new seasonic
  • BigTroll
    • Sep 2010
    • 1317
    • LAMBDA SOND
    new seasonic
    http://www.jonnyguru.com/modules.php...Story&reid=313
    really neat psu i love the layout hitachi cap and the price and performance of unit for its low wattage.
    My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Re: new seasonic
    Yeah, awesome power supply! And at a great price too. I might have to pick one of those things up. Aesthetically, it looks really good, I like the black and dark blue
    • c_hegge
      • Sep 2009
      • 5219
      Re: new seasonic
      It's a fair bit more expensive here in Aus. You'd be doing very well to get one for $100. Seriously, the OCZ ZS 650W is only $80!
      • Pentium4
        CapXon Be Gone
        • Sep 2011
        • 3741
        Re: new seasonic
        Ouch...it's pretty new though, hopefully the price will go down. It's not the only option out there but having such a great performing 80 Plus Gold rating in a low wattage power supply is pretty impressive
          by momaka
          03-12-2025, 03:42 PM
        • Jaime Morillo
          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
          by Jaime Morillo
          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
          The TV was stuck on the logo and I couldn't access the update menu.
          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
          The image result was good, but the image is inverted.
          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
          08-18-2025, 11:38 AM
        • wolf1976
          hitachi 50hk5600 problem with display
          by wolf1976
          hi
          i have the above tv and the display starts distorts the display at only in applications like you tube
          after and on the didital channels
          now without connect the antenna only the image of itsselfs tv i have the image i have in attach
          i have read in another forum someone else with similar problem with mine changes tcon card and motherboard and the problem remains
          can you tell me someone what is the reason that can causes that problem ? is the same the sisplay ?...
          09-13-2025, 02:26 PM
        • massimomax
          Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
          by massimomax
          Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
          spero che qualcuno può averlo per riprogrammare eprom. grazie
          Post in English !!!
          I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
          02-28-2025, 07:27 AM
        • dragometin
          Hitachi 40HYC42
          by dragometin
          TV Model: Hitachi 40HYC42
          Power Supply: 17IPS71
          MainBoard: 17MB95M
          Panel: VES400UNDS-2D-NO3
          When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
          I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
          Is there any variants on 17IPS71 power supply's?
          UART output pins 10 and 12 on scart connector:
          Code:
          12:24:04.595
          08-08-2024, 05:53 AM
