First, thanks to everyone for their help and suggestions on replacing caps on my G4 Sawtooth Power Supply (original thread and picshere )
I was able to order all the appropriate caps from Mouser, and have completed the replacement on this Delta DPS-338BB PS.
I jumped the PW_ON and Gnd wires on the motherboard connector and connected 1x120mm, 2x80mm and 1x92mm fans (had them lying around) to run the power supply. However, it would only briefly turn on (fans would start to spin) then turn off again.
I thought perhaps that was not enough load, so I attached a couple of old CDROM drives - and that seemed to do the trick as the power supply is currently running.
My next step was to measure the loads on the +3.3v, +5v, and +12v rails with my multimeter.
The +3.3v was @ 3.3, and the +5 was @ 5.2 (no significant loads on these rails anyway). However, the +12v rail was down to 11.5v, which seems rather low.
Is this an acceptable voltage?
Is there a better way to test whether this power supply is working ok before I put it back into the computer?
Again, thanks for your (collective) help...
Ran
Ran
But today, I’m making an exception here. Why? No idea. Perhaps only because the repair details are still “fresh” in my head… which is ironic, given this is a 16 year old monitor that hardly anyone will care about today. It is new to me, though.
