Quick look inside the infamous Tagan 480W
  • Fizzycapola2
    • Jan 2007
    • 4
    I decided to invalidate my warranty, don't know why I did this still kicking
    myself, curiosity to find bad caps inside got the better of me I guess. Anyway
    there wasn't much to see with the big heatsink covering nearly everything.
    Just a peek. Not much useful knowledge to be gained, but I did invalidate my warranty for this lol.
    Apologies for picture quality, I've spent thousands of dollars on cameras
    not spending anymore. (admitedly last purchase was 5 years ago )
    Fizzycapola2
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Quick look inside the infamous Tagan 480W
    nice panasonic primaries the rest are fuhjyyu
    • MixMasta
      • Feb 2006
      • 142
      I thought Tagan was a good brand?
      • gonzo0815
        • Feb 2006
        • 1600
        Not from my point of view.
        Tagan is a hot air brand like Antec. They do well in tests and reviews of low skilled hardware mags, or may be theyre good at the start. The rest is and always was marketing nothing else.
        But obivousely Tagan has archived to have some fanboys around them, thus if you say it loud that theyre crap as for using crapiest caps known on earth, you just got flamed in many forums from ...err probably people wich can`t judge the quality of an psu.
        But i know fore shure, that there is a wide margin in selling this psu`s, may be this is the answer why theyr pushed from that many shops that far.
        To be honest, except from the caps, most Tagan units would be ok, but on some series there where other isssues.
        In the first real THG test, some TAgan PSu`s failed to deliver the stated output. They burnt.
        Reason was the bad thermal contact of a Transistor to it`s heasink. ANother issue where some transformers, wich have some failures in the isolation layer.
        Any way, i would prefer to buy a PSu from the "real" manufacturer, like Seasonic and FSP.
        Shure, even they are using badcaps from time to time, but most retail PSu`s from either of the both have not failed on me.
        • Brian C
          • Dec 2006
          • 156
          Failures in transformer isolation layer ? i thught they should have done the high potential (hi-pot) and insulation test for all their products. May i know where can i get the info on PSU THG test ?
          • PeteS in CA
            • Aug 2005
            • 3583
            • USA, Unsure of Planet
            Were the transformer failures actual electrical failures? Or did the construction fail to comply with ISO 950 (or other applicable safety standard)?
            PeteS in CA
            • linuxguru
              • Apr 2005
              • 1564
              Tagan is not bad, just like Hi-Pro - simply upgrade the caps and be happy.
              • Fizzycapola
                • Oct 2006
                • 423
                I'd say it's a bit harsh to say it's crap inside.
                Given it's not ALL perfection.
                It's nearly perfection 50% of the inside is heatsink all the rest is components not even a centimetre cubic centimetre of free space, it's packed like I've never seen before. Primaries are good.
                This is one of the few PSU under 600w with 30A 12v rail, a good PSU when used beyond it's limit just burns out whatever caps it has (I imagine), this one has never failed despite 2 years at maximum load, Globalwin 680w blew out after 2 weeks under the same environment, so did Antec 350w (probably overloaded), multi award winning PSU of the year all over the net.
                Only parts that aren't any good (although working perfectly still after 2 years of heavy usage) are replaceable for under $5 and a few minutes soldering.
                Sorry to sound like some sad guy defending his purchase lol.
                But I have PSU that cost the same as this Tagan that deliver half the power rely heavily on fan cooling to work properly and have Fuhyyu primary caps to boot, now maybe Tagan aren't that bad lol!!!
                Rubycon Rubycon Rubycon
                • gonzo0815
                  • Feb 2006
                  • 1600
                  Well, i have not said Tagan is crap, the other things are not bad, but where is the benefit having expensive stuff like big heatsinks, epoxy PCP`s etc. when using the F word caps?.
                  Fore the same amount i would prefer a Seasonic S12, but the UCC caped version.
                  I do not know, what the problem with the transformers are exactly, but sometimes they loosen their isolation and short. IMHO not only Tagan`s where afekted.
                  A good PSU will never burn, as it should have WORKING overload protection, and in fact most PSU do have this.
                  The problem with the Tagan was the heattransfer from the powertransitor. The whole PSu was in fact capable in delivering the stated power, thus the OVP was set to it.
                  Then either the screws has ben losend during transport or they have not used the right torque.
                  So at least they have not fooled the customer by purpose.
                  • gonzo0815
                    • Feb 2006
                    • 1600
                    The test i refered was the first real THG (=Toms hardware guide) PSu test, wich was done with elektronic loads to push the psu`s to their stated output.
                    Since then, they continued to do psu live stress test over several weeks.
                    The actual test is here,
                    http://praxis.thgweb.de/2007/01/15/s...007/index.html
                    strangly on the english site i can`t find it. May be some advertiser won`t read that in english? or my google skills suck.
                    Any way, if you want to read it, i think google translation should be ok.
                    • WeStSiDePLaYa
                      • Mar 2006
                      • 63
                      umm...... arent FSP's known for their horrible ripple and regulation......
                      Specs
                      DFI AM2 LANPARTY UT NF590 SLI-M2R/G
                      X2 3800+EE AM2
                      2x1GB OCZ PC2-6400 Platinum XTC
                      XFX 7900GS
                      Maxtor 6L250S0
                      Maxtor 6V300F0
                      Western Digital WD2500JS
                      Mushkin HP-550(Cap/Filter Modded)
                      Cooling
                      Swiftech Apogee
                      Swiftech MCW-60
                      Swiftech MCP-600
                      HardwareLabes Black Ice Extreme 2
                      • gonzo0815
                        • Feb 2006
                        • 1600
                        Hm you are probably refering to the Epsilon series, IMHO they ar within the ATX spec, any way, my FSP`s are all ok and working w/o glitches (shure, there are no Fuyiyu crap inside, so if theyr used your milage may vary).
                        I have afew OEM units wich are very sensitive abouth crossloading (wich is probably normal for most brands) and some older p-PFC units for 5V powered systems.
                        if the PSu is choosen right for the system, those problems should no toccure.
                        The Amacrox 500GLN is working without any problems too.
                        To be honest, my systems are all far from being high end stuff, my main unit consumes abouth 150w under full load (GFX & CPU).
                        But i haven´t seen a system wich will draw more than 200w in real life ( an yes, i would not consider the famouse Intel D820 4GHZ OC thing as an longlasting experiment, and not as an solid working system IMHO a stupid projekt right from the start, but pepople love the GHZ myth))
                        So the 500w Amacrox is not something i intentionaly bought, it was an ebay bargain.
                        otherwise i would have bought a Seasonic S12 330w or 380w.
                        • Fizzycapola
                          • Oct 2006
                          • 423
                          • Flaku_34
                            Acer Nitro XV273 and Predator XB273, look inside and disassembly guide.
                            by Flaku_34
                            Introduction:
                            Hello everyone, this topic is more of a knowledge sharing and look inside type of post, but for someone working on this model of display it might be useful. Recently I bought Acer Nitro XV273 XB MIIPRZX with busted electronic, but screen was intact, price was incredibly low, so I took a gamble and bought the unit and try to fix it. As I dug inside, I found out that my motherboard was not responding, although all voltages seemed fine. I wasn't able to find any reliable information about this monitor on the web (only some pictures of motherboards from Ebay). By some research...
                            04-18-2024, 12:47 PM
                          • SuperStarr
                            An old runner - Tagan EasyCon 480W (TG480-U15)
                            by SuperStarr
                            I have a Tagan EasyCon 480W (TG480-U15) power supply.
                            Unfortunately‚ (or not - I'm here now! ) it died so I decided to open it and take a look in hope I will find the culprit and give it another try in case I can fix it.
                            By the way, I'm just a hobbyist, coming from automotive industry (automotive electrician) but as my (limited) knowledge is most of the time obsolete comparing it with latest tech trends, and I don't have experience with AC, most of the time you will find me searching / learning by following the tutorials, reading forums and some e-books, looking videos and so...
                            03-03-2019, 08:31 AM
                          • bauto601
                            KDM 480W PSU upgrade succes! (opinions?)
                            by bauto601
                            Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                            A "nice" YoungYear unit? - Badcaps
                            The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                            12-26-2023, 03:05 PM
                          • kotel studios
                            TAGAN TG380-U01 PSU - 5v shorted after replacing caps
                            by kotel studios
                            Hi
                            Recently I got this tagan tg380-u01 PSU with bad caps on 3.3v rail (the line was 2.5v no load!). Replaced them but no go, so I've replaced all of them, apart from some smaller ones and one under the secondary heatsink. Even that didn't help so I've replaced the others. All caps are known good ones.
                            Powered it on and heard the breaker pop. Opened it up and saw some smaller caps shorted together. Fixed that up but still it trips breakers. Now I get 0ohms from 5v to GND. Secondary heatsink removed and still a short, even with the PWM IC board removed. All diodes on that...
                            02-14-2025, 10:10 AM
                          • jolivares
                            Black tape in the mainboard inside apple's devices
                            by jolivares
                            Hi everybody.
                            i'm looking for the black tape inside apple's devices.
                            Is the tape tha covers the shield on the mainboard. when you take it out, loses the adhesive.
                            It is very thin.
                            can somenone help me to find it for a better repair?
                            Thanks, God bless you.
                            09-09-2024, 08:07 AM
