PC Power & Cooling Silencer 400 ATX Question
  • jpyerry
    • 94
    I have a PC Power & Cooling Silencer 400W ATX PSU that I am attempting to repair.
    I have replaced every electrolytic cap in the thing with mostly Panasonic FC capacitors, I used Nichicon HE for the two 1000uF 6.3V caps and Nichicon LS for the two 1000uF 200V big caps.
    Yesterday, I re-assembled it and tried it out. The voltage seems to fluctuate with a periodic regularity. On the 5V side it dips down to 4.8V and then comes back up to 5V. And, on the 12V side it dips to 11.8V and climbs back up to 12V. It does this at a pace that is slightly faster than once per second. As an additional observation, I hear a faint click that occurs at about the same pace, slightly faster than once per second. This noise is not coming from the fan, but I haven't been able to locate its origin.
    I know that the voltage dips are within the normally acceptable 10% range, but I am concerned because every other PC Power & Cooling supply I have has always had rock solid stability at the voltages it supplies.
    I don't know where to go from here. Any thoughts or suggestions? Do you think this supply is repairable, or should I just desolder the caps and other parts and just chalk this one up as a loss?
    Thanks,
    Justin
  • jpyerry
    • 94
    Re: PC Power & Cooling Silencer 400 ATX Question
    It's been almost a week now and I haven't gotten any responses yet. So I am just trying to bump my thread.
    Is this behavior similar to anything anybody has seen before? If anybody wants to see pictures of the supply, I can snap off a few, I just didn't think it would have been helpful in troubleshooting this problem which is why I didn't post any in the first place.
    If nobody has any suggestions for me over the next week or so, I guess I will just tear the thing apart and salvage my caps and other miscellaneous parts. But, I'm really hoping somebody might be able help me get what should be a really good piece of hardware back to a stable condition once again, I think it would be a shame if this one ended up in a landfill.
    Once again, thanks in advance,
    Justin
    • c_hegge
      • Sep 2009
      • 5219
      Does it have any load on it? You could try connecting some old fans and disc drives.
      • jpyerry
        • 94
        I did try it with a resistor across the 5V and 12V rails (2kΩ 5W wirewound). Same result. I will grab an old hard drive and a fan or two and see what result I get with them attached. Unfortunately, I work the entire weekend normally starting Saturday, but got called in early, so further testing will have to wait until Monday, which is when I will get back to you on the results.
        Probably the biggest thing I am curious about is what on Earth could be causing the ticking noise. It really sounds like the way a high quality mechanical watch sounds when you listen to it, clicking slightly faster than once per second.
        Thanks,
        Justin
          master hoarder
          • May 2008
          • 12175
          While you seem to know what you are doing, members here at BCN (myself included) still like to see pictures of the actual item. It helps because someone may see something that you perhaps overlooked.
          Given the problem, it just seems as if the power supply doesn't have enough load. A 2 KOhm resistor is not going to put a significant load on the PSU. Something like one of those 12V light bulbs for track lights works much better (5 to 40 Watts recommended). A hard drive or two will in many cases work too (actually only some very very picky and/or high power PSUs won't start with just that).
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            Especially since the minimum load resistors internal to these things are on the order of 100/47/10 ohms, on 12v, 5v and 3v3 respectively.
            A working TV? How boring!
            • jpyerry
              • 94
              I know this is a very old thread, but I thought I would let you guys know I made progress on this project today. I am moving in about a week, so I've been trying to finish up a lot of my backburnered projects.
              I took a second look at the supply, rechecking my solder work and polarity of capacitors. I managed to find that one of the capacitors, a 3.3uF 50V capacitor had a torn trace leading to the negative side. So, I made a new trace and epoxied it down to the board and resoldered it in place.
              I turned on the supply, and it still had fluctuations on both the 5V and 12V rails with the associated ticking noise, but this time it was much smaller, in the realm of .2V fluctuation on either rail.
              I decided this is more acceptable, so I decided to risk installing it in a system. Now that it is connected to a motherboard, the voltages are absolutely rock solid, 5.04V +/- .002V and 12.05V +/- .003V. And, the ticking noise is gone.
              I think I am going to declare this one a repair, and I am quite happy about it, I really didn't want to see such a nice supply go into the trash.
              Thanks for the help,
              Justin
              • senz_90
                • Aug 2013
                • 328
                • Indonesia
                may i see the pict?
                "There is no shortcut to be successful. No pain, no gain."
                Best Regards
                Rudi
                Thank You
                • jpyerry
                  • 94
                  Originally posted by senz_90
                  may i see the pict?
                  I am in the middle of moving and my camera is packed. I will post a few pictures in a couple of weeks after I am done with the move.
                  Justin
                  • joshnz
                    • Feb 2011
                    • 969
                    • New Zealand
                    I think you had a minimum load issue not enough load to keep it stable.
                    My pc
                    CPU : AMD PHENOM II x4 @ 3.5Ghz
                    MB : ASUS M4A89TD PRO USB3
                    RAM : Kingston ValueRAM 16gb DDR3
                    PSU : Cooler Master 850W Silent Pro
                    GPU : ATI Radeon HD 6850
                    • Ace Perception
                      Samsung R530 Bremen motherboard cooling
                      by Ace Perception
                      I'm wondering if anybody out there has much knowledge of Samsung Bremen motherboards.
                      I've got a Samsung R530 which is about 10 years old, over the last 12 months it developed a worsening problem where when asked to do much work it would shut itself down. I had a good idea this was due to overheating which was confirmed by a temperature monitor programme which showed little balls of fire next to the various internal temperature readings. I could also prevent it shutting down if I placed a huge fan running at full speed in front of its air intake!
                      So I went in pursuit of...
                      07-21-2020, 03:05 PM
                    • nubie
                      PC Power & Cooling Silencer 750W SLI only 0.10v on Green wire.
                      by nubie
                      I have an old PC Power & Cooling 750w EPS12V SLi power supply with the 80mm fan that is unresponsive except for the 5v Standby.
                      Green wire has 0.10v on it. Will not start PSU when shorted to ground.
                      There is an ICE2A0565 running the PSU and a
                      HY510N 'watchdog'.
                      Does anyone have schematics or an idea of where to start with this guy.
                      5VSB is at 5.06v connected to Motherboard. There is a 7805 and a diode running the 5VSB it seems....
                      07-06-2023, 11:15 AM
                    • eccerr0r
                      Running water cooling AIO 24/7/365?
                      by eccerr0r
                      Does anyone here run an AIO or other liquid cooled CPU cooling solution 24/7/365 / on a server? Do you feel comfortable with possible failures? Should I be worried about pump failures? Pump failures causing leaks?
                      Having reservations on a second hand cooling system on a PC. So far it's pretty good, keeps things nice and cool but I've never had long term experience with 24/7/365 operation of water cooling, AIO or not. Might have to downgrade to an air cooled system for peace of mind?
                      11-25-2025, 03:51 AM
                    • Hondaman
                      Liquid cooling?
                      by Hondaman
                      I hope my computer does not randomly reboot while typing this. My main system is the AsRock 970A-G/3.1 motherboard with the AMD 8150 chip. I am experiencing FREQUENT and RANDOM reboots once the system is used for a couple of hours (sometimes it reboots before I even get to the Win7/Linux Mint dual-boot screen). The problem MIGHT be the DRAM controller chip (I recently upgraded to the maximum 64 GB RAM). It also might be the VRM chips. I am using a typical aftermarket CPU cooler, which does NOT blow air DOWN onto the VRM heat sink.
                      (After previous generation hardware [Gigabyte] didn't...
                      05-08-2025, 09:37 PM
                    • mikey5791
                      Help repair Panasonic fridge not cooling
                      by mikey5791
                      Hi all forum members,
                      Few days ago, i might have forgotten to close my home fridge freezer door completely. The next day, the ice cubes and frozen meat almost melted halfway and the freezer doesn't feel cool. I shut it off, wipe dry and let it air dry for one whole day. The next day i switched on the fridge, the compressor run for a second and it shuts off(no vibration and no sound at all) only the internal freezer compartment fan is running but is not cooling even i switched on a full day.
                      After shut off, i dismantle the rear water pan holder and reached to the compressor wiring....
                      07-16-2025, 02:01 AM
