Power Inverter for a Car (Diagnose + Repair)
  • scampo77
    • Dec 2010
    • 233
    Re: Power Inverter for a Car (Diagnose + Repair)
    In the board there are no shorts, did you want me to yank them out?
    • ben7
      Capaholic
      • Jan 2011
      • 4059
      Take them out and check them with the diode check mode on your DMM. If you are not sure of the pinout, tell me what the transistor types are.
      Muh-soggy-knee
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        Also another test, with the driver transistors still on the board, remove the IRF640's and turn the unit on. Make sure the HV DC bus is on, and measure the voltage from the gate pad (where each IRF640 mosfet gate pin was) to ground.
        Muh-soggy-knee
        • scampo77
          • Dec 2010
          • 233
          Q7,Q16 the outer ones are NPN KSP42
          Q12,Q24 the inner ones are NPN PN222A
          I built a transistor testing station i found here, (the third or fourth one down from the top)
          http://www.kpsec.freeuk.com/components/tran.htm
          I pulled all 4 out and put them in this circuit and all of them acted as an insulator (no LED light) untill I applied voltage to the base, then my LED lit up.
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            Those are good, so it seems like the CD4013 flip flop(s) aren't switching, and we need to figure out if it is getting the correct input pulses. (or, no pulses at all!)
            Muh-soggy-knee
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • PantherDave
              by PantherDave
              Hi all!
              05-29-2024, 02:01 PM
            • GLISIT
              by GLISIT
              01-16-2025, 02:29 PM
              03-31-2024, 02:12 PM
              09-06-2024, 05:59 AM
