No brand psu 12v diode failed
  • joshnz
    • Feb 2011
    • 969
    • New Zealand
    Hi I have a 350Watt psu
    I was plugging in a usb cable into my sisters computer I knocked the power cord
    and it started arcing and the pc lost power no big deal.
    So I re-plugged the power cord and the pc tried to start but no go,
    The power light was green so I turned the psu off at the power switch then turned the power switch back on after some time, the psu ticked as to power on, same problem.
    So I disconnected it from the mb and tried to start it manually just got a tick and nothing, then unplugged all connectors same issue.
    Measured the voltages 5v tried to rise 12v had a few millivolts.
    Tested for shorts the 12v rail was shorted.
    I removed the diode for the 12v rail and is shorted on one half.
    It had a STPR1620CT can I use a FEP16AT?
    The only only difference is reverse voltage 200v old new 50v
    and 5ns more recovery time so a little slower than the old one.
    My pc
    CPU : AMD PHENOM II x4 @ 3.5Ghz
    MB : ASUS M4A89TD PRO USB3
    RAM : Kingston ValueRAM 16gb DDR3
    PSU : Cooler Master 850W Silent Pro
    GPU : ATI Radeon HD 6850
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: No brand psu 12v diode failed
    Some people will say 50v reverse voltage is too low for a 12v rail, but i've successfully used such diodes. Give it a shot.
    A working TV? How boring!
    • joshnz
      • Feb 2011
      • 969
      • New Zealand
      Thanks Th3_uN1Qu3.
      I will give it a go in morning hope I can find a friendly electronics repair shop I don't have my tools with me this visit
      My pc
      • Pentium4
        CapXon Be Gone
        • Sep 2011
        • 3741
        I'm curious to see how this works out for you. Can you post some pics of the PSU or at least the specs on the label?
        • joshnz
          • Feb 2011
          • 969
          • New Zealand
          here u go
          My pc
          • joshnz
            • Feb 2011
            • 969
            • New Zealand
            I found a better spec diode at the same place
            STPR1620CT (old)
            IF(AV) 2 x8A
            VRRM 200 V
            Tj (max) 150°C
            VF (max) 0.99 V
            trr (max) 30 ns
            BYV42-150
            IF(AV) 2 x15A
            VRRM 150 V
            Tj (max) 150°C
            VF (max) 0.85 V
            trr (max) 28 ns
            argh it's not in stock
            My pc
            • joshnz
              • Feb 2011
              • 969
              • New Zealand
              Yay it is running with the FEP16AT .
              wtf $17.50 to solder it in .
              My pc
              • joshnz
                • Feb 2011
                • 969
                • New Zealand
                power supply is still running has been the whole time
                Thanks for all advice.
                My pc
                • Pentium4
                  CapXon Be Gone
                  • Sep 2011
                  • 3741
                  Looks like an L&C. Glad to hear it's working!!!! What is it powering?
                  • joshnz
                    • Feb 2011
                    • 969
                    • New Zealand
                    CPU: Intel Celeron 325 Prescott 2.53GHz
                    MB: Intel Corporation D845GVSR
                    RAM:2X512
                    1X HDD
                    1X DVDROM CDRW
                    My pc
                    • c_hegge
                      • Sep 2009
                      • 5219
                      Looks nothing like one to me. If anything, it more closely resembles a CWT/ISO or possibly a Unitek (a small chinese company). It kind of resembles this, aside from the different heat sinks.
                      • Th3_uN1Qu3
                        Believe in
                        • Jul 2010
                        • 6031
                        • Romania
                        Agree, definitely not a Deer/L&C, their soldering usually looks horrible, and more often than not there's a wire beefing up the ground trace. This looks pretty clean, and has proper input filtering and a connector for a passive PFC coil.
                        • Victor Moreira Silva
                          Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                          by Victor Moreira Silva
                          I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                          Well, my decice specs are the following:
                          Model: Acer Nitro 5 AN517-54-55T5
                          CPU: Intel Core i5-11400H
                          GPU: NVIDIA GeForce GTX 1650
                          Motherboard: GH51G LA-L181P Rev:1c
                          The symptom:
                          When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                          05-26-2025, 10:49 AM
                        • GLISIT
                          by GLISIT
                          01-16-2025, 02:29 PM
                        • mkdj
                          Acer TravelMate P214 - N19Q7 main power rail shorted to ground
                          by mkdj
                          Dear all,
                          I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
                          I have checked resistance across each of the 4 MOSFETS. I have the following readings:
                          Both N-Channel Mosfets: nothing odd
                          P-Channel MOSFET number 1:
                          source - drain : 117 kOhm
                          source - gate: 96 Ohm
                          gate - drain: 117 kOhm
                          P-Channel MOSFET...
                          08-20-2025, 06:08 AM
                          by sam_sam_sam
                          03-31-2024, 02:12 PM
