Help with identifying PSU board (possibly Tagan?)
  • wacce
    • Feb 2012
    • 40
    • Finland
    I recently picked up a PSU board from trashes. The board is mostly intact, and no parts are missing, so I was wondering if it was worth saving. All info on the unit is appreciated. This unit suffers from bad Fuhjyyus, surprice surprice.
    The board seems very similar to Tagan PSUs, here's what I found from the forums.
    Tagan 480W: https://www.badcaps.net/forum/showthread.php?t=3230
    Tagan TG330-U01: https://www.badcaps.net/forum/showthread.php?t=12484
    Tagan TG380-U01: https://www.badcaps.net/forum/showthread.php?t=14353
    The fan controller is placed at the top of one of the heatsinks, like in TG330-U01, but unlike in TG380-U01 or 480W. My unit also has a different fan, which has some kind of LED light in it, label reads "ribbed led all blue, sleeve bearing, 12V 0.2A , RL4B S08025LD". That made me think, that it might be some other brand than Tagan. The unit has had two fans, the other one was taken by the previous owner.
    There are very little marking on the board, the ones I could find were "P022-E" and "(CF) 03 94V0, E199724" in sixth and seventh pictures. Found out that "E199724" refers to manufacturer Cheerful Industrial Co., Ltd. Also COPYRIGHT 2003 is written a couple of times on the board.
    Thanks in advance!
  • selldoor
    Slow Learner
    • 7870
    Re: Help with identifying PSU board (possibly Tagan?)
    This might help
    http://translate.google.co.uk/transl...ed=0CFIQ7gEwAA
    • wacce
      • Feb 2012
      • 40
      • Finland
      Originally posted by selldoor
      Thank you for the link! The i-Xeye unit seems almost like the one I have, except that mine has fan controller circuit on the top of the heatsink, and in all pictures I found of i-Xeye the controller was on the side. Different versions maybe?
      • wacce
        • Feb 2012
        • 40
        • Finland
        My discoveries so far: the board layout and heatsinks resemble most Tagan TG330-U1, but my unit has different fan(s) AND it has a red switch at the back panel (switch cables are attached to the remaining fan). I found some Tagan units with a similar looking switch for using 12V rails as separate or combined, like in TG430-U22.
        Other possible brands might be Topower or Epower, but haven't found any units that are similar enough.
        • wacce
          • Feb 2012
          • 40
          • Finland
          Seems like I'm spamming my own thread while I find out new things
          I realized that the red switch is a three step switch for regulating fan speed, and it was only disconnected from the fan controller circuit. These switches can be found at least in E-power PSUs, like Cougar (link) and Xscale (here) series.
          It is also now obvious to me, that this PSU is made by Topower, and might be supplied by one of it's associates (OCZ, BeQuiet, Tagan, E-Power).
          Topower TOP-400P5/450P5/520P5 board/heatsinks are looking very similar, as can be seen here and here. Taking into account the size of main caps, in my case 470uF, TOP-400P5 seems to be the only one to match, as TOP-450P5 has 1000uF main caps.
          Feels like I'm getting closer ...or maybe it's just me.
          • wacce
            • Feb 2012
            • 40
            • Finland
            Bingo.
            Be Quiet! Colorline 2 Fan (Titanium), 400W version.
            http://www.skenegroup.net/fi/artikkelit/be_quiet_13.2
            http://www.hartware.de/review_362_15.html
            I got lots of search results of finnish sites, which gives me more reason to believe that I got it right.
            Thanks you selldoor for helping me to the start, I might have ended up using a lot more time on this than I now did!
            I've got a blown-up Antec Smartpower SP-450P, which I can take the cables from, and some old PSU cases with similar dual fan layouts. Seems like the unit doesn't originally have SATA-cables, but I guess adding them now doesn't hurt right? I'll let you later know how the project progresses
            • c_hegge
              • Sep 2009
              • 5219
              Reminds me a lot of my topower built Global Win SAF450 (http://hardwareinsights.com/wp/2011/...saf450-review/). It is a half decent design, so if you can get it going, it will be worth hanging on to, but that could be easier said than done with the damage to the PCB.
              • wacce
                • Feb 2012
                • 40
                • Finland
                The innards of SAF450 are almost identical to this BeQuiet. Additional 50W would have been nice, but 400W should do in many systems.
                Actually the damage on the board is not that big, only the +12V through holes got little bent and they haven't even broken from the PCB. To make sure the connection is ok, I'll solder an additional wire on the trace, over the bent bit.
                • c_hegge
                  • Sep 2009
                  • 5219
                  The extra wire is probably a good idea. Replace all the caps and see how it goes. Check the primaries too, as these PSUs are notorious for killing them.
                  • wacce
                    • Feb 2012
                    • 40
                    • Finland
                    Sorry for my lack of knowledge, but is the EMI filter replaceable with just any (new enough) other EMI filter circuit from for example Antec Smartpower? Antecs circuit seems a bit more compact, and I was wondering if it's compatible. Picture attached.
                    • c_hegge
                      • Sep 2009
                      • 5219
                      Yes, you can replace the EMI filtering components. They are all compatible, but bear in mind that they can be physically different sizes, but if they fit, they will work.
                      If that smartpower is really wrecked, then you could probably put the Topower in its case. I used a smartpower case when I was re-building my Rexpower/Key Mouse PSU.
                      • wacce
                        • Feb 2012
                        • 40
                        • Finland
                        Excellent, thanks for the reply.
                        I was considering using the Antec case too, as I'm a little short on two fan cases. With my current level on knowledge, Antec is not an easy case. One resistor near the other heatsink is totally fried (pic. attached), and I believe this PSU went out "with a bang", taking some other components with it. Interestingly, only those two caps near the burnt resistor and one main cap were bulging. Anyway, it might be doable but seems like a good amount of work, going through all the transistors is necessary I believe.
                        Also, Antec is pretty much the only one which has decent cabling left
                        • c_hegge
                          • Sep 2009
                          • 5219
                          If you're gonna fix the Antec, you're probably better off replacing the whole 5VSB circuit with a PWM IC based circuit. everall has done it a few times to Antec SP-xxx (https://www.badcaps.net/forum/showthread.php?t=19291).
                          If you decide to put the Topower in the Antec's case, you would get away with only one fan, and it looks like you still have one of the fans that the Topower originally came with
                          • wacce
                            • Feb 2012
                            • 40
                            • Finland
                            That actually seems quite interesting. Maybe I'll save the Antec for later, as they tend to be very nice PSUs after some modding.
                            There is indeed one fan still left, but I'm not sure if it provides sufficient airflow. From the reviews I read that the fans are VERY quiet, so I'm guessing that they don't spin very fast. I think I'm going to use two fans, just to be sure. I might combine one old single fan case with different top cover, which has a place for 92mm fan. We'll see.
                            • c_hegge
                              • Sep 2009
                              • 5219
                              You could also put an ~6K resistor in parallel with the thermistor on the fan controller. The reason these PSUs are quiet is because the fan controller spins the fans very slow untill the PSU really starts to cook, then they will become louder. The 1 fan should be enough airflow IMO if you mod the fan controller
                              • goodpsusearch
                                • Oct 2009
                                • 2850
                                • Greece
                                I agree. I fan mod most of the power supplies I fix just to be safe they don't cook caps (or toroid coil) again.
                                • m1ch43lzm
                                  by m1ch43lzm
                                  05-12-2025, 08:37 PM
                                • howardc64
                                  by howardc64
                                  07-24-2025, 05:17 PM
                                • snipersquad100
                                  Dewalt DCR020 Power Board – No Power, Need Help Identifying ICs / Possible Replacement
                                  by snipersquad100
                                  I’m working on a Dewalt DCR020 jobsite radio that won’t power on.
                                  So far, I’ve checked the following:
                                  • The mains is reaching the transformer
                                  • Transformer outputs ~15-20 V AC
                                  • Bridge rectifier outputs ~15-20 V DC
                                  • All fuses test OK
                                  • The on/off button signal reaches the PCB connector
                                  Despite this, the unit does not power up at all.
                                  Inside, I’ve identified some of the ICs:
                                  • ST7317 (appears to be an LCD driver, not the main MCU)
                                  • LM2937L (voltage regulator)Not putting out power, 0.5V on the input
                                  • Markings like FS1235, unknown IC
                                  • Board number:
                                  09-01-2025, 10:57 AM
                                • Hakuu
                                  by Hakuu
                                  Hi There,
                                  More Details
                                  TV Model - LG OLED77G1PUA
                                  07-12-2023, 02:37 PM
