less jewellery, more gold into electrotech industry!
by tony359Hi all,
2. Even with the fan running outside of the case, there is still some noise which is clearly going back to the processor via power line....2 Photos -
by MegaZACSurprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
There's some logic behind it. As soon as I select an input I get only left...-
04-23-2025, 10:09 PM -
by courtcircuitHello
I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
Removed each of tyhe boards
02-08-2025, 08:22 AM -
by roadrashA vintage 1980's PC power supply has started making a hissing and whining/squealing noise and the PC is now giving random errors like memory and video etc. Ive tried the PSU with just the Motherboard plugged in and its quiet but soon as I increase the load adding controller interface cards and drives etc, the noise starts. I think there is something about to fail but cannot see anything like a bulging cap or anything. Does anyone know whats the most likely suspect component? Here is a link to a video i took....
by karatzdiHello,
I know some might say... just buy another one. Sell it as parts..!
So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
Spent some time downloading the Service...-
06-11-2024, 08:38 AM -
- Loading...
