Fortron FSP-ATX-400PNF
  • weirdlookinguy
    • Sep 2007
    • 1638
    Re: Fortron FSP-ATX-400PNF
    Originally posted by shovenose
    fsp is a decent psu oem, but the love crap caps!
    Actually, they've really gone downhill and put out a lot of junk in the past few years.
    • c_hegge
      • Sep 2009
      • 5219
      Personally, I'd be replacing all of the secondary caps if I had one of these. Jamicon are pure junk, right down there with Fuhjyyu and Sacon. El-cheapo Teapo are marginally better, but not much. I see lost of PSUs with failed teapos. I wouldn't be too worried about the primaries, though, as they rarely fail in any PSUs.
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        Originally posted by mzperx
        I have 2 of these PSU laying around with bad caps. One of the 2 CAPs in the middle (Teapo 1000uF 10V) are dead on both.
        I wonder if it originates from the capacitor quality or maybe the motherboard what it worked with killed it.. (I found these)
        I would change them, but I have only 1 such capacitor in my inventory but that has greated diameter, or I have some (a lot) nichicon 1000uF 6.3V caps.. oh and a Jee 1000uF 16V.
        Jee is low quality as I read, but maybe it is oversized enough not to die?
        Also would it be enough to change 1 cap on both, or both caps since they are identical, and I guess the other can fail as well?
        JEE is really bad, don't bother using it. The Nichicons are much better and should work fine (if they are the right series, of course, such as PW, PM, and HE), even though they are rated for a lower voltage. The original caps are rated for 10v, which means they cannot be placed on the 12v rail, only on the 3.3v, 5v rail, or 5vsb.
        Thus 6.3v and 10v caps are *generally* interchangeable in PSUs.
        • mockingbird
          • Dec 2008
          • 5488
          The FSP units with Teapo caps fail often. I've got several 300W model "PN" or "PN/B" here. The "THN" models with the OST caps last longer.
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Exact opposite experience with a batch of six FSP460-60PFN I did a while ago.
            These had 3 cap PI filters on all three rails.
            For the lot: 18 of 18 OST blown and only 4 of 26 Teapo blown. All the OST were on +12v. All the bad Teapo were in the same PSU. All the caps were 12.5mm.
            ... Also had 5 of 5 Fuhjyyu blown. - Imagine that!!
            One had a light blue Teapo instead of a Fuhjyyu in that spot. That was one of the ones without blown Teapos.
            Mann-Made Global Warming.
            - Dr Seuss
            • 370forlife
              Large Marge
              • Aug 2008
              • 3113
              Usually teapo will show it when they fail, OST hardly ever does.
              • dood
                Deputy dood
                • Mar 2004
                • 2462
                I've found the exact opposite to be true.
                Ludicrous gibs!
                • Rulycat
                  • Apr 2010
                  • 724
                  • United Kingdom
                  #28
                  Considering the mixed experiences here, we should maybe just settle on them all being rubbish and move on!
                  Maybe they're not so bad if the heat is kept down?
                  • c_hegge
                    • Sep 2009
                    • 5219
                    I find that both brands often fail without showing it.
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      My experience is more in-line with what 370forlife said on mobos.
                      I would adjust it to:
                      Usually teapo will show it when they fail, OST often don't. [On mobos.]
                      For me, in PSU's they both usually show it and they both sometimes don't.
                      Thing is, with PSUs I tend to see the same model[s] over and over.
                      I usually get 5 to 10 at a time and stick to models I know.
                      When I see the same PSU over and over the odds are I'm going to see the same cap problems over and over.
                      So: many of you see a wider -variety- of PSU cap issues than I do.
                      - Dr Seuss
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        OST's get yanked regardless of condition.
                        It might say OST on it but my eyes see Fuhjyyu anyway.
                        I'll leave Teapo alone if I haven't seen a bad one in whatever model PSU yet and there is no other reason to pull it apart.
                        Yup, good cooling helps.
                        - Dr Seuss
                        • mzperx
                          • Oct 2010
                          • 4
                          #32
                          Returning to the repair part: found 2 United branded 1000uF 10V capacitors which should be the exact same size I need. Are they considered good?
                          • Th3_uN1Qu3
                            Believe in
                            • Jul 2010
                            • 6031
                            • Romania
                            #33
                            If you're talking about United Chemi-Con, then yes they're good. Also i can confirm what PCBONEZ said about Teapo. I've also had good luck with Jamicon coz that's pretty much all they sell here, but only with general purpose ones in general purpose applications, never used (or seen for that matter) them in a SMPS yet.
                            Never seen bad primary caps? I did, in a blown Antec Smartpower. Not bloated but one has about 1.5 ohm ESR, the other 0.5. That is while ALL other primaries i have measure below 0.15. They were, guess what... Fuhjyyu of course! Funny thing is that all the Fuhjyyu and Jun Fu caps in the secondary of that PSU tested perfect.
                            A working TV? How boring!
                            • mzperx
                              • Oct 2010
                              • 4
                              #34
                              I'm thinking if I can fix the problem, I might buy some caps, and redo the whole power supply, but first I want to fix the visible problem to see if it works at all or some other parts got blown too as a consequence.
                              • 370forlife
                                Large Marge
                                • Aug 2008
                                • 3113
                                If they are these type of united, then no they are not good
                                http://capacitor.web.fc2.com/u.html#united
                                These ones are:
                                http://capacitor.web.fc2.com/u.html#unitedchemicon
                                • mzperx
                                  • Oct 2010
                                  • 4
                                  #36
                                  It seems that the solution will be really to try with whatever I got, and thenif it works change the whole set. It should still be cheaper than buying a brand new PSU, and if I but in brand caps it should stay function for years.
                                  • Darko442
                                    • Dec 2011
                                    • 7
                                    #37
                                    hello
                                    I have problem with Fortron FSP-ATX-400PNF, blow out electrolitic capacitor and burnout resistor in HV part of PSU,and please help,I need info for this capacitor, how is rated Capacity/Voltage.
                                    • c_hegge
                                      • Sep 2009
                                      • 5219
                                      I don't know what value the resistor is, but the exploded capacitor is probably the same as the other small one just behind it.
                                        master hoarder
                                        • May 2008
                                        • 12175
                                        • Bulgaria
                                        #39
                                        If no one gets to your question in a day or two, post a picture of the underside of the PSU so that we can figure out what circuit that cap and resistor are part of.
                                        • Darko442
                                          • Dec 2011
                                          • 7
                                          #40
                                          thanks for speed help.Switching transistor is NPN "3DD209L" from China on this link is datasheet"http://www.alldatasheet.com/view.jsp?Searchword=D209L".
                                          Resistor and electrolitic capacitor is in base circuit,fuse is blow,main switch transistors is blow,rectifier is ok,main electrolitic cap(1 and 2) is ok.and this is all for now...
                                          pictures is attached
                                          Darko442
