Completed Re-Capping of PS: 11.5v on +12v rail too low?
  • ran
    • Oct 2006
    • 71
    First, thanks to everyone for their help and suggestions on replacing caps on my G4 Sawtooth Power Supply (original thread and picshere )
    I was able to order all the appropriate caps from Mouser, and have completed the replacement on this Delta DPS-338BB PS.
    I jumped the PW_ON and Gnd wires on the motherboard connector and connected 1x120mm, 2x80mm and 1x92mm fans (had them lying around) to run the power supply. However, it would only briefly turn on (fans would start to spin) then turn off again.
    I thought perhaps that was not enough load, so I attached a couple of old CDROM drives - and that seemed to do the trick as the power supply is currently running.
    My next step was to measure the loads on the +3.3v, +5v, and +12v rails with my multimeter.
    The +3.3v was @ 3.3, and the +5 was @ 5.2 (no significant loads on these rails anyway). However, the +12v rail was down to 11.5v, which seems rather low.
    Is this an acceptable voltage?
    Is there a better way to test whether this power supply is working ok before I put it back into the computer?
    Again, thanks for your (collective) help...
    Ran
    Integrity - doing the right thing even when no one is looking
    Freedom - not the right to do as you please, but the liberty to do as you ought.
  • linuxguru
    • Apr 2005
    • 1564
    Re: Completed Re-Capping of PS: 11.5v on +12v rail too low?
    Once you have a sufficient load on +5v, it will drop down maybe 200 mV and +12v will increase by about 500 mV to compensate. These two rails are usually regulated together, with additional cross-regulation provided by the toroidal inductor. The measurements you have are OK.
    • trodas
      • Jan 2006
      • 770
      • Czech republic
      No, 11.5V on 12V rail is not acceptable voltage for good PSU, yet you did not provided the PSU load on all rails, so, I say connect it to the machine and then measure again
      You are very likely to get much better readings.
      And unless the +12V rail is not providing like +17V or such, you can't damage anything, so, go ahead. As already suggested, the balanced load probably can fix the voltage. Small fluctuatios is normal, and most PSUs did not regulate to exact voltages, so I don't shake head at about 200mV shift.
      I would care much more about ripple, but then again - measuring ripple with scope on load that it not like the mainboard provide is proven useless again. Been there, did that and then wonder why the ripple is so much better on the board
      "It is dangerous to be right in matters on which the established authorities are wrong." - Voltaire
      "I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway my config - my caps
      • Rainbow
        • Aug 2005
        • 1371
        11.5V is probably OK. Once you connect it back to the system (so it will be properly loaded), the voltages should be OK.
        • ran
          • Oct 2006
          • 71
          Thanks so much for all your responses. I'll go ahead and hook it up tonight and see what happens!
          Beyond measuring voltages, are there other things I can test on this PSU with my lil' ol' multimeter?
          • trodas
            • Jan 2006
            • 770
            • Czech republic
            Unfortunately - nope. You need scope to check out the ripple the PSU produce and estiminate then the quality of the PSU (caps is not all, cheap regulation circuits will always produce spikes...)
            • gg1978
              • Dec 2004
              • 431
              Your Power supply sounds fine.. I suspect the reason your +12V is a bit low, and your +5 is a bit high, is that you have no load on the +3.3V.. All of the good quality ATX power supplies i've seen have the +3.3Vsense line, which lets the power supply know what the actual 3.3V reading is at the board. Since this is an Apple G4 PSU, it's certainly a good PSU..
              Also, i've got a 300W Delta that refuses to turn on if there is no load on the +3.3.. Looks your Delta will turn on with no +3.3V load, but regulation may not be optimal.. Try probing your voltages with the power supply in the G4, with at least one HDD and one CDROM drive hooked up.. I think you'll find your +12V will be perfectly in tolerance then.. Even though techically it's within the +/- 5% tolerance band right now..
              • ran
                • Oct 2006
                • 71
                Great - I'll do that....as soon as I can find a mac video card!
                Thanks for the help, everyone!!!
                • bimole
                  Weird behavior on 3.3V rail of a CORSAIR CX600
                  by bimole
                  A colleague gave me an apparently ill CORSAIR CX600.
                  He told me that he heard a banging noise, and smelt the magic smoke.
                  After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
                  I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
                  It's another story on the 3.3V rail...
                  I have some devices to test deeply PSUs (scope, AC source, electronic load)...
                  02-13-2025, 04:49 AM
                • AJ847.63e
                  Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
                  by AJ847.63e
                  Hi Folks,
                  Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
                  I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
                  The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
                  05-06-2025, 10:37 PM
                • SarcasticOP
                  General question about MacBook power rails for repair.
                  by SarcasticOP
                  I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                  • PPBUS_G3H (12.6V-12.8V)
                    • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                  • PP3V42_G3H (3.42V)
                    • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                  • PPVRTC_G3H (3.3V)
                    • This
                  12-12-2024, 05:50 PM
                  by momaka
                  03-15-2023, 10:17 PM
                  KingWin ABT-650MM 650 Watt ATX PSU [PCB: SW8835REV:A]
                  by momaka
                  For today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
                  http://www.rmac.kingwin.com/products.../abt_650MM.asp
                  I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
                  What mostly drew me into buying it is its 2x PCI-E power connectors...
                  03-29-2022, 11:34 PM
