Repurposing a Brick
  • LAS
    • Sep 2011
    • 144
    Repurposing a Brick
    Hi BadCaps folks,
    Up until recently, I have had a Sony laptop but now I find myself with a Dell. I would like to have a second brick which I can use with my Dell, but think I may be able to modify my old Sony brick, with a new Dell plug, and hope to use it in my Dell.
    I have attached a photo of both bricks below. Both are 19.5vdc and 4.x amps.
    As I see it, the difference is in the plug which goes into the laptop. I have ordered and received a Dell plug via an eBay seller in China, and today it arrived. I chopped the plug off of the Sony brick and spliced on the new plug.
    On the Dell plug, as I see it, there is negative (on the silver outside sleeve), and positive (on the inside metal sleeve) and then there is a third wire - red - which goes to the center pin but I am unaware of its function. On the voltmeter, the Dell brick does not read a voltage, or a very small one.
    On the Sony plug, the plus and minus are the same configuration. There is no third wire.
    Something does not seem right however. When I plug in my unmodified Dell brick, the charge battery light blinks on and off. When I plug in my new modified Sony brick with the Dell end, the light goes on once but does not blink. And for some reason, my Sony brick / Dell end shows 2v on the pin.
    Does anyone with any experience in bricks see anything that I am missing?
    Thanks all,
    LAS.
    Re: Repurposing a Brick
    Do you have the pictures of the Dell plugs?
    • LAS
      • Sep 2011
      • 144
      As a matter of fact I do Budm!
      Original Dell on the left, modified Sony on the right.
      • retiredcaps
        • Apr 2010
        • 9271
        http://www.tomshardware.com/forum/55...r-power-supply
        Another reason why I won't buy any Dell stuff.
        --- begin sig file ---
        --- end sig file ---
        • LAS
          • Sep 2011
          • 144
          A big sigh...thank you Retiredcaps for your research.
          Well, the good news is that I am only out $4 for the plug from China.
          I had a feeling it might go that way when I saw the photo of the plug with the third wire.
          On to the next project.
          • retiredcaps
            • Apr 2010
            • 9271
            It took me days to figure this Dell proprietary one out (I probably would still be looking for it if selldoor did not help out).
            https://www.badcaps.net/forum/showthread.php?t=19392
              retiredcaps, Thanks for the Info.
              I found this in Dell forum for the possible fix:
              http://en.community.dell.com/support....aspx#19589078
              I also found other complaints in Dell forum also.
              http://en.community.dell.com/support.../19775870.aspx
              http://nctritech.wordpress.com/2010/...endor-lock-in/
              • b700029
                Banned
                • Sep 2010
                • 640
                There's a 1-wire EEPROM in it:
                http://www.laptop-junction.com/toast...stery-revealed
                http://www.laptop-junction.com/toast...r-id-chip-died
                You can move the EEPROM from the adapter to inside the laptop to make it able to run from any DC source.
                • LAS
                  • Sep 2011
                  • 144
                  Thanks b700029. If it was my laptop and not company owned, I may have just tried that but at least now I know what's going on. I may just spring for another adapter as Dell OEM adapters can be had for about $25.
                  • 999999999
                    • Sep 2006
                    • 774
                    Ironically enough I just went through this with a Dell D600 someone brought to me, though the issue cited was it was really slow. On the D600 it doesn't just refuse to charge the battery, it drops the 1.6GHz CPU down to 600MHz and I couldn't find any software solution to get it to run any higher.
                    Turns out the Dell PA-10 (Or maybe it was PA-12) PSU had the center pin smashed down in the plug and was shorting out against the positive DC power contact (entire inside of the barrel connector) too. I tried to straighten the pin but it just broke off which I expected given how mangled and tiny it was.
                    I ended up bidding on a replacement on eBay, original (used) Dell OEM PSU not one of their thousands of listings for a generic PSU, cost me $11 delivered. Winning bid is usually about $7 plus shipping.
                    • b700029
                      Banned
                      • Sep 2010
                      • 640
                      If it's property of your company then why not ask them for an adapter too.
                      • Bowline
                        by Bowline
                        06-11-2025, 10:13 AM
                      • F R 2568
                        Dell Latitude 5420 does not start (no post) need help to find the reason why
                        by F R 2568
                        Hello all,
                        this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                        I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                        If the laptop is only connected to the AC adapter (battery removed):
                        When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                        The power/battery...
                        01-08-2025, 05:45 AM
                      • diamon
                        Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                        by diamon
                        I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                        Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                        Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                        Pictures of these boards:
                        Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                        Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                        Dell...
                        02-28-2024, 12:51 PM
                      • master3112
                        by master3112
                        07-29-2025, 01:55 PM
                      • OntarioTL
                        Dell 5410 greyed out BT
                        by OntarioTL
                        Well I've learned something new today. Of all the Dell laptops I've come across I have never seen bluetooth greyed out, and only to learn this is during the build from Dell factory. I've tried to pull the original BIOS and fix with another dell with the same issue on the forums, however the original was not recovered from the forum upgrade so I cannot do a comparison to attempt the fix on my own.
                        If someone could help me out with this unit and I'll try the next one as so far I have 2 on my desk with this issue. Thanks in advance!
                        Dell Lattitude 5410
                        Service Tag...
                        07-25-2025, 01:28 PM
