Corsair CX-600 photos
  • Behemot
    • 4845
    • CZ
    Re: Corsair CX-600 photos
    Use diode tester between all voltage rails and ground. If somewhere will be 0 (or like 1-2, for older topologies with mostly shared +3,3 and +5 V rails there is as low as 6 ohms and it works fine), you have the one shorted. If not, it's something else, compensation/power good I guess.
    • rogfanther
      • Jul 2006
      • 458
      • Brazil
      Aaaaand it works. There was a shorted diode in the -12V line.
      I humbly admit I hadn´t remember to consider checking for shorts in the cable end. Tested all the rectifires in the heatsink , all tested good, and started considering the problem to not be a short.
      The psu is currently being tested, but has already endured some cycles of on/off and seems to still work ( fingers crossed ) .
      Thank you very much Behemot, and the others who helped also. One more thing to remenber doing in the basic tests of defective psus...
      Now, back to a bunch of coolermasters and sunpros that won´t turn on but are not shorted...
      • RJARRRPCGP
        • Jul 2004
        • 6304
        Originally posted by c_hegge
        CWT transistor based 5vsb circuits kill boards too. Remember the Antec StupidPowers?
        It looks like I caught mine early!
        In fall, 2011, I noticed my Antec SmartPower 2.0 500W PSU whining when real quiet in the house and the PC off.
        Then shortly after, I took the cover screws off and pulled the cover off and after I did, I saw a bulging Fuhjyyu cap next to the outer exhaust fan. (the fan that seems to never work.)
        PSU on the Acer desktop is now an Antec VP-450.
        ASRock B550 PG Velocita
        Ryzen 9 "Vermeer" 5900X
        Arc A770 16 GB
        eVGA Supernova G3 750W
        Alienware AW3423DWF OLED
        • BigTroll
          • Sep 2010
          • 1317
          • LAMBDA SOND
          wow, i just got a xclio 500watt goodpower and inside it looks just like the corsair as its a cwt build, however it actually has a 330uf 400v samxon and the secondarys are teapos.
          My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro
            • 31138
            i just fixed something very similar to that with the same "totally dead" symptoms.
            tested all the semiconductors,
            then got fed up and just thought "fuck it" and replaced the small electrolytics.
            and - it works!!!
            • Behemot
              • 4845
              • CZ
              #26
              You have ESR meter stj?
                • 31138
                no, it broke.
                i had the old analog one wih the "speaker-wire" probes.
                looking to get a new digital one off ebay soon.
                a lot of my tools seem to be dying these days - my weller DS80 failed too
                i dont think it would of helped with 85' small caps though.
                there where only a few, i just put YXF & FC in instead.
                • Behemot
                  • 4845
                  • CZ
                  #28
                  I got a spare ESR Micro v4.0s, can send you with some caps…measures 0,01-65535 uF.
                    • 31138
                    i was looking at one of these.
                    http://www.ebay.co.uk/itm/261518555263
                    • Behemot
                      • 4845
                      • CZ
                      #30
                      That's auction so count on higher price.
                      Anyway, these things are mostly useless. I have more advanced CT-Micro V1.0 on this design (it's still the german design of like-a-multi-purpose testing device), in reality it is useless for measuring in-curcuit. You cannot manually select WHAT do you want to measure so it measures something else or nothing quite often. So far it only helped me with inverter transformers and small capst, mostly out-of-curcuit. I do ten times more diagnostic with ESR Micro and cheap chinese multimeter.
                      Also count on no support, no warranty, no battery.
                        • 31138
                        i didnt expect support or battery.
                        and i only test off-board anyway.
                        as a standalone for testing small parts before fitting, it should be fine.
                        • Behemot
                          • 4845
                          • CZ
                          #32
                          If you are OK with being many times slower, your choice. But having to replace all caps blindly or desolder them and test one at a time, that's just crazy. It actually quite explains why so many people here has so low annual sales they cannot afford anything. You save few bucks on chinese crap over something better but it makes you so much slower you don't earn anything because you repair single device in several times longer time-frame than me.
                          Sure, I don't succeed in repairing so many units, but after all, I earn much more doing for example 3 displays a day than doing one display/PSU for 3 days. Nobody will pay you for this and that is what you have to realize.
                            • 31138
                            most of my repairs dont have any caps other than ceramics,
                            i work on large logic boards with dozens - even over 100 logic chips on them.
                            • Behemot
                              • 4845
                              • CZ
                              #34
                              Yeah for ceramics it's good but once they are in circuit, baaad, they have to come out…
                              • zeldaww
                                • Mar 2016
                                i got one of these CX600 that is just not working
                                when i connect the green wire with ground and turn it on the fan spins for 1 second and shuts down.
                                I read there were cases where people had to connect 2 HDD and 2 fans for it to work correctly, but in my case i connected like 4 fans, disc drives and same problem, fan spins 1 second and turns off.
                                I checked the capacitors and they look brand new, when i see the caps there is no sign of inflated capacitors.
                                rogfanther : can i send you an email , maybe you can give me a hand with my PSU
                                • Behemot
                                  • 4845
                                  • CZ
                                  #36
                                  Try checking the secondary rectifiers if some is not shorted…tat's always a good start.
                                  • frogz81
                                    • Oct 2012
                                    • 31
                                    • Indonesia
                                    #37
                                    I got cx-600 with blown primary cap from my friend. cause he use Genset, and after a moment there is bang on PSU.
                                    Upon checking it the primary cap explode.
                                    already check diode bridge, mosfet PFC and PWM is good.
                                    the question is whether simply replacing the primary cap can revive it?
                                    Any suggestion is there more section/part to check or damaged part caused from this issue.
                                    Thank for your help.
                                      • 31138
                                      check fuse
                                      • frogz81
                                        • Oct 2012
                                        • 31
                                        • Indonesia
                                        #39
                                        Hi stj,
                                        the fuse is good
                                          • 31138
                                          then maybe its just the cap
                                          • bimole
                                            Weird behavior on 3.3V rail of a CORSAIR CX600
                                            by bimole
                                            A colleague gave me an apparently ill CORSAIR CX600.
                                            He told me that he heard a banging noise, and smelt the magic smoke.
                                            After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
                                            I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
                                            It's another story on the 3.3V rail...
                                            I have some devices to test deeply PSUs (scope, AC source, electronic load)...
                                            02-13-2025, 04:49 AM
                                          • Ibod
                                            Corsair cx600 psu & ASRock B450Pro4 mobo wont start
                                            by Ibod
                                            HI I have a PC using a Corsair cx600 psu & ASRock B450 Pro4 mother board that won't power on after a shutdown (replaced a dead drive in a raid array) Not the boot drive.
                                            With most things unplugged, including the 24 pin ATX connector, but not the ATX12v to cpu, I have +5.01V on the +5vsb pin 9 from the PSU. When I plug the 24 pin back in to the mobo, the +5vsb fluctuates between 1.1v & 1.9v.
                                            Not sure where to go from here ?
                                            Is the PSU at fault or is the mobo causing the problem
                                            Look forward to any help :-)
                                            If I plug the 24...
                                            02-08-2023, 11:00 AM
                                          • h0m3w0rk
                                            Random Shutdowns/Startup Failure with Corsair SFX 450
                                            by h0m3w0rk
                                            I'm encountering a frustrating issue with my Corsair SFX 450 power supply. After an undefined period of operation, my PC will either suddenly restart or, in some cases, it won't start at all until I disconnect the power cable and reconnect it. This erratic behavior occurs intermittently, making it difficult to pinpoint the exact conditions under which it happens.
                                            For context, I have tested the PSU using an electronic load at 150W, and under those controlled conditions, it functions flawlessly. This leads me to...
                                            02-09-2025, 03:19 AM
                                          • saimom
                                            Asus FX507ZC4 DANJLFMBAB0 REV B I need photos
                                            by saimom
                                            Hello everyone!
                                            Please help me determine which microcontroller was in this place.
                                            Logically, I guess that this is a ddr4 PWM memory controller and some kind of Richtek, but which one?
                                            Thise motherboard came after another service, where they say that water got on the controller and it burned down and they dismantled it.
                                            They did not take photos before the intervention
                                            The DANJLFMBAB0 REV B board, schematics, boards and photos of the motherboard were not found on the network, but I may have searched badly-((
                                            Maybe someone has a photo of this piece,...
                                            12-17-2024, 08:51 AM
                                          • Davi.p
                                            Reduce the size of photos please..
                                            by Davi.p
                                            Hi all, i'm asking all to reduce photos to a more comfortable resolution before post, the better like around 2000x2000, otherwise many PC / Tablets / phones refuses often to load them or has strong defection... today's digital cameras integrated in phones especially are a mockery because them saves photos at enormous resolutions with much less the real definition, so reducing them is only a good deal.. THANKS!!...
                                            05-16-2024, 12:53 AM
