Sansun SN-W450 ATX - buzzing & burn marks
  • quattro alex
    • Mar 2012
    • 92
    Model:Sunsung "make your life beautiful" SN-W450 ATX
    Sticker: 0604 005 263
    Fault: Buzzing heard with the psu powered on without load. Probably still buzzing with load but intake fan too noisy to hear.
    Background: Work colleague asked me to take a look at this psu which he has had for a few years, he mentioned the buzzing and the fact it looked quite dusty - this was an understatement.
    Testing / observations:
    PSU (cheap tester) showed the following rail voltages:
    +3.3 = 3.3v
    +5 = 5.2v
    +12v1 = 12.1v
    +12v2 = 12.1v
    -12v = 11.6v
    5vsb = 5.1
    PSG=280ms (not sure what this means)
    Once I'd removed a lot of the dust I saw that caps C19 & C20 were bulging. These are JEE caps with a value of 2200UF and 10 volts. Tested values were ESR of 2.2 & 2.3, no capacitance value available - I am assuming it was too low. I still have to measure a few of the other caps (Canicon and Su'Scon)
    At this stage I had a sniff and I could smell that burnt plastic smell. I unscrewed the secondary board which sat upside down above the 2 large black caps. This didn't look so good - the pcb was very discoloured around 2 resisters. I need some help trying to work out the values of these resisters as the colour bands are badly burnt. There is also no continuity on either of the resisters.
    I will carry on testing the remaining resisters that I can work the values out on. The general layout on this psu seems quite poor and everything seems very tightly squeezed in. Add copious amounts of dust and this can't make for a long service life.
    Photo's to follow shortly.
    Fixed so far: GNR TS902W monitor, Sony Game Gear, Philips FCD565, Arcam Alpha 10, Memorex SA 404amp
  • quattro alex
    • Mar 2012
    • 92
    Re: Sansun SN-W450 ATX - buzzing & burn marks
    photo's now attached
    • everell
      • Jan 2009
      • 1514
      Does the fan blade spin freely? If not, a good place to start would be to take the fan apart, clean and oil the bushing, then reassemble. Without a freely spinning fan, I would expect lots of continuing heat problems.
      Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
      • c_hegge
        • Sep 2009
        • 5219
        Those resistors won't get much airflow, even with a working fan. I think that the best solution would be to disable the APFC and remove the PBC (although I don't know if that's legal in the UK, since PFC is mandatory there). As for the buzzing, it's probably the two big caps going bad. JEE are a notoriously unreliable brand and APFC puts more stress on them than usual.
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          Or use resistors with proper power rating.
          A working TV? How boring!
          • b700029
            Banned
            • Sep 2010
            • 640
            280ms is the time from power-on to when the Power Good signal comes up.
            It looks a lot better than some "500W" gutless wonder, and some of the newer high-wattage PSUs are just as cramped inside. Poor choice of caps though.
            For figuring out the value of the resistors you can pull the endcaps off and try measuring the resistance across the carbon spiral directly. They might not be directly responsible, but something else failed in the APFC circuit may have caused them to overheat.
              The buzzing could be bad primary caps. I had a PSU that did that when the primary caps were bad - then again, they were only fake 330uF ones (actually 220uF.)
              • quattro alex
                • Mar 2012
                • 92
                The fan spins, but could definitely be smoother, so I will take it apart and use something like lubricating oil for a shredder.
                Big JEE 85c (CE.W IM0610) caps are rated at 820uf and 200v - tested at no1. 840uf & 0.17 esr. No2.770uf & 0.20 esr - I haven't got these, what would be a good replacement and what level of ripple should I be aiming for?
                I got a reading for both resisters using the 200K scale on my DMM. 1.374 & 1.376 - can you recommend which value I should replace these with?
                APFC - does this stand for automatic power filtering control? I don't know about the regulations regarding this, and I am not sure I'd feel comfortable removing it - especially as this is not my equipment.
                Thank you for all the advice / suggestions so far.
                • mcdaydavies
                  • Jun 2011
                  • 77
                  I think APFC means active power factor correction.
                  • PeteS in CA
                    • Aug 2005
                    • 3581
                    • USA, Unsure of Planet
                    That's what it is, mcday. Without power factor correction (PFC) the voltage charge on big input lytics mean that the P/S only draws current from the AC line during the very brief parts of the 50Hz or 60Hz sine when the voltage at the input is higher than the voltage across the caps. If you saw the input current on an oscilloscope you would see alternating, brief, high amplitude, positive- and negative-going spikes with relatively long periods between during which little or no current flows. Ideally, PFC allows current to flow throughout the sine wave cycle, in phase with the voltage, with sinusoidal amplitude.
                    Active PFC comes close to achieving that ideal, but requires and extra controller (or a dual controller), an extra switch device, an extra rectifier, and an extra inductor. Passive PFC doesn't come as close to the ideal, but is much simpler - a large, heavy, steel laminations core inductor between the bridge rectifier and the input lytics. Active PFC is usually wide range, capable of operating from 120VAC (nominal) or 240VAC (nominal) without setting a voltage range switch. A P/S with Passive PFC requires a range switch.
                    PeteS in CA
                    • b700029
                      Banned
                      • Sep 2010
                      • 640
                      The primary caps are within tolerance. They're usually +/- 20% so 820uF could mean anywhere from 656 to 984uF. They are probably JEE LM series ( http://www.jee-jee.com/huizhou/digit...id=1437&bb=eng ) although their catalog indicates they should be violet and not black.
                      The resistors might be 137K.
                      • c_hegge
                        • Sep 2009
                        • 5219
                        The capacitance is probably OK, but the ESR seems a bit high
                        The burned resistors look to be fairly beefy, so unless you go with larger power resistors, higher wattage ones may not be available.
                        • quattro alex
                          • Mar 2012
                          • 92
                          My colleague is looking to keep the cost down so I'll hold fire on replacing the primary caps for the moment. With regard to the resistors is it likely that their resistance has decreased or increased over time?
                          I am concerning about getting the correct wattage. When I look online the 137k 0.25w resistors don't look beefy enough. The measurements of the resistors are 11.1mm long by 3.5mm diameter, lead wire of 0.74mm. Is it likely that these would be 2w or higher in rating?
                          Is something like this suitable? http://uk.rs-online.com/web/p/throug...fixed/2142235/
                          • Th3_uN1Qu3
                            Believe in
                            • Jul 2010
                            • 6031
                            • Romania
                            They are likely to be over 1W, i think 3W ones will fit.
                            • quattro alex
                              • Mar 2012
                              • 92
                              What are the risks of going with a higher wattage?
                              • Th3_uN1Qu3
                                Believe in
                                • Jul 2010
                                • 6031
                                • Romania
                                Risk of going with higher wattage: Might not fit due to larger physical dimensions.
                                Risk of going with lower wattage: Suffer the same fate as the original ones (burn out).
                                • Behemot
                                  • 4845
                                  • CZ
                                  As for the APFC, I got some dealing with our business inspection (basicly tried to get them ban some crappy PSU, it is just fine according to them - they must be corrupted) and learned that no standard defines use of PFC in EU. There are only restriction for backward harmonic emissions, but I think that could be mostly get rid of by proper filtration. The PFC is just easy way to do that, and as for higher power-rated PSU's, you have to use APFC to not blow of your breakers all the time (cause you get higher current consumption without PFC).
                                  As for the resistors, what about doing some flymod or attaching them to heatsink? :-)
                                  • c_hegge
                                    • Sep 2009
                                    • 5219
                                    I think 3W ones will fit.
                                    They may fit, but the ones in there look like 3W, so they will just do exactly the same thing.
                                    If I wasn't going to disable APFC, I would use some 10W wire-wound resistors, use some Thermal Epoxy to stick them to a heat sink (assuming the PSU has one which isn't live) and use wires to connect them to the PCB.
                                    • Th3_uN1Qu3
                                      Believe in
                                      • Jul 2010
                                      • 6031
                                      • Romania
                                      10W resistors are huge... 5W will do.
                                      • c_hegge
                                        • Sep 2009
                                        • 5219
                                        ^ Maybe, but it's still too close to the original 3W rating. If you're attaching them with wires, size is no big deal. There's room for a pair of 10W resistors there on the APFC heat sink. I used a few for the 5vsb and 12V rails on my load tester. I didn't think they were that big.
                                        • lowpost99@gmail.com
                                          Help with Dell Latitude E5470 that shuts down when moved at all. Powers up, but no charge, power jack has brown burn marks
                                          by lowpost99@gmail.com
                                          I have a Dell E5470 that powers up and boots windows no problem. Using a non-standard universal type charger, it shuts down immediately if moved, (power short in that charger or AC power jack) because the battery has no charge and isn't charging orange/white lights blinking on the front. When first powered up, BIOS power alarm stated that it could not detect the voltage setting and I had to dis-able the message to get past this. It got into Windows fine, as long as not moved, so I dis-assembled it looking for a cold solder joint on the power jack that I thought might be lifting off the MB, but...
                                          09-03-2024, 02:57 PM
                                        • ttmi100x
                                          HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                                          by ttmi100x
                                          Greetings everyone,
                                          I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                                          The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                                          Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                                          Upon closer inspection...
                                          07-31-2024, 06:36 PM
                                        • howardc64
                                          Insignia NS-43D420NA20 backlight on no display - LCD panel burn failure
                                          by howardc64
                                          Eventually discovered a burn mark near lower corner of LCD. Here is a summary
                                          • Backlight on, no image
                                          • Disconnect right buffer board (view from front), left side display comes on
                                          • Masked off pin 7+8 (both ~12,5v on both left and right buffer board) from t-con to right buffer board (view from front) display works but have some lines
                                          • Buffer board is pretty simple
                                          Removed the front bezel to examine edge of the glass. Found burn mark on lower right (view from front). Plastic bezel covering the burn mark region shows heat signature on the inside surface facing the LCD panel. Last 2 pics. Bright...
                                          07-11-2025, 04:04 PM
                                        • dcbw
                                          PowerMac G5 ACBel 614-0303 buzzing
                                          by dcbw
                                          The PSU works, but shortly after powering on (either in the G5, or by shorting the power-on pin to ground) it begins buzzing loudly. It also makes the LED lights connected to the same circuit flicker. It's definitely a buzzing, not a high pitched whine.
                                          The buzzing seems to come from the high voltage side of the board, perhaps from the white relay. Could the relay be bad, or could the 5V supply be bad enough that it's unable to keep the relay on? Any pointers to help isolate the issue? Thanks!
                                          Other info: API2FS34, ID 291, Date B0404
                                          05-31-2024, 07:13 AM
                                        • dropfry
                                          Need help with a wine fridge controller board.
                                          by dropfry
                                          Model: Frigidaire FFWC18L2QB
                                          Board: FX101B PCB16006F1 110 HANYI
                                          This fridge was turning on, but wouldn't cool and the fans wouldn't spin in the back. Removed the back panel and found two controller boards and a power supply. The controller board at the top had burn marks under two heatsinked transistors (photo titled Top_Left). They said 13005D on them. I could not find those in America, so after a lot of googling and cross checking datasheets it looks like E13005 are replacments. Tested them with the diode setting and they both look good.
                                          Put the board back...
                                          10-07-2023, 04:55 PM
