What could cause this PSU to output 12.5V on the 12V?
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    So, the PSU in question is crap no doubt. It's a "Nift" branded L&C power supply that took out a motherboard due to the really high voltage on the 12V. I tested it and the 3.3V reads 3.3, the 5V reads 5.0 and the 12V stays right on 12.5V. What could be causing this? The caps look to be good but then again it's purely YC caps. Also just for fun, I posted a pic of 2 NIFT PSU's with the same exact label, but holy hell look at the different in build quality! They're both crap but they sure did improve it some (Don't mind the missing input cap on the right one, I ripped it off )
    Re: What could cause this PSU to output 12.5V on the 12V?
    It is within spec, if the mother board cannot handle 0.5V higher on 12v LINE, that is not good
    http://www.certiguide.com/apfr/cg_ap...owerSupply.htm
    http://www.tomshardware.com/forum/30...hold-concerned
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      Oh okay, 12.6V is the max, for some reason I thought that it was 12.5V. Still seems a little high though, what happened on the mobo was all the TK caps on the mobo bulged, and all the panny's lived
      • rogfanther
        • Jul 2006
        • 458
        • Brazil
        I think you can find this psu in threads talking about "anodia" caps. I do not remember the brand under which it was sold, but they are, while not the best, not the worst either. Good for about 200 - 250W, tops.
        • Pentium4
          CapXon Be Gone
          • Sep 2011
          • 3741
          Yeah, all of them are YC but the same color as Anodia caps, so they're probably the same company. This one has 470uf 200V Input caps and a 4A bridge rectifier. It was powering an Athlon x2, 2 dvd drives, a GT430, 2 RAM sticks, and a TV tuner card. Pretty low load really. Think this thing could be upgraded to maybe a 300W? The transformer probably couldn't do much more than that, if at all.
            TK are just rebranded OSTs, I thought.
            I like PSUs with high 12V. It's good, lower current draw, so in theory slightly more efficient in places. As demand increases, the voltage can drop - this is normal, some designs are like that.
            • Pentium4
              CapXon Be Gone
              • Sep 2011
              • 3741
              Yeah that's true. Do you think it's worth improving? The output rectifiers are 20A, 30A, 30A, 5A. Not sure which ones are which but those are the specs of them.
              • rogfanther
                • Jul 2006
                • 458
                • Brazil
                I would risk saying its quality can be improved with better caps. At least it has inductors in the outputs. Seems the other model , with just one row of caps, lacks these also.
                Up to 300W I don´t know, but maybe assuring 250W with some reasonable stability ? Which was the motherboard that burnt ?
                Just to register, most of the psus of the second type ( just one row of green caps ) I have seen around here, where dead when the fan stopped running, then they would cook the toroid inductor, and it would in turn cook the few caps the thing has.
                • Pentium4
                  CapXon Be Gone
                  • Sep 2011
                  • 3741
                  Precisely, the fan seized up and it cooked. The motherboard if I recall correctly was a Biostar, but not 100% sure. I could at least add an X cap and maybe replace the bridge rectifier with a GBU606 just because I have so many of them lying around.
                  • rogfanther
                    • Jul 2006
                    • 458
                    • Brazil
                    Of ocurse, anything in it can be an improvement.
                    I have one like yours ( with that big bunch of green radioactive caps in the secondary ) waiting for a day I decide to try fixing its 5vsb as a learning experience.
                    • mariushm
                      • May 2011
                      • 3799
                      Someone already said 12.6v is OK ... and it is, nothing wrong with it.
                      It's group regulated model, which means that as you put some load on 5v (around 2-3A), the 12v will slowly drift down towards 12v.
                      Problem is modern computers don't use 5V that much nowadays and this kind of psu was designed for the 5v days of the past.
                      • Th3_uN1Qu3
                        Believe in
                        • Jul 2010
                        • 6031
                        • Romania
                        Wrong... If you put some load on 5v, 12v will go UP, and vice versa. This is likely an old design, tweaked to work better with modern computers. Under load you will find voltages to be within spec.
                        I remember Socket A boxes (which don't use 12v at all, except for the hard drive and optical drive) with cheapo PSUs where 12v would be over 13v. They ran like that for years.
                        A working TV? How boring!
                        • Pentium4
                          CapXon Be Gone
                          • Sep 2011
                          • 3741
                          Thanks for the replies, good to know How hard would it be to add a fan controller? I took one out of a parted out SPI power supply.
                          • goodpsusearch
                            • Oct 2009
                            • 2850
                            • Greece
                            Does it use 13007 or 13009 switching trasistors?
                            • Pentium4
                              CapXon Be Gone
                              • Sep 2011
                              • 3741
                              It has a DFF2N65, and two D304X
                              • goodpsusearch
                                • Oct 2009
                                • 2850
                                • Greece
                                Transistors limit: 300watt max
                                2x470uF primary caps: (maybe) 300watt peak
                                But they could be fake... and real capacitance can be 330uF. L&C does that very often.
                                The power supply needs a second coil at the input AC filter and a second X capacitor.
                                I would not make the fan run slower with those heat-sinks and the general design.
                                  master hoarder
                                  • May 2008
                                  • 12175
                                  • Bulgaria
                                  TKs are crap and that's why they failed.
                                  12.5V is a bit high but wouldn't kill them. That said, I don't like the 12V rail on my PSUs that high either. In my experience, all of my hard drives run hot when the 12V rail is either too high or too low. 11.90 to 12.30 is where I like/try to keep it.
                                  • ben7
                                    Capaholic
                                    • Jan 2011
                                    • 4059
                                    Try loading the 5v and 3.3v. The 12v might be poorly regulated. Also check how much ripple is on the power rails.
                                    Muh-soggy-knee
                                    • Pentium4
                                      CapXon Be Gone
                                      • Sep 2011
                                      • 3741
                                      I'd be happy to get 300W out of this thing. I'll test the YC input caps for capacitance and probably replace them with 470uf OST's because I don't want to waste my 560uf Panny's in an L&C. Yeah TK are pretty bad, I'd like to see more like 12.3V but at least it's still in spec
                                      • Pentium4
                                        CapXon Be Gone
                                        • Sep 2011
                                        • 3741
                                        So I was really busy at work today so I didn't have much time but I took out the "Sleeve Bearing" (no brand) fan and replaced it with an NMB-MAT, ahhh so much better It's at least 3 times quieter and don't have to worry about it failing any time soon.
                                          Corsair CX750M [Model 75-002019] - burned output toroid inductor
                                          by momaka
                                          Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
                                          So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
                                          09-19-2021, 08:44 PM
                                        • mecha1166
                                          Copper corrosion? Yamaha HS8S Audio 1 output only
                                          by mecha1166
                                          OAUD Yamaha HS8S Audio one output only.
                                          I have pulled the output board. Output txsistors are ok (only 2 main output). Everything measures the same on each side. Customer did not bring in speakers so I cannot go too deep. I did notice a greenish tint on the tip of the solder joints that connect to the COPPER output connectors. All 6 have a greenish tint at the tip - each side has 3 pins each. Anyone else have copper speaker output pins that corrode at the place on the PCB where they are soldered? I will try to add a photo. Thanks.
                                          08-04-2023, 02:55 PM
                                        • electron_jj
                                          Panasonic TH-L42D25A checking the PSU output voltage
                                          by electron_jj
                                          Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
                                          I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
                                          08-29-2021, 08:13 AM
                                        • technodruid
                                          Wavetek 130 Output issues
                                          by technodruid
                                          First post!
                                          Last night I finally got a chance to try out a wavetek 130 that I purchased a year ago or so after finally getting unpacked from a move. It was working really well, I was testing the various settings from the 50 ohm output into my rigol scope and it seemed to be fairly accurate. I was stepping through the course adjust from x10 to x100 and sweeping the dial looking for any distortions or drops/rises in amplitude. It all looked great.
                                          Then when i switched to the 1M setting, the sine wave disappeared. I moved back to x100k and the sine wave was still gone. Something...
                                          04-04-2024, 10:32 AM
                                        • CapLeaker
                                          Astron RS-7A/10A not regulating output voltage low
                                          by CapLeaker
                                          Either I am getting old or dumb, probably both.
                                          This “simple” linear power supply is driving me insane. Should be easy, right?
                                          Here is the story. Got that Astron RS-7A or 10A as stone dead. I mean turned on and got 0.00V not even an mV on the output. Why dat? Darn electrolytic output capacitor shorted at the binding posts. No, problem… new one in stock and mounted.
                                          Turned the PSU on again and now I got 0.1V on the binding posts. Everything clear like sunny day and replaced the LM723 regulator IC in the socket. Had it made, I thought....
                                          09-17-2023, 08:33 PM
