Sansun SN-W450 ATX - buzzing & burn marks
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: Sansun SN-W450 ATX - buzzing & burn marks
    What about a 7-watt ceramic?
    I noticed in the pics above that the resistors are on the far side, farthest away from the fan; maybe they get no airflow at all right there.
    -Ben
    Muh-soggy-knee
    • quattro alex
      • Mar 2012
      • 92
      Thank you for all the suggestions - in this case I've ordered both 120k and 150k 2w resistors as this was the closest I could find to the original items. I am assuming the ceramic ones will have a higher temperature threshold and therefore longer life?
      Fixed so far: GNR TS902W monitor, Sony Game Gear, Philips FCD565, Arcam Alpha 10, Memorex SA 404amp
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        Yes, that is correct.
        A working TV? How boring!
          master hoarder
          • May 2008
          • 12175
          That APFC circuit looks way too tiny. Might not be designed properly. I would say just get rid of the APFC circuit. The PSU uses an older half-bridge technology, so it should work fine without it.
          • lowpost99@gmail.com
            Help with Dell Latitude E5470 that shuts down when moved at all. Powers up, but no charge, power jack has brown burn marks
            by lowpost99@gmail.com
            I have a Dell E5470 that powers up and boots windows no problem. Using a non-standard universal type charger, it shuts down immediately if moved, (power short in that charger or AC power jack) because the battery has no charge and isn't charging orange/white lights blinking on the front. When first powered up, BIOS power alarm stated that it could not detect the voltage setting and I had to dis-able the message to get past this. It got into Windows fine, as long as not moved, so I dis-assembled it looking for a cold solder joint on the power jack that I thought might be lifting off the MB, but...
            09-03-2024, 02:57 PM
          • ttmi100x
            HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
            by ttmi100x
            Greetings everyone,
            I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
            The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
            Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
            Upon closer inspection...
            07-31-2024, 06:36 PM
          • howardc64
            Insignia NS-43D420NA20 backlight on no display - LCD panel burn failure
            by howardc64
            Eventually discovered a burn mark near lower corner of LCD. Here is a summary
            • Backlight on, no image
            • Disconnect right buffer board (view from front), left side display comes on
            • Masked off pin 7+8 (both ~12,5v on both left and right buffer board) from t-con to right buffer board (view from front) display works but have some lines
            • Buffer board is pretty simple
            Removed the front bezel to examine edge of the glass. Found burn mark on lower right (view from front). Plastic bezel covering the burn mark region shows heat signature on the inside surface facing the LCD panel. Last 2 pics. Bright...
            07-11-2025, 04:04 PM
          • dcbw
            PowerMac G5 ACBel 614-0303 buzzing
            by dcbw
            The PSU works, but shortly after powering on (either in the G5, or by shorting the power-on pin to ground) it begins buzzing loudly. It also makes the LED lights connected to the same circuit flicker. It's definitely a buzzing, not a high pitched whine.
            The buzzing seems to come from the high voltage side of the board, perhaps from the white relay. Could the relay be bad, or could the 5V supply be bad enough that it's unable to keep the relay on? Any pointers to help isolate the issue? Thanks!
            Other info: API2FS34, ID 291, Date B0404
            05-31-2024, 07:13 AM
          • Tom41
            AOC U27G3X strange burn-in
            by Tom41
            I have an AOC U27G3X 4K gaming monitor that I use both as a TV and for gaming on a Nintendo Switch 2 console. Recently, something very strange has been happening to it. After playing a game that has an on-screen timer for a few minutes, the last digit of the timer (the one rapidly flickering from 0 to 9) appears to burn in on the monitor. Going to a different source or power cycling the monitor does not help; there is a constant flickering area on the screen where that digit was.
            It seems strange that only that digit would burn in, and NOT the other digits that are changing less frequently....
            10-23-2025, 04:33 AM
