No brand psu 12v diode failed
  • joshnz
    • Feb 2011
    • 969
    • New Zealand
    Hi I have a 350Watt psu
    I was plugging in a usb cable into my sisters computer I knocked the power cord
    and it started arcing and the pc lost power no big deal.
    So I re-plugged the power cord and the pc tried to start but no go,
    The power light was green so I turned the psu off at the power switch then turned the power switch back on after some time, the psu ticked as to power on, same problem.
    So I disconnected it from the mb and tried to start it manually just got a tick and nothing, then unplugged all connectors same issue.
    Measured the voltages 5v tried to rise 12v had a few millivolts.
    Tested for shorts the 12v rail was shorted.
    I removed the diode for the 12v rail and is shorted on one half.
    It had a STPR1620CT can I use a FEP16AT?
    The only only difference is reverse voltage 200v old new 50v
    and 5ns more recovery time so a little slower than the old one.
    My pc
    CPU : AMD PHENOM II x4 @ 3.5Ghz
    MB : ASUS M4A89TD PRO USB3
    RAM : Kingston ValueRAM 16gb DDR3
    PSU : Cooler Master 850W Silent Pro
    GPU : ATI Radeon HD 6850
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: No brand psu 12v diode failed
    Some people will say 50v reverse voltage is too low for a 12v rail, but i've successfully used such diodes. Give it a shot.
    A working TV? How boring!
    • joshnz
      • Feb 2011
      • 969
      • New Zealand
      Thanks Th3_uN1Qu3.
      I will give it a go in morning hope I can find a friendly electronics repair shop I don't have my tools with me this visit
      My pc
      • Pentium4
        CapXon Be Gone
        • Sep 2011
        • 3741
        I'm curious to see how this works out for you. Can you post some pics of the PSU or at least the specs on the label?
        • joshnz
          • Feb 2011
          • 969
          • New Zealand
          here u go
          My pc
          • joshnz
            • Feb 2011
            • 969
            • New Zealand
            I found a better spec diode at the same place
            STPR1620CT (old)
            IF(AV) 2 x8A
            VRRM 200 V
            Tj (max) 150°C
            VF (max) 0.99 V
            trr (max) 30 ns
            BYV42-150
            IF(AV) 2 x15A
            VRRM 150 V
            Tj (max) 150°C
            VF (max) 0.85 V
            trr (max) 28 ns
            argh it's not in stock
            My pc
            • joshnz
              • Feb 2011
              • 969
              • New Zealand
              Yay it is running with the FEP16AT .
              wtf $17.50 to solder it in .
              My pc
              • joshnz
                • Feb 2011
                • 969
                • New Zealand
                power supply is still running has been the whole time
                Thanks for all advice.
                My pc
                • Pentium4
                  CapXon Be Gone
                  • Sep 2011
                  • 3741
                  Looks like an L&C. Glad to hear it's working!!!! What is it powering?
                  • joshnz
                    • Feb 2011
                    • 969
                    • New Zealand
                    CPU: Intel Celeron 325 Prescott 2.53GHz
                    MB: Intel Corporation D845GVSR
                    RAM:2X512
                    1X HDD
                    1X DVDROM CDRW
                    My pc
                    • c_hegge
                      • Sep 2009
                      • 5219
                      Looks nothing like one to me. If anything, it more closely resembles a CWT/ISO or possibly a Unitek (a small chinese company). It kind of resembles this, aside from the different heat sinks.
                      • Th3_uN1Qu3
                        Believe in
                        • Jul 2010
                        • 6031
                        • Romania
                        Agree, definitely not a Deer/L&C, their soldering usually looks horrible, and more often than not there's a wire beefing up the ground trace. This looks pretty clean, and has proper input filtering and a connector for a passive PFC coil.
                        • Victor Moreira Silva
                          Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                          by Victor Moreira Silva
                          I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                          Well, my decice specs are the following:
                          Model: Acer Nitro 5 AN517-54-55T5
                          CPU: Intel Core i5-11400H
                          GPU: NVIDIA GeForce GTX 1650
                          Motherboard: GH51G LA-L181P Rev:1c
                          The symptom:
                          When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                          05-26-2025, 10:49 AM
                        • GLISIT
                          by GLISIT
                          01-16-2025, 02:29 PM
                        • madan1
                          DALI SUB E-12F class D, fluctuating power rail
                          by madan1
                          Good day everyone.
                          I have on the bench an amp board from DALI SUB E-12F. It is class D amp with a smps on the same board.
                          The issue is that it powers off way before the rated power is reached (the protection circuit kicks in). It has an independent standby power supply, which stays on after the main power supply is turned off via a relay on the primary side (thus there is no reason to believe that the protection is triggered from the smps IC on the primary side).
                          The normal value of the positive and negative power rails is +/- 43V.
                          The positive rail stays...
                          10-15-2025, 10:33 AM
                        • mkdj
                          Acer TravelMate P214 - N19Q7 main power rail shorted to ground
                          by mkdj
                          Dear all,
                          I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
                          I have checked resistance across each of the 4 MOSFETS. I have the following readings:
                          Both N-Channel Mosfets: nothing odd
                          P-Channel MOSFET number 1:
                          source - drain : 117 kOhm
                          source - gate: 96 Ohm
                          gate - drain: 117 kOhm
                          P-Channel MOSFET...
                          08-20-2025, 06:08 AM
