Half dozen psu repair challenge
  • pdavid
    • Jan 2011
    • 279
    • Hungary
    Last week I got my scope back plus I managed to salvage a huge isolation transformer. 1kW. I just need to find a place for it.
    So, one coworker wants me to repair a bunch of psus he piled up in his shop over the time.
    Since he doesn't have much equipment over there we are going to haul all the units to me so I can do it more properly.
    There are 6 units in total: Fsp 350-60hlc; 350W and 400W -80gln; 600W Epsilon, Macron MPT-5002p and a Chieftec CTG-450.
    Only the Chieftec works but the pc restarts and goes bsod after a few hours (works fine with an old GPS-400AA) The rest won't even start, one of the 350W Fortons has two broken fan blades too.
    I'm eager to get started Expect lots of pictures soon.
  • pdavid
    • Jan 2011
    • 279
    • Hungary
    Re: Half dozen psu repair challenge
    I opened all the units up for visual inspection. All except the Chieftec has buldging caps. I'm affraid some of the fortons may even have bad primary caps.
    I decided to start with the Macron, I haven't meet the insides of this psu so far.
    Standby voltage is 3.4V closing pson ground: unit doesnt start.
    Passive pfc
    8A Greetz
    2x1000uF 200V primary capacitors
    2 x 2sc2765 fets, 3843pwm
    5N60G standby fet, driven by a some sot-23 pwm
    ...Fuhjyyu caps everywhere.
    WT7525 supervisor
    smd 339
    1040CT for standby
    2 x 20100 for 12V; 2 x 3040 for 5V; 4045 for 3.3V schottkies
    Fuse, transistors and diodes test good. I replaced all capacitors except the primaries, measured 950- 960uF on them...
    Still no go. The fan doesn't even twitch, only standby voltage is present. I'm going to look for shorts and measure supervisor and other ic tomorrow.
    • c_hegge
      • Sep 2009
      • 5219
      Could be a bad transformer too.
      • Khron
        • Sep 2006
        • 1350
        • Finland
        First clue: 5Vsb is nowhere near 5V - start your investigations there.
        Prime suspect: those two small cap in the 5Vsb circuit, between those two (nearly) upright diodes. Replace those with some brand-name trustable ones, and see if it works right after that.
        Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          There's also that stupid voltage boosting circuit on the primary (the 2 small electrolytic caps next to the primary caps, along with the 2 diodes next to them). Not that that's the cause of the problem, but if you do end up fixing the Macron, you should remove/disable that circuit - it generates a lot of heat and really servers no practical purpose.
          • c_hegge
            • Sep 2009
            • 5219
            I doubt it's causing the problem. Usually, the caps on those circuits fail, but all that happens is that the voltage boost circuit itself stops working. The PSU still runs without it, but it's just somewhat less efficient.
              That circuit reduces efficiency... it increases power factor. It's a valley-fill circuit. Disadvantage is ripple is about 50% of line voltage (stretches transformer design) but PF is about 0.8~0.9 ideally.
              • pdavid
                • Jan 2011
                • 279
                • Hungary
                Ah, yes I have replaced all the small lytic caps too. Standby got back to normal right after I replaced the caps.
                The pfc voltage doubler circuit is gone. I removed it before I reassambled the psu. Interestingly the pcb wasn't fried there at all.
                Only standby voltage is present, it won't start.
                Also here are some shots of the 600W Forton. Turning on the unit it's buzzing and gives 1,5-3V standby. I took it apart and I keep finding bad components. Glimm lamp isn't lit when AC is applied, it has popped at some point. Capxon everywhere. The Capxon LP primary cap has 252uF (real parameters: 420uF 420V ) capacity and it looks corroded
                One of the 12V diode is shorted. Just great...
                I hope the other fsp units aren't like this.
                • Wester547
                  • Nov 2011
                  • 1269
                  • USA.
                  Wouldn't 50% of the line voltage be a good thing, if you mean 50/60Hz ripple as opposed to 100Hz/120Hz ripple (unless you mean something else, like 25/30Hz ripple with half wave rectification and 50/60Hz ripple with full wave rectification with passive PFC involved)?
                    master hoarder
                    • May 2008
                    • 12175
                    • Bulgaria
                    Check if PS-ON signal is present. Also check the standby auxiliary voltage rail on the secondary side (if there is one). If both of these are okay, check the auxiliary voltage on the primary side next.
                      The main caps get 50% ripple, so around 320-160V (160Vp-p) operating range for the PSU, which means the PSU transformer and controller has to be designed to work over a wide voltage range, which is tricky... The ripple is still at 100Hz. Typical ripple is around 70Vp-p at the point where the control loop begins to struggle and 100Hz becomes dominant on the outputs.
                      • Wester547
                        • Nov 2011
                        • 1269
                        • USA.
                        I thought half wave rectification (excepting the stress of APFC designs) meant a ripple frequency that is equal to that of the mains rather than double that of the mains... did I miss something? :o
                          It's not half wave rectification. It's full wave rectified.
                          Here's an example of what the valley fill circuit does. Efficiency of this stage is 98.5%, power factor is 0.95 for a 560W load. So it works fairly well, and it's efficient.
                          The resistor is for limiting inrush current, and may be removed and replaced with an inrush NTC on the input; it also helps reduce the THD.
                          • Wester547
                            • Nov 2011
                            • 1269
                            • USA.
                            Oh, that's another type of PFC. I'm curious, though, does APFC use full wave rectification (in forward PSUs) since its ripple is essentially equal?
                              Yes, most (I don't know of ones that don't) APFC circuits use full wave rectification.
                              • Wester547
                                • Nov 2011
                                • 1269
                                • USA.
                                So a passive PFC is a low line frequency (50/60Hz) inductor and Active PFC uses a higher switching frequency... but with half wave rectification, would a passive PFC (50/60Hz) cut the ripple frequency in half again (to 25/30Hz) or would it remain the same? And would a passive PFC in a bridge PSU mean half wave rectification?
                                  No, most (all?) passive PFC systems use full wave rectification too...
                                  • Wester547
                                    • Nov 2011
                                    • 1269
                                    • USA.
                                    But passive PFC is a 50/60Hz inductor (at least referring to passive PFC in forward topology). Full wave rectification has a ripple frequency that is double that of the mains, right?
                                      The passive PFC coil goes before the bridge rectifier in most cases, so it sees 50/60Hz.
                                      • Wester547
                                        • Nov 2011
                                        • 1269
                                        • USA.
                                        If it's before the bridge rectifier, it wouldn't change the type of rectification a forward or bridge PSU would use, would it (or would it have to be after the rectifying bridge to do that, even though if it was after it would be operating at a 50/60Hz line frequency)?
                                        • Raulnn
                                          TD Systems K50DLG12US half black and half white screen
                                          by Raulnn
                                          good night! I have this screen that looks half black and half white. the tcon gives a low vgh value (5-6v). the rest seem fine. I first removed the flex from one half of the panel and then the other. Removing the left, vgh increases it to 25-26v. I think the problem is in that area, but there are not many elements on the integrated controller board. there are no shorted capacitors. could they be a cof? Some help?
                                          By the way, now the entire screen is black. Maybe some flex was not connected correctly... I have exchanged the flex and there are no variations, I don't think they are the...
                                          01-20-2024, 04:49 PM
                                        • scubacamper
                                          Sharp Aquos LC-70C6400U Half Screen Dark
                                          by scubacamper
                                          I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                                          Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                                          when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                                          05-03-2025, 12:19 PM
                                        • valvashon
                                          LG 55UH6150- trouble powering up, then half lit screen (pictures!)
                                          by valvashon
                                          The 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
                                          Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it...
                                          11-24-2024, 12:08 PM
                                        • kca
                                          by kca
                                          Hello all ~
                                          08-31-2025, 06:38 AM
                                        • smic717394
                                          MSI Optix MPG27CQ half screen working. Identify burned component
                                          by smic717394
                                          I have a MSI Optix MPG27CQ screen to fix, only half screen is working, I found a burned chip on the right buffer board (S270DP01V00_HF_SR) but I can't read the model. Can anybody help?...
                                          04-08-2025, 05:53 AM
