What mainly determines a power supplies efficiency?
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    This may be a dumb question but I'm curious. Is it mainly the schottky's/transistors and transformers?
  • c_hegge
    • Sep 2009
    • 5219
    Re: What mainly determines a power supplies efficiency?
    The Switchers, the PFC Parts (if present), and the secondary rectifiers are the main parts responsible for the efficiency. The secondary rectifiers should have a low voltage drop, and the Transistors (both PFC and the switchers) should have both fast switch times and a low RDS-on (resistance when switched fully on)
    • Rulycat
      • Apr 2010
      • 724
      • United Kingdom
      Doesn't the topology affect efficiency a lot?
      • c_hegge
        • Sep 2009
        • 5219
        Yes, it does. I was referring to parts which were easily replaceable.
        • Pentium4
          CapXon Be Gone
          • Sep 2011
          • 3741
          Thanks for the reply! I wonder if you could get an old half bridge up to 80% efficiency
          • iMic
            Vintage AT Power Supplies - Selecting Capacitors
            by iMic
            Back after a long hiatus with some old power supplies that need repairing. I've recently picked up a couple of 386SX systems, two 486DX systems, a SiliconGraphics Indy and an iMac G3 that either have verified leaking capacitors in their power supplies, or are likely to in the near future. For the sake of simplicity, instead of tackling all at once, I'm starting with the 386's and one of the 486's.
            The 386's power supplies are Seasonic SS4040A's, with caps that are visibly leaking, and 9 replacement caps per unit are required. Most appear to be from the Rubycon...
            02-19-2023, 06:45 PM
          • SolomonMan
            HP Docking Stations Power Supplies...?
            by SolomonMan
            All,
            I recently purchased for a colleague and myself two used HP Docking Stations. They are for home use and are exact model as the ones we use at work for our laptops. We are both Software Developers.
            Anyways these docks are HP Model 5TW10UT#ABA.
            Unfortunately they did not come with there Power supplies (PSU) and I got them reasonable from eBay.
            I purchased 2 new from Amazon After Market Power Supplies(PSU). Same Voltage and Same Amperage and in fact it mentions on the Amazon page they are supported for these docks as well.
            h...
            05-09-2023, 08:04 AM
            Meanwell Switching power supplies intermittent every capacitor under 100uf
            by sam_sam_sam
            Here is the eBay website link where I bought them from
            https://www.ebay.com/itm/276135936202
            I have been waiting for these switching power supplies to come well they came in today so I took one apart and found that it Capcon and EIite and another brand that is on my list of capacitors to replace on site it has several 0.47uf @ 50 volts ESR value twice the reading of a new one 10 UF @ 50 volts almost twice the ESR value of a new one 47 UF @ 59 volts with double the ESR value 100 UF almost the same as a new one it got replaced for good measure Iit was a brand if I see them...
            11-25-2023, 06:05 PM
            ISL95836 Laptop PWM Controller Datasheet
            The ISL95836 Pulse Width Modulation (PWM) controller IC
            provides a complete solution for IMVP-7/VR12 compliant
            microprocessor and graphic processor core power supplies. It
            provides the control and protection for two Voltage Regulators
            (VRs). The first VR, typical for Vcore, incorporates 2 integrated
            drivers and can operate in 3-, 2- or 1-phase configurations. The
            second VR, typical for graphics, incorporates 1 integrated
            driver and can operate in 2- or 1-phase configurations. The two
            VRs share...
            11-05-2024, 03:31 PM
          • bauto601
            KDM 480W PSU upgrade succes! (opinions?)
            by bauto601
            Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
            A "nice" YoungYear unit? - Badcaps
            The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
            12-26-2023, 03:05 PM
