ISL95836 Laptop PWM Controller Datasheet
    The ISL95836 Pulse Width Modulation (PWM) controller IC
    provides a complete solution for IMVP-7/VR12 compliant
    microprocessor and graphic processor core power supplies. It
    provides the control and protection for two Voltage Regulators
    (VRs). The first VR, typical for Vcore, incorporates 2 integrated
    drivers and can operate in 3-, 2- or 1-phase configurations. The
    second VR, typical for graphics, incorporates 1 integrated
    driver and can operate in 2- or 1-phase configurations. The two
    VRs share a serial control bus to communicate with the CPU and
    achieve lower cost and smaller board area compared with the
    two-chip approach.
    Both VRs utilize Intersil's Robust Ripple Regulator R3
    Technology. The R3 modulator has numerous advantages
    compared to traditional modulators, including faster transient
    response, variable switching frequency during load transients,
    and improved light load efficiency due to its ability to
    automatically change switching frequency.
    The ISL95836 has several other key features. Both outputs
    support either DCR current sensing with a single NTC
    thermistor for DCR temperature compensation, or more
    precise resistor current sensing if desired. Both outputs come
    with remote voltage sense, programmable VBOOT voltage,
    IMAX, and switching frequency, adjustable overcurrent
    protection and separate Power-Good signals.
    Features
    • Serial Data Bus
    • Dual Outputs:
    - Configurable 3-, 2- or 1-phase for the 1st Output Using Two Integrated Gate Drivers
    - Configurable 2- or 1-phase for the 2nd Output Using One Integrated Gate Driver
    • R3 Modulator
    - Excellent Transient Response
    - High Light Load Efficiency
    • 0.5% System Accuracy Over-Temperature
    • Supports Multiple Current Sensing Methods
    - Lossless Inductor DCR Current Sensing
    - Precision Resistor Current Sensing
    • Differential Remote Voltage Sensing
    • Programmable VBOOT Voltage at Start-up
    • Resistor Programmable IMAX, Switching Frequency for Both Outputs
    • Adaptive Body Diode Conduction Time Reduction
    Applications
    • IMVP-7/VR12 Compliant Computers​
    ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
    3+1 Voltage Regulator for IMVP-7/VR12 CPUs
    Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
    core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
    configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
    serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
    Based on Intersil's Robust Ripple Regulator...
    11-05-2024, 03:24 PM
  • SageHappy
    Lenovo Thinkpad 11e showing "Thermal sensing error" upon powering on.
    by SageHappy
    Hello guys,
    I hope you are all good. One day my Lenovo thinkpad 11e laptop just started displaying "Thermal sensing error" after I switched it on. At first I thought it was an issue to do with a defective thermal sensor in my fan. I replaced the old fan with another used fan but, the problem still persists. From where I bought the fan, they said the fan was working just fine so, my question is how can I rectify this problem. Thank you in advance.
    05-27-2024, 12:35 PM
    ISL6556ACB ISL6556ACBZ ISL6556ACR ISL6556ACRZ PWM Controller Datasheet
    Optimized Multi-Phase PWM Controller
    with 6-Bit DAC for VR10.X Application
    The ISL6556A controls microprocessor core voltage
    regulation by driving up to 4 synchronous-rectified buck
    channels in parallel. Multi-phase buck converter architecture
    uses interleaved timing to multiply channel ripple frequency
    and reduce input and output ripple currents. Lower ripple
    results in fewer components, lower component cost, reduced
    power dissipation, and smaller implementation...
    11-05-2024, 03:10 PM
  • macattack600
    820-00165 Current Sensing Issue
    by macattack600
    820-00165 Macbook air 2015 Motherboard.
    Initially would not fully boot no liquid damage any kind.
    Finally get to boot notice it says service battery won't boot after 2nd attempt.
    Replace with genuine Battery and OEM 45w charger it boots.
    If its fully charged 100% stuck ! even though coconut battery shows it going down in percentage, system information says fully charged when after running 20 min on battery alone and I look now its not charging but still shows icon as "charging"? but magsafe is green ? confusing!
    When I run Mac...
    04-14-2021, 10:47 PM
  • ktmmotocross
    Asus 290x 109-C67157-00_02 - 1phase not work
    by ktmmotocross
    Hello.
    Have this Asus 290x 109-C67157-00_02 and one phase wont work. when put little load i hear "coil whining" noise. with big load card freeze whole pc.
    On PWM signal of this phase i have steady 1.4V which others have 0.3V-1.6V
    i measure everything and could not find problem. i replace mosfets - no change. i exchange two of 8510 ic which control mosets -no change, so there is problem with IOR controler not give godd signal. i mesure most of component aroud it and all looks good.
    Any hint on this?...
    07-25-2022, 03:02 AM
