430W (Ya Right)
  • Maxxarcade
    • Jul 2006
    • 973
    430W (Ya Right)
    Just opened up the power supply to my Sister's computer to check it over before installing a new (compared to her old setup anyway) Socket 754 system into the case.
    It is an @-Power "430W" power supply. Looks like maybe 250 to me.
    Anyone heard of Koshin caps? It has mostly those along with some Su'scon caps.
    I was going to switch it out for a Sparkle supply form another system, but I opened that one up and it had bulging caps and was only rated for 6A on the +12v rail anyway. At least now I know why that other system was flaky.
  • japlytic
    • Oct 2005
    • 2086
    Re: 430W (Ya Right)
    https://www.badcaps.net/forum/showth...ghlight=koshin
    • Super Nade
      • Jun 2006
      • 294
      Re: 430W (Ya Right)
      Looks like a Tosin knock off, who by themselves are nothing to rave about.
      Q6700 @ 3.6 GHz
      Zippy GSM-6600P
      Curcial Ballistix PC6400 (4 x 1Gb) Micron D9GMH
      Abit IP35Pro
      ATi HD4870
      • linuxguru
        • Apr 2005
        • 1564
        Re: 430W (Ya Right)
        Looks like a Deer/L&C, including the 3A rectifiers on the +12v rail - probably closer to 150W-200W.
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          Re: 430W (Ya Right)
          looks like the allied units we see here.
          the square vent holes give it away.
          yet another deer product.
          • jonnyGURU
            • Feb 2006
            • 244
            Re: 430W (Ya Right)
            Yeah. I've seen lots of Koshins. Interestingly enough, I've NEVER seen them on the primary.
            Speaking of Su'Scon, BadCaps has tainted my mind for life. I was in my wife's class room and looking down into the backs of the iMacs (you know how they're semi-clear and you can see the motherboard, PSU, etc. all laid out.)
            I was observing how Apple used Su'Scon caps in them. LOL!
            Rest in peace BFG. You were... a job...
            • yanz
              • Nov 2004
              • 910
              Re: 430W (Ya Right)
              "I've NEVER seen them on the primary."
              yeah, mee too.
              su'scon in an iMacs? wow. i thought the only right place for those caps are in deer craps and the like. i recall there are some reports about failed su'scon in this forums...
              it is still a v1.3 ATX PSU, so it has a weak 12v amperage. looking at the pics, maybe those two single diodes that set together in paralel are used for 12v rectifiers (or maybe for 3.3v). that is a very cheap solution. a fast/smooth response schottky rectifiers diode are more preferrable and normally always be used on every decent psu. so this psu isn't normal , i wont be surprosed to find another cheap solution on this POS.
              2x 330uf primary capacitance is not normal too for PSU > 400W. it should have more than 2x 470uf (or 680uF). the bridge rectifier is made from 4 single diodes. that feels cheap too. a normal chip bridge rect should be used (rs405, gbu806 or the like).
              the fan is cheap too. and if i get a >400W PSU, i would expect to see a lot of 3300uf caps on secondaries, not less (1000uf or 1500uf ones is a no no).
              are they fuhjyyu or jamicon TK/TM? some old fsp based psu use fuhjyyu craps. HEC's too.
              days are so short when you actually do something..
              • Shroomie
                • Apr 2006
                • 356
                Re: 430W (Ya Right)
                I opened up my mother's 235w Hipro last night. (circa 1999) Two Hitachi HP3 470uF 200v input, what I could see on the output was...surprise...Su'Scon. It was like being handed a box of chocolates, and then kicked in the nuts.
                Not entirely sure if it's properly functioning. I'll test it out this evening.
                You know there's something wrong when you open up a PSU and are glad to find Teapos.
                Why I don't buy cheap cases!
                • Tom41
                  • Oct 2005
                  • 336
                  • England
                  Re: 430W (Ya Right)
                  After reading this thread I just _had_ to look inside my iMac... it's one of those older G3 ones with a built-in CRT monitor, not LCD. It's also very hard to get the case off it! Opening up the RAM/expansion card cover, I could get a good look at the caps on the logic board - they appear to be Chemicon KZG. No visible bulging or venting yet, but you never know... I'd check the caps inside the CRT part as well, but that is almost impossible!
                  I wonder if Apple is using cheaper caps inside their new iMac and MacBook computers, to cut down on the costs?
                  You know there's something wrong when you open your PC and it has vented Rubycons...
                  • willawake
                    Super Modulator
                    • Nov 2003
                    • 8457
                    • Greece
                    Re: 430W (Ya Right)
                    on the iMac G5 they were using mostly Nichicon HN if you recall. Pity about that cos those boards looked awesome not cheap.
                    • jonnyGURU
                      • Feb 2006
                      • 244
                      Re: 430W (Ya Right)
                      Guess I've been lucky.
                      Haven't seen a failed Su'Scon yet.
                      • linuxguru
                        • Apr 2005
                        • 1564
                        Re: 430W (Ya Right)
                        Me neither - I've seen them only in PSUs, both on the primary and secondary side. I replace them on the secondary side as a matter of routine, but I haven't seen a single bulged or obviously failed Su'scon. I'd guess they're at the same level of quality as a CapXon, Teapo or OST - not terribly bad, but worth replacing as a matter of abundant precaution.
                        A Hipro is almost always worth fixing - its ratings are honest, so 235W will be 235W after a recap.
                        • kc8adu
                          • Nov 2003
                          • 8832
                          • U.S.A!
                          Re: 430W (Ya Right)
                          i see lots of bad suscon in psu's
                          always on the secondary.
                          • jonnyGURU
                            • Feb 2006
                            • 244
                            Re: 430W (Ya Right)
                            A particular brand of PSU?
                            Could be like Antec and Fuhjyyu's. Not that Fuhjyyus aren't bad, but put them in an Antec with a 900RPM fan and it's like vinegar and baking soda.
                              by sam_sam_sam
                              03-31-2024, 02:12 PM
                              by sam_sam_sam
                              07-01-2024, 06:34 AM
                            • shamsudeen
                              Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                              by shamsudeen
                              Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                              I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                              i know that in linear power supply the noise will be very low comparing to SMPS supply....
                              07-19-2025, 07:14 AM
                            • CMCM
                              Russound CA4 Power Supply Repair
                              by CMCM
                              Hello Everybody,
                              Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                              Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                              The outputs marked 12v and 20v are all measuring only 1v.
                              The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                              The capacitors physically look clean (no bludgesor leaks) and...
                              07-03-2025, 01:12 PM
