Fortron FSP-ATX-400PNF
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    I am using these for replacements in the office.
    dual rail 12v which is not exactly what i need though
    Passive pfc
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Fortron FSP-ATX-400PNF
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      jamicon, teapo, capxon
      last one. 20+4 atx
      • davmax
        • Dec 2005
        • 899
        I see this PS has plenty of Teapo caps and Jamicon 3300u 10V. I would be rather sus of the latter caps. The old trick of using low grade caps uprated from 6.3V to 10V.
        Gigabyte EP45-DS3L Ultra Reliable (Power saver)
        Intel E8400 (3000Mhz) Bios temps. 4096Mb 800Mhz DDR2 Corsair XMS2 4-4-4-12
        160Gb WD SATAII Server grade
        Nvidia 8500GT 256Mb
        160Gb WD eSATAII Server grade for backup.
        Samsung 18x DVD writer
        Pioneer 16x DVD writer + 6x Dual layer
        33 way card reader
        Windows XP Pro SP3
        Thermaltake Matrix case with 430W Silent Power
        17" Benq FP737s LCD monitor
        HP Officejet Pro K5300 with refillable tanks
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          well its a pretty common trick though, especially in PSUs.
          • bgavin
            • Jan 2007
            • 1355
            If one wanted to measure a PSU suspected of doing this, is it simply a matter of measuring the voltage across the cap in question while power is applied?
            Or is there a surge voltage that isn't apparent with this method?
            • willawake
              Super Modulator
              • Nov 2003
              • 8457
              • Greece
              there is 3.3v, 5v and 12v rails, why would you need to measure?
              • bgavin
                • Jan 2007
                • 1355
                To see if a 6.3v good quality cap is sufficient where they are using a cheap 10v cap.
                I see many mentions of where caps of higher voltage are used without an underlying requirement.
                • willawake
                  Super Modulator
                  • Nov 2003
                  • 8457
                  • Greece
                  probably safer to do it on a molex. recommended to check on various levels of load and no load. it is probably ok though.
                  with higher voltage though, sometimes much better specs in same diameter just taller. even in the good caps.
                  • bgavin
                    • Jan 2007
                    • 1355
                    I was more concerned about cheap caps in 16v in 10mm diameter vs. premium cap in 10v and 10mm diameter. The oddball Teapo and Fuhkyyu 1650uF and 1800uF are in 10mm diameter. It is harder for me to find matching premium caps in the same diameter.
                    • Daijoubu
                      • Mar 2007
                      • 12
                      Mine have OSTs for the big ones and the ball bearing version of the Yate Loon fan (D12BH-12)
                      • Daijoubu
                        • Mar 2007
                        • 12
                        Has no PFC too (I'm in Canada)
                        • Big Pope
                          Approved Vendor
                          • Dec 2005
                          • 426
                          willawake,
                          Would you tell me the value capacitance and diameter of large can input caps(Teapo)?
                          My SAMXON Capacitors Database HERE!!
                          X-CON is a new brand for SAMXON's Polymer Capacitors.
                          • willawake
                            Super Modulator
                            • Nov 2003
                            • 8457
                            • Greece
                            they are Teapo LXK 820uf 200v.
                            looking at the spec sheet they would be either 25x30 or 35x30. I will pull the psu to check, when i can.
                            • Big Pope
                              Approved Vendor
                              • Dec 2005
                              • 426
                              Thanks, because i want to replace it with Samxon EP series for testing, so i need to know the diameter first.
                              • nsx29
                                • Jan 2006
                                • 26
                                I have seen testing by others that indicate high ripple with this psu. The primary cap of 820uf 200V is kinda small for a 400w.
                                I open this HEC 350 watt which have a pair of 1000uf 200V by capxon. This PSU is from 2001. THe secondary caps are domed (fujuyyu caps). I don't know why in this psu use 470uf 35V on and 400uf 25V on the secondary side. I don't think psu need 25 and 35V on the secondary. I will update with picture in the build thread.
                                • kc8adu
                                  • Nov 2003
                                  • 8832
                                  • U.S.A!
                                  watch for those 25v caps to be on the -5 and -12.
                                  they are filters before the regulator ic for the 2 lines.
                                  since supply has to be well above the target for the common 78xx and 79xx a 16v cap wont do and give any headroom.
                                  • skafiskafnjak
                                    • Aug 2006
                                    • 19
                                    I am using these power supplies in all my custom built PC's for a long time and never had any problem with them.
                                    • mzperx
                                      • Oct 2010
                                      • 4
                                      I have 2 of these PSU laying around with bad caps. One of the 2 CAPs in the middle (Teapo 1000uF 10V) are dead on both.
                                      I wonder if it originates from the capacitor quality or maybe the motherboard what it worked with killed it.. (I found these)
                                      I would change them, but I have only 1 such capacitor in my inventory but that has greated diameter, or I have some (a lot) nichicon 1000uF 6.3V caps.. oh and a Jee 1000uF 16V.
                                      Jee is low quality as I read, but maybe it is oversized enough not to die?
                                      Also would it be enough to change 1 cap on both, or both caps since they are identical, and I guess the other can fail as well?
                                      • shovenose
                                        Send Doge Memes
                                        • Aug 2010
                                        • 6575
                                        fsp is a decent psu oem, but the love crap caps!
