What I found at work today...
  • Elysarian
    • Mar 2013
    • 200
    • United Kingdom
    Got called out to a camera (CCTV) fault today - customer report was 4 cameras offline in the same area.
    This is what I found when I opened the PSU (an Elmdene 12v, 3A boxed unit):
    Personally haven't heard of that brand of cap myself but I've flagged the job for a follow-up to replace the PSU with a 5A unit (I've always specced 1A per camera myself and although the draw on this *should* only be 2A judging by the resistance reading on my meter you have to account for impulse currents when the IR lamps switch on).
    There was a layer of soot in the bottom of the case too and the output volts were reading 3v (I didn't even bother checking the ripple!).
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Re: What I found at work today...
    Wow! That thing went out with a bang Haven't heard of that brand either
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      hmm it was a sad looking unit before the pop, look at that not even a bridge rectifier and is that spring supposed to be ground?
      also the small blue cap under the "incap" is popped to, its not feasible to repair mainly because the "incap" thats 8800㎌ cost the same amount as a new power box.
      not good!
      Follow the white rabbit.
      • klkmalik
        seeking Tips
        • Nov 2011
        • 68
        • UAE
        This problem means High voltage going to shorting main diode and busting main caps. should be test diode. caps,switching transistor. but before you test, you must connect Ac lamp 100 or 80 watts in fuse holder. If the bulb is bright still short component if the board
        good bulbs dim/
        • Elysarian
          • Mar 2013
          • 200
          • United Kingdom
          not good!
          They are cheapo units TBF, we never repair them - their bigger units do have a proper bridge in them IIRC.
          The spring isn't a ground contact though, it's a tamper (case open) switch for connecting the unit to an intruder alarm system - grounding is via the regulator heatsink (the Alu part wrapped around the PCB).
          Missing components are for a fault relay that isn't fitted in this particular model (the back EMF diode screenprint is visible near the relay output terminals).
          • mockingbird
            • Dec 2008
            • 5484
            Looks like that "incap" has turned into an "outcap".
            • delaware74b
              • Apr 2009
              • 628
              Incap - 'incap'able of holding its guts inside for long......
              Stupidity should be a crime, especially for drivers. I have NO patience for them.
              • c_hegge
                • Sep 2009
                • 5219
                Of course
                • BOSCHNJAK
                  by BOSCHNJAK
                  ABOUT ME INTRODUCTION FILE
                  2
                  024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
                  2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
                  2022 BEV, PROJECT ?
                  2021 BEV, PROJECT ?
                  2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
                  2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
                  12-28-2023, 02:09 PM
                • valvashon
                  Repair Success! Middle Atlantic UPS2200R-IP
                  by valvashon
                  Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
                  Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
                  02-06-2024, 12:54 PM
                • Grouickman
                  Hofmann geodyna 6300 Wheel balancer
                  by Grouickman
                  Hi there,
                  First, I'm not sure it's the right section to post for this type of device, but could not think of something better.
                  Ok, so my son (a mechanic) bought a faulty Hofmann Geodyna 6300 wheel balancer (which appears to be mostly a re-branded Snap-on wheel balancer).
                  I'm looking for any resources (doc, manuals, schematics) that would be available for this device or anyone that would have any knowledge on this particular device (or its Snap-On equivalent).
                  I'm trying to diagnose the fault(s ?), but I can't find any schematic (appart from the...
                  03-31-2025, 05:29 AM
                • Mark R
                  The Overseas Only Kenwood Model KR 790
                  by Mark R
                  I am Repairing this unit. It had many problems. One major one was the power transformer being about 4-5 volts low on the main B+ line which called for 66.5 Vols after the Main Filter caps but only showing about 62 Volts. Caps and the 5 amp Diode bridge were replaced which helped slightly.
                  The other strange problem was the small secondary winding from the PT which supplies 18 Volts AC to the "FM FLUORESCENT DISPLAY" circuit, and the small winding that supplies 8 Volts AC to the push button grain of wheat lamps. Those voltages were down from 18 Volts to 16 volts. Which was...
                  09-23-2025, 08:27 PM
                • pecman
                  Aiwa Z-R700 Music System has very low power when switched on, dim lighting and nothing works
                  by pecman
                  I was given an Aiwa Z-R700 from the 1990s era to look at by someone who said the twin tape deck did not work. The whole unit unit powered up ok but there was nothing from the tape deck. I had a look and found all the belts broken, I replaced the belts and then put the tape deck back into place and it still does not work. Also when I now power up the unit all the lighting on the front is very dim and the cd player and the tuner as well as the tape deck do not work. I have checked all the connections and ribbon cables again, there are no burnt or swollen capacitors. Maybe there are capacitors on...
                  08-05-2025, 10:10 AM
